Trailer Hitch Lights on a 2007 Accord ? - Drive Accord Honda Forums
Old 05-07-2007, 08:14 AM
Mark_48 Mark_48 is offline
I'm putting a hitch on my 2007 Accord and the t-connector wiring kit that was specified for the car physically fits OK, but I'm not so sure about the way the LED brake and taillights work, that this is the correct t-connector setup. I had even called the hitch manufacturer to check and they said it was the one for this car.
Will what appears to be a standard tail light converter work with the Accords LED light system?
http://search.cartserver.com/search/...t1136&GO=GO%21
118302 T-One Connector Assembly with Converter
Old 05-07-2007, 12:45 PM
CA05LXDriver's Avatar
CA05LXDriver CA05LXDriver is offline
5th Gear
Location: Changing the world, one urinal mint at a time!
I would recommend checking it against what is recommended here www.etrailer.com
I've used them a couple times and they're 2 for 2 with shipping me the correct stuff.
Durka Durka
Old 05-07-2007, 01:28 PM
etrailer.com shows the same part number as I have. Must be the right one. Never had a car with LED brake/tail lights so I just wasn't sure it was the correct one. The other thing that threw me was the package for the t-connector harness only went up to 2006 model Accords.
Old 05-09-2007, 03:12 AM
fourhondas fourhondas is offline
Hidden Hitch Trailer Harness
Hello-
I just installed a hitch on my wife's 2003 EX and used the following from JC Whitney:
Item: 494511 CLASS I RECEIVER
Item: 515105 T-CONNECTOR
The hitch is of very high quality and a direct bolt-on and looks great on the car. The T-Connector plugged directly into the driver's side tail lamp in series with the bulb socket. No wires to cut, literally a 5 minute installation. Be careful of the bulb current on your trailer; I replaced my trailer lamps with 1157 base LEDs to reduce the load on the car's electrical system when the trailer is connected.
Good luck,
John
Old 05-09-2007, 12:53 PM
Originally Posted by fourhondas
Hello-
Good luck,
John
I never even thought to look for LED bulbs for the trailer. Does your 2003 Acccord have the LED tail/brake lights. My concern is that there may be more than simply a switch that operates the lights and I don't want to damage any electronics in the car if that's the case.
Mark....................
Old 05-09-2007, 06:06 PM
john07ex john07ex is offline
2nd Gear
I just installed a hitch on my 07 also but i had to drill holes in the trunk floor to bolt it up. And i havent wired in my lights yet. I figured i could just tap into them in line like i did before but my 07 has LED's...
hhmm interesting...
2012 accord sedan
*sold*2007 Accord coupe v6 Ex-L
CarPC with 7in touchscreen.
Old 05-10-2007, 03:18 AM
LEDs only in the Trailer, not the car...
Hello-
My wife's 2003 does not have LEDs in the tail lights. I purchased 1157 LED bulbs from www.superbrightleds.com. Those inserted into the sockets of the trailer's tail lamps. 1157 normal bulbs draw several amps of current, while the LEDs draw 0.2 amps. I did not want to risk over taxing the Accord's brake / turn signal circuits.
The Accord is a 4-Cyl. As such there is no drilling. I believe the V-6 cars have some extra heat shield that blocks the trailer hitch mounting points above the mufflers. Those don't exist on the 4-Cyl, so it is a direct bolt on without drilling.
Happy Trailering...
