Grinding/Clunking Noise When Turning Steering Wheel - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 05-31-2007, 01:30 PM
pimpp1184 pimpp1184 is offline
About a few days ago, I started noticing that when I turned my wheel in either direction, it would make a grinding/clunking noise.
I have never had this happen before and to happen all of a sudden is getting me worried.
I had checked the steering wheel fluid about a month ago and it seemed fine. I haven't checked it recently but could there be a another issue ... hopefully nothing too serious or Expensive.
Thanks.
1997 Honda Accord SE
Old 05-31-2007, 04:41 PM
turBeau turBeau is offline
Sup
Its probably the intermediate shaft getting a little dry. My wife's 05 Camry did the same thing. I just sprayed some Marvel Mystery Oil down the shaft to shut it up.
07 Sedan SE I4 Auto
TSX IM w/ P2R heatshield
Homemade CAI
2.25" exh. w/ 06 Si muffler
17mm TL sway bar
Magnefine trans. filter
Fumoto Valve
Kenwood KFC-6970ie
Old 05-31-2007, 06:37 PM
ItsaHonda's Avatar
ItsaHonda ItsaHonda is offline
6th Gear
The 96 Accord would grind sometimes when I cut the wheel sharply to the left or right. The noise could best be described as a loud metal on metal rattling/clanking from the front end that would only last for about a second or so as I turned the wheel.
I first noticed it shortly after I bought the car with 45,000 miles. The Honda service dept. and local shops couldn't find anything wrong. I drove an additional 122,000 miles without it causing any further problems.
1990 Honda Accord LX coupe
130,XXX miles
1989 Honda Accord LX sedan
186,XXX miles
1998 Lexus GS400
170,XXX miles
1992 Cadillac Allante
70,XXX miles
2013 Kia Optima LX
8,xxx miles
Old 05-31-2007, 07:02 PM
Sup
Yea, the intermediate shafts can be quite tricky sometimes. If your not familiar w/ them, its got a splined shaft on the inside with a hardened tube that goes over it. The shaft moves in and out of the tube which is suppose to be filled with grease. Over time, the moving in and out of the splined shaft can release some of the grease and thats when you start to hear the clunking. Some need to be lubed and some don't.
Like both of you have stated, you only heard or felt it when turning. Thats b/c its low on grease and bottoming out.
07 Sedan SE I4 Auto
Homemade CAI
17mm TL sway bar
Fumoto Valve
Kenwood KFC-6970ie
Old 06-01-2007, 05:26 AM
Alright I'll get some Marvel Mystery Oil or something equivalent from a car shop this weekend and spray it down the intermediate shaft. So hopefully this will resolve the issue.
Old 06-06-2007, 07:28 PM
Sup
You should be able to spray it from the inside. My wife's Camry had a little rubber boot (cover) that I took off to see the top of the shaft. It will probably be tight but you'll get it. I can take some pics of mine and post them to give you an idea if you'd like.
07 Sedan SE I4 Auto
Homemade CAI
17mm TL sway bar
Fumoto Valve
Kenwood KFC-6970ie
Old 10-10-2014, 12:45 PM
Shoesandchips Shoesandchips is offline
Intermediate shaft
Is this the column ? I mean is that where you would spray the marvel mystery oil?
Thank you
Old 10-10-2014, 02:51 PM
user320's Avatar
user320 user320 is offline
6th Gear
I'm not much of a mechanic so I'd like to see some pics of where one would spray the oil if you (or anyone else) would be kind enough to post them.
'14 BRP EXL I4 Sedan
'13 MSM EXL V6 Sedan
Old 10-16-2014, 04:44 AM
Can you display the picture of the inside where you would spray the marvel mystery oil?
Thank you
Title goes here
close
video goes here
