squeeling noise in reverse - Drive Accord Honda Forums
Old 08-09-2007, 10:10 AM
scrs309 scrs309 is offline
My daughter has a 1999 2dr accord, which makes this high pitched squeel when backing up. the car makes no noise in drive and drives fine. any ideas?
Old 08-09-2007, 10:21 AM
Accordlover's Avatar
banned
Bad Transmission?
Also, my godmothers odyssey had a squealing noise with a rattle that was caused by a loose heat shield on the cat.
Old 08-09-2007, 10:25 AM
This is coming from the rear end. My first thought is rear brakes, but it only does it in reverse. It has that same sound as brakes squeeling though.
Old 08-09-2007, 04:40 PM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
Sometimes rear brakes will just make the squeal in reverse at first. Have them checked!
We don't tolerate personal attacks!! 3 strikes & you're out!!
I kicked cancer's butt! You might be next!!!! :)
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
His: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
Old 08-10-2007, 08:34 PM
Thanks for the input, I'll check that out.
Old 08-11-2007, 04:59 AM
James.uk's Avatar
James.uk James.uk is offline
James.uk
We need more info really.. What area is the noise coming from? does it vary in pitch with speed? does applying the handbrake-footbrakes effect the sound.. etc etc..
Honda Accord. 2.0iES 4dr automatic. 1996 'N' reg. 87.000. (Burgandy) ave mpg 21. (Best 32) SOLD.
(modified) Citroen ZX 1.9 Diesel Auto 1994 "L" reg. 100K miles, (Dark Blue), ave mpg 44. (Best 55) ECU free.
2002 Wedgewood blue. Rover 75 2.0 CDTi Conniossaur Auto ave mpg 40 (best 52) mpg. :)
