How to get Radio Code - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The 7th Generation > Audio, Electronics & Lighting
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old 03-04-2007, 10:14 AM
CALJETT55 CALJETT55 is offline
I purchased a used 2004 Honda Coupe EX and read in the owner's manual about how if you disconnect the battery, the radio will need a code to unlock it and be used again. Where can I get the code? And if I have to visit a dealership to do so, what paperwork should I bring?
Thanks!
EDIT....
Radio code can be found here >> https://radio-navicode.honda.com/
Old 03-04-2007, 12:19 PM
djharkavy djharkavy is offline
Thanks!
Check the glove box, and under the cupholders/ash tray/etc.
If nobody wrote the code down, you need the serial number of the radio and possibly your VIN.
Your dealer should be able to help you with it with those numbers. If they try to charge you, then you can try this (from a web site. I haven't tried it)
PLEASE everyone listen to me! This has happened to me twice. I discovered a very easy and FREE way to fix your radio. Make sure your radio is OFF. Hold down the preset buttons 1 and 6 at the same time. Turn the radio on and your SERIAL NUMBER will appear. 4 numbers first and then 4 more. Write them down (obviously) then call (800) 999-1009. Make sure you have your VIN number handy because they will ask for it. They will ask for your name and approx. milage, and your radio's serial number. They will then give you your radio unlock code--WRITE IT DOWN!
Old 03-04-2007, 02:27 PM
blueasianmonkey's Avatar
blueasianmonkey blueasianmonkey is offline
4th Gear
Plus if you have an Accord LX I4 there is no radio security code...
Old 03-04-2007, 09:15 PM
BenjiBoy650's Avatar
The OP does say they own an EX...
Old 03-05-2007, 05:25 AM
Accordlover's Avatar
banned
I've used a vin number to get it before, call a Honda dealer, I think they have the codes in the computers now. The only issue might be that the HU may have been replaced (a very issue prone HU in those cars) and the code may not have been updated in the system. Give a call with the vin a try.
Old 04-22-2007, 03:32 PM
takamo's Avatar
takamo takamo is offline
3rd Gear
It happend to my Accord before that I got the wrong radio code when I bought my certified Accord from the Dealer.
All you need is a Title that proof you own the car from the dealer repair shop. Too easy..
02 Accord V6 EX - OK
92 Accord LX - Retired
Old 07-06-2007, 07:11 PM
perldork's Avatar
perldork perldork is offline
just be careful, some dealers will try to charge you a fee to get that information .. don't go for that, just keep searching until you find one that doesn't .
Once you get it, a good place to keep it is online at
https://www.ahm-ownerlink.com/login.asp?brand=honda
Honda's Owners site .. accounts are free and it will help you with knowing when to do services etc.
yet another car newbie - stock 2002 EX 4-cyl F23A4 (2.3L, SOHC, ULEV, VTEC) coupe, 5-speed MT
Old 07-13-2007, 08:50 PM
4th Gear
i can see that, i did add in a "plus" just so that everyone knows, kuz when i read that in my manual, i was wondering where my code was and i found out there isn't for an lx
________________________________________
Current: 2006 Honda Accord LX I4
Love Alabaster Silver
Mods: Factory Alarm w/ Hood Switch & Mic
Blitzsafe iPod Harness
35% FormulaOne Tint + MoleSkin
Acura TL Key Conversion
Debadged Accord Sign
Color Matched Side Skirts
Fog Lights/Spoiler
F.Mods: HID retro
PastLove:1990 Honda Accord LX I4
ODO:130,000 Miles
Old 09-03-2007, 09:50 AM
07EXL5COUPE's Avatar
07EXL5COUPE 07EXL5COUPE is offline
my car had a little card in a plastic sleeve with all the owners manual stuff....
'07 EXL 4cyl 5spd
Old 09-06-2007, 10:56 AM
tracom tracom is offline
My First Post
any quick way to get the serial off an ex w/ nav? i dont have any preset buttons
2004 ex accord
Old 09-06-2007, 11:06 AM
Terps_Fan's Avatar
Terps_Fan Terps_Fan is offline
5th Gear
Sometimes they put a sticker on the left inner part of you glove compartment, which I believe to be the serial number for the stereo.
Current:
'03 Accord EX-L 5spd Sedan, Satin Silver Metallic
'00 Civic EX 5spd Coupe, Milano Red
Past:
'00 Integra GSR 5spd Hatchback, Voltage Blue Metallic
'91 CRX Si 5spd Hatchback, Phoenix Red
'88 Civic DX 4spd Hatchback, Rio Red
Future:
Old 10-17-2007, 08:17 AM
dieselgg dieselgg is offline
3rd Gear
On my 2006 SE 4dr Cdn model ... when I held down buttons 1 and 6 all I got it to say on the display was "DIRC" ... when I pressed button 4 it did a test of some sort and button brought up "DSP OK"
06 Accord SE I4 5spd Sedan
Old 12-29-2007, 09:37 PM
cp2087 cp2087 is offline
Also...I noticed when i opened the sunglass holder that there is a sticker with my radio's code and some other number sequence...
Old 12-30-2007, 04:30 AM
Aviography's Avatar
"some other number sequence" is likely the serial number of the radio.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 12-30-2007, 10:17 AM
JMoney's Avatar
JMoney JMoney is offline
Smile
I had purchased my Accord from a resaler and found out that the radio was replaced after the car was manufactured for some reason, so i had the wrong security code. I drove to the Honda dealer and went into the service dept. and they looked the code up in the computer. took 5 seconds and i was out the door. they didn't charge me or ask for any paperwork.
2003 Honda Accord Coupe EX V6 Silver
Title goes here
close
video goes here
