White smoke from engine - Drive Accord Honda Forums
Old 06-13-2013, 06:21 AM
jaypapes12 jaypapes12 is offline
I recently took my car to the shop to get an inspection and after leaving, I noticed that something was leaking from under the car. The next day, I when I turn the car on and let it run for a little a white smoke comes from the engine ( front left if you're looking at the car) that smells like burning rubber. When I accelerate, the smoke increases & the engine light runs about 45% between hot and cold. I made a mile drive this morning and before I got to the destination, the engine temperature was way too high. Anyone know what this piece is and what I could do to fix it??
The smoke is emitting from below the bolt, right after whatever that black piece is in the second picture. ...and unfortunately all pictures are rotated to the right -_-
Thanks in advance for the help.
Old 06-13-2013, 11:08 AM
to be more clear, the smoke is coming from the top of the black canister in the center of the picture that has the line running into the top of it
Old 06-13-2013, 12:09 PM
drzcb7's Avatar
drzcb7 drzcb7 is offline
4th Gear
more info on the car would help out as well.. but im assuming its a V6? and is it the front or rear of the engine bay thts smoking? cause if its the rear might be power steering hose tht there is a recall for.
2004 Accord Sedan CM6 (daily) Graphite Pearl
Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights, Hybrid Mirrors <-All OEM, TL-Type S F/RSB's, Mugen Door Visors, 08 TSX Wheels, Yakima Roof Rack w/Raptor Attachment.
1990 Accord Coupe CB7 (project) Charcoal Granite Metallic
H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Sedan Trunk Conversion, 02 Accord Rims
Old 06-13-2013, 12:23 PM
sorry about that, it's a v6 honda accord....if you're facing the engine, it's the back left thats smoking
Old 06-13-2013, 12:39 PM
Drew03Accord Drew03Accord is offline
Out of Control
You need to zoom out a bit more on the pics.
2003 LX Sedan, i4 + Automatic. 170K and counting.
Old 06-13-2013, 12:41 PM
mc1114 mc1114 is offline
6th Gear
How are the oil and coolant levels?
Power steering hose is a good possibility. Same thing happened to a friend's V6 Accord. Smoke from the back of the engine
2007 Black Coupe 6-5AT 113k
Past:
2006 Silver Coupe 6-6MT
2006 Black Coupe 6-5AT
2005 Graphite Coupe 6-5AT
2003 Black Coupe 6-6MT
Old 06-13-2013, 12:59 PM
all of the liquids are looking good...a friend of mine said that it kind of smells like the power steering fluid is burning. so possibly that is the hose bursting and spraying liquid out causing the smoke and burning rubber smell???
Old 06-13-2013, 01:03 PM
03LXV6's Avatar
03LXV6 03LXV6 is online now
Moderator
If it's PS fluid you are in luck. Well sorta. There is a recall so you wouldn't have to pay to get the hose replaced.
That's wouldn't cause the other issue you are having though.
2007 EX-L 4DR
Old 06-13-2013, 01:55 PM
Statizy's Avatar
Statizy Statizy is offline
3rd Gear
Is there some sort of 'sweet' scent?
2005 Honda Accord Sedan V6
Old 06-13-2013, 06:43 PM
HondaTechAV6 HondaTechAV6 is offline
6th Gear
the p/s hose leaks and sprays onto the catalytic converter. can cause a fire and lots of smoke. take it in, all 03-07 v6s are 100% covered
Old 06-14-2013, 05:31 AM
thanks so much for the help!! im thinking it's the recall they have....I know that typically with things on this, honda sends out a recall form to get reimbursed. Does anyone know what to do if you dont have this form/sheet/whatever
Old 06-14-2013, 06:10 AM
ifyc576 ifyc576 is offline
Honda goes by your VIN, so whomever the VIN is registered to will receive the recall notice.
I didn't bring in my recall letter to the Honda delear. I just told the Service Advisor that I was here for the power steering hose recall.
Be warned, after the dealership "looks over" your vehicle, the Service Advisor may tell you that you car needs additional work.
Be prepared to tell the SA that you have a trusted mechanic who will do the additonal work or prepare to take a hard boning as you will pay a premium price for the addtional work.
07 Accord Coupe EX-L V6 with Navi
Old 06-14-2013, 06:44 AM
Dan's Avatar
Dan Dan is offline
6th Gear
Could be something as simple as a bad radiator cap, or a busted hose. Don't remove the radiator cap when the engine is hot. you will die
3.0-AT (7th Generation)
Old 06-14-2013, 07:18 AM
KH's Avatar
KH KH is offline
6th Gear
I would bring it to your local mechanic and have him take a look. Don't keep driving it like this, it could be doing further damage.
~Kevin
'03 NHBP Coupe 6-6, XLR8 V2 j-pipe, Borla stainless exhaust, Ingalls Torque Damper, TL-S Swaybars, Neuspeed short shifter, Eibach Pro springs, Wicked Tuning camber arms, '12 Coupe 18s with 235/45/18 tires, OEM Replica Spoiler, LED tails, exLED Interior Lights projector HLs, GTA Car Kit (iPhone and aux)
Old 06-14-2013, 08:21 AM
gveng's Avatar
gveng gveng is offline
2nd Gear
I just had the power steering recalled. The only symptom I had was the smoking coming from the rear of the engine. The power steering hose won't cause your car to run hotter or overheat. It sounds to me that you have an issue with your cooling system.
Tags
coolant, engine, power steering, radiator
Title goes here
close
video goes here
