Wrong Low Beam Bulbs? - Drive Accord Honda Forums
Old 02-18-2012, 08:05 AM
Captain Ron Captain Ron is offline
Long time lurker, first time poster. I have a 2008 Accord EX-L Coupe.
I recently ordered a set of headlight bulbs for my Accord. From everything I read, the 9005 are the high beam bulbs and the 9006 are the low beam bulbs. So I ordered some GE Nighthawk Platinums. Everything seemed ok.
I swapped out the High Beams with no trouble, but when I went to do the low beams (and I stopped after trying to do the driver side), I found out my bulbs didn't match! The 9006's didn't fit!
And sure enough, they failed the visual inspection too!
My existing low beams:
What I wanted to install:
Thoughts? Thanks.
Old 02-18-2012, 08:09 AM
Markus's Avatar
Markus Markus is offline
Corvalis TTX
The coupe takes H11 for the low beams. Says so right in the owner's manual. There's no way to make a 9006 fit.
Mark
08 Accord EX-L V6 sedan (non navi)
2012 Infiniti G37X | 2012 Porsche 911 Turbo S | 97 Jaguar XJ6 | 95 Ford Taurus SHO | 77 MGB | 2012 Cessna 400 Corvalis TTX
MackDaddy's Avatar
MackDaddy MackDaddy is offline
About to retire.. :)
9005/06 for Sedan headlights.
You coupe owners have H11 projector beam lows....
Edit: Markus beat me to it...
Old 02-18-2012, 09:05 AM
Artema's Avatar
Artema Artema is offline
Michael
Consider H9 instead of H11 for some extra output.
Old 02-18-2012, 11:59 AM
Gah. Good to know. Basically Amazon.com's little car match utility doesn't get specific enough about body style. It simply asks/assumes - 2008 Honda Accord.
Thanks for the heads up on this.
Old 02-18-2012, 12:01 PM
Artema's Avatar
Michael
When I purchased my headlight assemblies, not just the bulbs, I first received a Sedan model which their configuration thing said would fit. They not only took them back, but refunded me the $90 in labor at the body shop after they tried to get the wrong model installed.
Old 02-18-2012, 12:22 PM
Does anyone have a comprable bulb to recommend? The GE Nighthawk Platinum line doesn't appear to be offered in either the H9 or H11 size.
Old 02-18-2012, 12:25 PM
Artema's Avatar
Michael
Just look for the Phillips on Amazon or something. They're quite good.
Old 02-18-2012, 08:24 PM
mi08coupe mi08coupe is offline
Give the Narva H9 a try. You can find them here... http://store.candlepower.com/h-9.html
2008 Accord Coupe EX-L I4 NON_NAVI
R94 San Marino Red
Old 02-19-2012, 04:53 AM
ilovelamp's Avatar
ilovelamp ilovelamp is offline
OP, check this out.
http://www.sylvania.com/en-us/applic...s/lrgmain.aspx
2010 Accord EX-L V6 PMM Sedan (w/o nav)
My First Honda!
X-tour shiftknob
Philips HIR 9012 Low Beams
Old 02-19-2012, 05:55 AM
scb2755 scb2755 is offline
just posted this in the other lighting thread but thought it could also be very useful for people here too if its right. cost $7.41 a piece for name brand H9 seems like a great deal im trying to jump before the price goes up, just need a final confirm these will fit w. the trim in the 2009 coupe low beams
Amazon Amazon
Sent from my DROIDX using AutoGuide.com App
Tags
headlamps, headlight, headlight bulb, headlights
