97 Stick Shift Movement Problem - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The Early Generations
Old 08-19-2011, 07:58 AM
...Mike ...Mike is offline
We have a 1997 Accord DX - 4 cylinder - manual 5-speed transmission.
The stick shift has always moved fine - no problems.
Recently, the shift lever seems to get stuck moving out of 4th.
Less often, it now seems to have trouble sometimes when it gets out of 4th or 5th and into neutral, where it doesn't want to go anywhere.
My son told me he could slap it and make it move.
After my test drive, I told him that just wiggling a bit would suffice.
Any suggestions ?
Thanks...
...Mike
Old 08-19-2011, 07:59 AM
SatinSilver's Avatar
SatinSilver SatinSilver is offline
Has the manual transmission fluid been changed every 30k miles?
05 Toyota Matrix XR: Silver, 55k
99 Accord Coupe: 2.3, 166k, original owner.(sold)
94 Civic Coupe: manual (sold with 45k)
83 Cutlass Supreme Coupe: Traded in with 67k.
Old 08-19-2011, 01:08 PM
Let's guess 'no' . We got it with about 100K on it and it now has 120,000 miles.
We have not changed any fluid. I'm thinking maybe the prev owner did not either.
I'm guessing changing the fluid now won't fix the issue.
Does this behaviour sound characteristic of no oil changes ?
Thanks...
...Mike
Old 08-20-2011, 06:50 AM
I would put some new mtf in there and see what happens. It's worked for others in the past with similiar problems. Probably, the best mtf is GM FM syncromesh mtf. Should be available at any GM dealer. Call around first though to make sure it's in stock.
This is what Honda recommends to get rid of hard shifting in 7th and 8th gen mt's(the GM stuff). There is a tsb on it.
Old 08-21-2011, 05:40 AM
arete111 arete111 is offline
I just changed out the trans fluid on a 97 EX 5MT with Penzoil Synchromesh and it greatly helped going into reverse.
Old 09-01-2011, 04:13 PM
Rush 2112 Rush 2112 is offline
I've heard that if the fluid hasn't been changed in great amounts of time, such as 100,000 miles, that changing it can be detrimental, and actually cause problems - is this true? I just bought a 209,000 mile accord and im not sure if i should change my gear oil, clutch fluid, etc.
'87 Toyota 4runner SR5. Optioned out, remarkably slow. Equipped with ground-clearance-reducing side steps.
Gave up my 2003 EX-L V6 6-speed @ 112k miles. Lookin to take it back soon.
No longer - '91 Jetta @ 160,000; '97 Accord @ 214,000
