I am experiencing what I would call excessive valvetrain noise for the past few months. It is most noticeable in the morning, but occasionally will continue for several miles after start up.
I did a search and did not come up with anything and was wondering if anyone else has experienced this problem. It's getting colder out now and it seems to be getting worse.
Car currently has 80K miles and I just completed an oil change this weekend with Castrol synthetic 5/30. I usually fill up with 87 octane from Shell. Any advice/help would be appreciated!
Thanks for the replies. Fred it is not really noisy on startup and I would say it is loudest when I first accelerate onto the street from my driveway in the morning.
Didn't realize Castrol was that bad, can you tell me where I can find Motorcraft oil?
My 03 I4 has 75k and is also pretty noisy. On cold start-ups, like the OP said. It's probably the valves. I was thinking of having the clearances checked, even though this is scheduled for past 100k IIRC.
Ok, does it sound (please bear with me) like it's at engine speed or half speed? Almost like a "mini-diesel" sound?
If you hear it when accelerating, but it stops when you release the accelerator (but still at the same rpm) it's not valve noise, it's cold engine piston slap. Once the pistons expand in the cylinders it stops.
My Integra GSR had this sound from about 20k until I sold it, only when cold. Seems to be a pretty generic Honda noise.
The MC oil may dampen it a bit as it does flow very well when cold.
The castrol isn't great, mainly because it seems to really thin out when hot. This leads to it running off all the components after a hot shut down. Thus the rod knock I hear on older motors, and it can exacerbate piston slap as there's a lack of oil on the pistons/cylinder walls to cushion the skirts when cold.
Pennzoil is ok. It meets the basic requirements for 5w20.
Pennzoil, Quaker State and Shell oil are all the same stuff as they are all made by the same company in the same plant. Just packaged differently and a little different additive packages depending on the product.
The MC oil meets the very strict Ford/Honda double time testing for heat and shear.
Normally you won't hear valvetrain noises cold vs hot, if you're hearing clattering when accelerating, but it stops when you let off the pedal, it's most likely piston slap. Valve noise is primarily heard only at idle or slightly above when not moving. They'd have to be horrendously loud to hear them when revving the engine.
Actually, the three oils listed above are not the same. They all have different chemical compositions and bases. Each company still employs its own set of engineers.
Great info guys, and Fred it is just as you described in that I hear it when accelerating, but it stops when you release the accelerator. It does sound like a diesel, just a very quiet one. I have had plenty of cars/trucks and never had anything like this before.
Is there anything you can do other than switching oil, I always take it extra easy on the car when cold. Also, does it indicate any potential future problems? Thanks in advance.
It's piston slap. GM trucks have a huge problem with it as does Ford with certain engines.
There's nothing much you can do about it other than complain to Honda.
I know many of the older 4 cylinders Bs, Fs, Ds (to a lesser extent), all had it. The F22 in the gen 5 Accords seemed to be the loudest. High mileage J30s also have it.
Driving easy for the first mile or two as the engine warms is a very good idea, regardless of whether you have any noise or not.
As far as future problems, well it depends. Piston slap is excessive piston skirt to wall clearance, usually when cold. If you hear it hot, you've got a big problem. It does tend to get a little worse with age.
Many piston manufacturers put an area of low friction coating on the skirts to reduce the chance of hearing this and to reduce running friction. If the surface wears off, you get noise. This is why certain oils with better frictional characteristics and better specs seem to help, they can "cling" a little to the pistons on shut down to help keep the piston skirts from contacting the cylinder walls.
Most Hondas use cast aluminum pistons, they are usually fairly round when cold and expand evenly. If they've gone to hypereutectic pistons they start cold ever so slightly oval and go to round when hot and provide stronger pistons than regular cast.
Both of these are usually set fairly tight clearanced when cold.
I can't remember ever hearing of Honda using forged pistons (maybe the turbo RDX does though) they are deliberately set up looser when cold as they expand much more when hot. Anything with forged pistons sound very loud and diesel like when cold.
had exactly your problem-- it too now that it is colder became much more annoying-- solution is to have the dealer adjust the valves when the car is completely cold. they also checked and if needed retourque the head bolts.
I can't see adjusting valves curing piston slap.
I can see the "retorque" of the head bolts possibly doing something, if they weren't properly torqued in the first place. The bores will be distorted out of round.
You can't really retighten head bolts that are torque angle or torque to yield without fully loosening them. TTY bolts need to be replaced.
Since I don't have my manual in front of me I'm not sure which type they are on the K24, TE or TTY. Most Honda engines aren't TTY.
One of my customers is a now retired Shell oil employee.
Once Sopus products (Shell/Royal Dutch Petroleum) bought all three brands there is very little difference between the three until you get to things like the Q power oils and the Pennzoil Platinum.
They are all made at the same plant and shipped from the same facility from what I've been told.
Certain Shell oils in the US are considered the "low price" leaders but things like Shell Helix, which is a European product is by far better than anything we can ever get here.
