Noise From Tire or From Wheel Bearing - Drive Accord Honda Forums
Old 08-12-2012, 07:49 PM
saha.manojit saha.manojit is offline
Hello Everyone,
I do hope someone can help me. I am driving a 2008 Honda Accord (EXL-Navi). I have recently installed 4 All Season Michelin Tires.
I have recently notice this issue, whenever I am driving within 60 kms speed I do not get any noise from tire. Whenever I am driving over 100 kms spped I do not get any noise from tire but whenever I am driving between 70 kms to 80 kms I do get a noise from my tire.
I am not sure whether I am getting that noise from my tire or from wheel bearing.
I have also noticed that I do not get that noise on some roads, especially when the road is very smooth I do get that noise.
Can anybody give me some idea what could be the problem?
Thanks you.
Old 08-12-2012, 09:54 PM
4G63attack 4G63attack is offline
Did it have that sound before the new set of tires???
Old 08-13-2012, 04:02 AM
Aelayyat Aelayyat is online now
If the noise was not there before you had the new tires installed then I would say there is an issue with one or more of the new tires.
IF noise was there prior then you might want to look @ the wheel bearings.
Also can you describe the sound of the noise??
Honda I own:
2010 Accord Sedan, EX V6
Black on Black
Other rides:
3 big body Cadillacs
85 Fleetwood Brougham d'elegance
90 Brougham d'elegance
05 Deville DTS
Old 08-13-2012, 04:46 AM
The noise is kind of Air circulation noise. Sounds like the Air is passing through my tire and generating that noise. When I drive keeping my window open I do not get any noise from the tire may be because of Air is getting into my car and that takes the noise away. Whenever I drive with all my window close then I do get those noise from inside the card looks like it's coming from Front Wheel at the driver side.
As I said I do get the noise when I drive between 70 kms and 90 kms
Old 08-13-2012, 05:30 AM
mobiless2's Avatar
mobiless2 mobiless2 is online now
mobiless2
It can also be air moving thru the groves of the tire. Install a temp tire on left front and test, if noise is there its your bearing, if noise is gone its your tires.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 248K
2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K
Old 08-15-2012, 06:12 AM
I took my car to Honda Service Centre they have confirmed me that the noise is coming from Rear Wheel Bearing. I am going to replace that soon.
Thank you guys for all your advise.
Old 08-17-2012, 02:52 PM
VA/DC Accord VA/DC Accord is offline
2011 4 Door Accord LX-P
The front right bearing / hub on my 2011 Accord was replaced at approximately 9,000 miles. FYI
