VCM or problem - Drive Accord Honda Forums
Old 06-29-2013, 06:13 PM
jrasero jrasero is offline
2nd Gear
VCM or problem
I have a 2010 Accord Coupe V6
When I am cruising/coasting I see the eco light come on which leads me to believe the VCM part of the engine is shutting down cylinders
As I start to coast I feel a slight jerk. Is that normal? is that just the engine shutting down cylinders?
or is this something else?
2010 Honda Accord Coupe EX-L V6
Old 06-29-2013, 08:52 PM
HondaTechAV6 HondaTechAV6 is offline
6th Gear
take it in and drive with a mechanic. can't tell if it's normal if I can't drive it.
there is some vibration associated with vcm operation though.
Old 07-01-2013, 02:34 AM
CtheW0rld's Avatar
CtheW0rld CtheW0rld is offline
1st time honda owner
i've had the VCM almost 3 years now. i cannot tell when it kicks in, so you may want to get it looked at.
2011 Accord Coupe EXL V6 - PMM/Black Leather/Auto & 2000 toyota MR2 Spyder
Old 07-02-2013, 07:08 AM
poorboyaccord's Avatar
poorboyaccord poorboyaccord is offline
2008 Accord Coupe EX
sounds like the transmision
Old 07-02-2013, 01:08 PM
Amperex Amperex is online now
3rd Gear
There is a transmission up-shift point at around 42 mph. If you are cruising above this speed and decide to coast. The transmission will downshift when you decelerate to approx 35mph. I try and drive on the streets at or below 40mph to eliminate experiencing this most annoying characteristic. There is also a overdrive lock-up at around 62mph. I try and drive on the highway above or below 60 mph to eliminate experiencing this most annoying characteristic. There are also perceivable cylinder deactivation (VCM) transitions. Most noticeable when the engine transitions to 3 cylinders. This most annoying characteristic of the vehicle, you just have to learn to live with.
Old 07-02-2013, 02:35 PM
RahTX RahTX is offline
3rd Gear
Mine downshifts to 4th at ~40mph and to 3rd at ~20mph. I know this is off-topic, but what are you expecting it to do? Hold 5th gear at 20mph? That doesn't seem very useful, or safe for that matter. Shouldn't you be in a gear appropriate to your speed, or am I missing something?
Regarding VCM, like CtheW0rld, I honestly can't tell when VCM engages - other than the light on the dash...
2012 PMM Coupe EX-L V6 5AT
Old 07-02-2013, 04:34 PM
3rd Gear
What your missing is that this 5 spd transmission is crude, unrefined and antiquated.
Old 07-02-2013, 08:09 PM
when i first drove my car i thot there was an issue with the transmission, i later found out that this is normal,but yeah ur right somtimes its annoying sometimes i like it
Old 07-03-2013, 08:05 AM
gooderthanyou's Avatar
gooderthanyou gooderthanyou is offline
3rd Gear
Learn to live with it!
FYI i've had the same symptoms at least 30k miles ago at least. I've had no issues and it still does the same annoying stutter. I find it best to drive a little more aggressive, the problem is when you cruise around or cruise at low speeds around 25 mph or 20 mph. The car ALWAYS wants to shift gears up. So at 25 mph, it will try to shift up, and when you go slow, it takes longer to shift. Then you might go to 20 mph, it'll shift down. Hence a "hunting transmission". Add that when it shifts, it may go from 3 cylinders to 4 cylinders to shifting. All this change makes for a clunky ride. Or cruising, 4 to 3 cylinder changes are annoying and make a HUMMMMMMM.
Makes city driving annoying, plus I hear the torque isn't enough for this big car.
Go 45+ mph, no issues.
Accelerate fast, no issues.
Title goes here
close
video goes here
