transmission flush
I got conflicting opinions on doing a power flush of the transmission fluid on my 99 LX 4 cyl. One guy recommended doing it right now to my Accord that I just bought used and the other guy said it can knock parts loose in the tranny due to the pressure of the power flush. I don't have a clue what is correct. Also, heard from 1 tech that there were problems with the tranny on the 99 and another said that the problem was on the 6 cyl not the 4. I'm a new Accord owner and am confused on this issue. Please help. Thanks anyone.
99 Accord LX 4dr 4cyl 4spd auto |
The power flush is not only confusing to you........ In my humble opinion it would be best to drain & fill several times.....every 2500 miles or so. About the fourth time you will have replaced 90+% of the original fluid then do it again every 15K or so. If there is a filter in your transmission change it every time you drain.
There are machines that introduce new fluid at the same time the old is drained until completely new fluid is in the transmission. Hopefully others here will know more about the name of the machine that does this, I've only heard of it. |
I would like to see more opinions on the matter of the power flush but I am leaning to the more frequent drain and fill method. The dealer I spoke with wanted about $170 to do it. Seems high to me but I don't know what is fair or not for this operation. Thanks for the reply.
I had this done to the 94 silverado at the Valvoline instant oil change. It took about 2 weeks and I had a seal leaking. Not a big repair, but it sure didnt seem to help the transmission much. I would drain, change the filter, and go on.
Honda recommends that you DO NOT flush a transmission with a machine. The proper way to "flush" is to take out what you can, refill, drive, and do it over for a few times.
The problems were on BOTH 4 and 6 cyl. They were more prominent on the 6cyl because they have more torque and more weight, but rest assured the 4 cyl is not immune. |
Thanks Benji, you gave me the same advise on my other post about my spoiler light and it sparked me to conduct my own investigation. A very good thing actually. I will NOT power flush!!!!! A little off of the subject but I hope someone reads this and heeds my advice. I thought I really messed up the other day. I was replacing the little light that illuminates the clock and in a momentary lapse or reason I did it with the car running. Bad idea. The light smoked, my power windows would not roll down, I lost the mileage display and could not move the shifter out of park. I was freaking. Turns out that 1 fuse on the driver side blew and caused all that other stuff to go with it. I thought I fried some big circuit board or something. So anything electrical no matter how small the bulb do WITH THE CAR OFF!!!!!.
The bulb probably just smoked because it had finger oils on it. Same thing with mine.
We've flushed my Accord at ~50k and ~80k. The transmission is stills slippy at take off up hill. Good luck man
1999 Honda Accord - 112k! Automatic 2.3L http://i42.photobucket.com/albums/e3...dAccord008.jpg |
Watch out there notsoslimshady, you have the 6th gen problematic automatic
Jeff 2000 Accord EX Coupe Deep Blue Velvet 4 cyl. 5MT 60K on the odo. R.I.P. Sigh.... |
I know. thank goodness such a delicate transmission is in a car driven by people who dont even want to wash a car in the winter (my parents) lollol
DO NOT FLUSH. CHANGE the transmission oil and filter. Flushing is just putting the old fluid back in, although it is recycled. It is just another useless service for mechanics to make money. Never flush, only change.
I recently purchased a 98 EX V6 coupe with 130k on it. Don't know when the tranny fluid was changed, so I asked the Honda dealer where I purchased about a flush.
They have a machine that pushes out the old fluid while leaving the tranny with new. Not high pressure. I talked them down to $130 for the service. After getting the car back, it was worth every penny! Shifts smooth as silk!
98 Accord V6 EX Coupe |
Most newer honda's don't have a servicable filter. I guarantee you when you do this service after about 45k, it'll feel like a new trans. and MORE importantly: make sure the shop that does this service uses COMPATIBLE fluid! If they use DEXRON III in all their service(s), for the newer hondas it's not compatible...says so in owners manual. OR they could use a friction modifier as an additive to make the DEXIII compatible... I'd opt for Genuine FLuid in the newer hondas... Using the wrong fluid will cause slippage. Same goes for Power Steering EXCHANGE services... I just had mine done with 107000miles and I swear it steers like new again. No more shudder and easier turning effort. Hope this helps. FLUSH = NO. EXCHANGE = YES!
2009 Accord LX Sedan Polished Metal |
THIS is what I was talking about in my first post! Seek it out! |
