??Lucas transmission fix?? - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The 6th Generation
Old 02-17-2011, 11:44 AM
ap116862004's Avatar
ap116862004 ap116862004 is offline
Does lucas transmission fix really work.
I tried it in the past for my 98 accord because of hard shifting on 2-3 gear on a AT transmission. And it worked, and this was like 20,000 miles ago. Now that my car lost its mojo because its doing it again, I don't know if I should add it because of different opinions. I wanna know from a 6 Gen owner if they used it on there car and what was the outcome.
Old 02-18-2011, 09:47 AM
SatinSilver's Avatar
SatinSilver SatinSilver is offline
Lube Guard Red would be my choice based on what I've read on here about it on here. I'd stay far away from the Lucas stuff based on what "Fredsvt" has said about it. It can possibly clog the small internal passages that run thru the trans.
If you want to upgrade the atf try some Redline D4. When the carrier bearings started to go on Fred's 98 Accord the above fluid helped get another 50k out of the trans.
Old 02-18-2011, 10:17 AM
Accordguy04's Avatar
Accordguy04 Accordguy04 is offline
24th Gear
Send a message via AIM to Accordguy04
I used Lucas on my Monte and it worked wonders. Def a great product and well worth the $12
Old 02-19-2011, 01:43 PM
sodaks2k sodaks2k is offline
Monte tranny does not equal accord tranny. The accord tranny is more "sensitive" to additives and can be damages easier.
2014 MSM Accord Sport Sedan 6M
Title goes here
close
video goes here
description goes here. Read Full Story
