Installing Tein S Springs on 235/45/17 - Drive Accord Honda Forums
Old 09-04-2012, 04:07 PM
07HondaAccrd 07HondaAccrd is offline
I was wondering if I need to roll my fenders if when I install my Tein S springs on my 07 sedan. Im going to be using 235/45/17 tires
Old 09-04-2012, 04:43 PM
crackerteg's Avatar
crackerteg crackerteg is offline
Call me Z
Nope.
The tire size doesn't mean a thing if we don't know which wheels you're running. We would also need to know the offset of said wheels. If you're talking about 06-07 6MT wheels, 235 is a bit wide for a 6.5" wheel. Hell, that's a bit wide for any of the 7th gen accord OEM wheels. So again, what wheels are these tires going to be mounted to?
The name is Z
2005 Satin Silver Metallic LX sedan k24 5MT
HT spec V2 F2 Type 1 coils l Wicked Tuning rear camber arms l TL-S 20mm RSB l
EVO X GSR 18 x 8.5 +38 wheels wrapped in Falken 912 sized 225/40/18 for her pleasure l OEM V6 coupe exhaust minus resonators l
Custom "Icebox" intake l Custom polished shifter extension l Custom E46 bixenon retro in black housings l OEM rep front lip l ebay fogs l
there's more I'm forgetting
Daily beaten/ driven
Old 09-04-2012, 04:47 PM
NightMarcher01's Avatar
NightMarcher01 NightMarcher01 is offline
aka 'The Gif King'
It will be for the front, you'll definitely rub.
I'd go with 215s in the front, 225s in the back (that's if you're staggered)
If not, then you'll need to roll your fenders.
2003 Honda Accord Sedan
http://www.cardomain.com/ride/3877738
CHECK IT OUT!
Old 09-04-2012, 05:02 PM
crackerteg's Avatar
Call me Z
Incorrect. You can't assume that without knowing the wheels he's running. My previous setup was 06-07 6MT wheels with 225 width tires on S Tech springs. No rubbing whatsoever. Others who run TL/ TLS wheel which have a slightly more aggressive offset than the 6MT Accord wheels run 245 width tires on S Techs and don't rub at all. No rolling on any of theirs or my fenders.
The name is Z
Old 09-04-2012, 05:07 PM
Thanks for the reply guys. Sorry for not including the type of wheels. I'm putting on 8th gen accord wheels on. I believe they're 7.5
Old 09-05-2012, 03:52 AM
crackerteg's Avatar
Call me Z
Then you'll be perfectly fine. Those have a +45 offset IIRC and you won't even come close to touching the fenders. Be sure to post pictures once you're done.
The name is Z
Old 09-05-2012, 06:01 AM
Thanks! I will post pics as soon as I get them on
Old 09-05-2012, 03:26 PM
Bursaliozer Bursaliozer is offline
EX V6 6spd
Glad you got your answer, i just took quick cellphone pics to show you that you will be fine.
Im running 225s on 18x8 OZs with Tein S on the fronts and stock on the back. As you can see you still have 2 fingers gap with 40 series so with 45 series tires you will be fine.
Old 09-05-2012, 10:22 PM
07AccordEx-L's Avatar
07AccordEx-L 07AccordEx-L is offline
out of control
I'm running 17x8 TL-S wheels (235/45/17) and I'm dropped with no gaps and I rub :/ in the front
2006 Accord Coupe V6 6MT w/Navigation
Previous:2007 Accord i4 5AT
My 7th Gen V6 6 Speed Build
http://www.driveaccord.net/forums/sh...344#post967344
Old 09-06-2012, 04:58 AM
crackerteg's Avatar
Call me Z
Dropped on what? If it's Tein S techs, something is wrong with your suspension.
The name is Z
Old 09-06-2012, 04:29 PM
out of control
I'm on coilovers.
Old 09-06-2012, 04:55 PM
How bad does it rub and do you usually carry passengers?
Old 09-06-2012, 05:23 PM
isedawishy isedawishy is offline
posted from a toilet
55 I believe, so they'll tuck away even more..
Old 09-06-2012, 05:36 PM
_shlee_'s Avatar
_shlee_ _shlee_ is offline
SHLEE
Looks great! I'm still waiting to see if I'm going to go coilovers or springs.
Old 09-06-2012, 11:26 PM
out of control
It only rubs on bumpy turns or turns going up a narrow incline. Gonna roll my fenders to see if it helps a little.
