Key Stuck in ON I, can't remove - Drive Accord Honda Forums
Old 08-15-2007, 12:32 PM
ouchevelless ouchevelless is offline
I have a '94 Accord EX. Once in a blue moon I would have to really wiggle the key to get it to go from the off position into where I could start the car. But, very rare.
Last night, however, the opposite: I cannot get the key out of the ignition! It won't go past ON I, but it will start. When I try to push the key in and turn it back really hard, I can hear a clicking near the shifter, but I have tried putting it back in neutral and even just shaking it around while trying to pull the key out.
How can I get this key out of there? I have another key but I can't try it to see if it helps since the current one is stuck!
Thanks for any help. I go back to school in three days and I can't just leave this sitting around with the keys hanging in the ignition, heh.
Old 08-15-2007, 12:37 PM
digitalh3lix's Avatar
digitalh3lix digitalh3lix is offline
lookin' clean
Send a message via AIM to digitalh3lix
is the steering wheel locked? try pulling the steering wheel towards the left and push in and pull out of the ignition. if thats not the case try wiggling the wheel and your keys to see if you can get it out.
2007 ASM Accord SE Sedan 5SPD
Mods:Skunk 2 knob, Neuspeed SSK, Eibach Pro-kit, Koni yellows, Modulo front lip, Hybrid Tails, HFP Silverstars, General Exclaim 225/50/17, Hawk brakes pads, 17mm RSB, strut tower,Mini H1 Retro, 6K HID, Acura Legend brake calipers, Depo headlights,Raxles, Syncromesh,Boston Acoustics
1993 Prelude VTEC 5SPD BLACK - SOLD.
Old 08-15-2007, 12:47 PM
The steering wheel isn't locked. I tried wiggling it by turning the wheel and even trying to move the whole column up and down using the adjusting lever thing. Very weird.
Old 08-15-2007, 02:50 PM
lookin' clean
can you even start the car up? if its an auto is it in park?
Old 08-15-2007, 02:55 PM
mwmcginn's Avatar
mwmcginn mwmcginn is offline
<error: divide by zero>
well, if its an automatic, there is some sort of soleniod to keep you from truning the car off with it in gear. Sounds like a failure with that. I know some cars have a manual release next to the gear shifter, under a small cover that has to be pryed off... You might pm princess to see if she has any thing on this - I think its calles shift interlock
Mike M
2006 Accord VP
Wheels, AutoDim Mirror (temp and Maplights), Car PC.
Yep it's in park and an auto. I can start it. I actually just got back from driving it around the block. It was extremely hard to get it out of park into reverse (I had to force it), but I drove and went through the gears and got it back into park and got the key out. I'll try using the other key from now on and monitor what's going on. I sometimes unlock my trunk with the key and use it to lift the trunk, I'm sure I just bent it along the way or something. I just hope the difficulty of getting it out of park had to do with the ignition switch and isn't something else.
Old 08-15-2007, 03:44 PM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
sounds like either worn out ignition switch or worn out key to me.....
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 08-15-2007, 04:20 PM
Accordlover's Avatar
banned
As a 1996 Accord owner with a failed ignition switch I say switch as well. Sometimes the tumblers inside break, and you'd be surprised how much faster the car starts with a new switch!
New switch with wiring is about 190 at th dealer. It's not available as an after-market part to my knowledge.
Old 08-15-2007, 08:49 PM
SSMV6's Avatar
SSMV6 SSMV6 is offline
39.1 going on 40mpg!
I think Mike is on the right track with this one especially after the OP said this:
2013 Accord EX-L Navi 11,178 miles and counting...
<a href=http://www.fuelly.com/driver/SSMV6/accord target=_blank><a href=http://badges.fuelly.com/images/smallsig-us/210024.png target=_blank>http://badges.fuelly.com/images/smallsig-us/210024.png</a></a> . . . . Last tank mpg = 32.2mpg
2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles
1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles
2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles
Old 08-16-2007, 11:05 AM
KidIcarus KidIcarus is offline
Refined Like an Accord
I kinda agree with Accordlover. It could be the switch. I had the "pleasure" of replace the switch about two weeks ago by the stealership. But I owuld goahead and replace the whole unit. Only problem with that is you would have one set of keys to open the door and another set to start the car.
1998 Accord V6 EX 4D
Wild Like a Nissan Xterra
Refined Like a Honda Accord
Old 08-16-2007, 04:05 PM
a_nguyen19 a_nguyen19 is offline
My brother drives a 92 accord, and he got the key stuck in there and has yet to take the key out or get an new switch. They has been in there for about a year now and no one has yet to do anything. But i guess it doesnt matter because the car has 250,000 miles and still goin strong. Good thing you got your key out though.
2007 Graphite Pearl Honda Accord EX-L 4Cyl...TL Key Conversion
35% tint
Old 08-16-2007, 04:54 PM
91EX 91EX is offline
Go Tigers!
I had a 97 Odyssey that had similar problems. There was a recall on the ignition switch. After the recall was performed, I had no problems.
91 Accord EX AT
Old 08-16-2007, 05:36 PM
Bill's Avatar
Bill Bill is offline
2007 EX-L V6 Sedan
Location: Southern New Jersey, 20 miles from Philadelphia
I had an Olds Cutlass many years ago with a similar situation. I had a lot of trouble turning the key to start the car, with a lot of jiggling involved. It finally got to a point where I could no longer do it and had to get the car towed to the dealership where they replaced the ignition switch. I was advised at the time that this was strictly a dealership item (as mentioned by one of the previous posters). Once replaced, I never had another problem with it.
Title goes here
close
video goes here
