What type of service for "B-1" maintenance minder? - Drive Accord Honda Forums
Old 08-17-2007, 12:47 PM
RLiu818 RLiu818 is offline
My Maintenance Minder came up with "B-1". What type of service do you guys recommend?
I have called several honda dealers. Some are recommending Minor service and some are recommending Intermediate Service, all of which are priced very differently depending on the dealer.
What do you guys recommend?
FYI I am at about 12K miles.
Old 08-17-2007, 01:13 PM
namegoeshere's Avatar
. . . . ლ(ಠ益ಠ)ლ . . . .
Check your manual, but I believe B-1 is: oil and filter change plus tire rotation.
I would also take a look at the air filter and cabin filter to see if they need changing. Oh, and check your brakes.
Old 08-17-2007, 03:18 PM
Scott Scott is offline
Ex Mustang Driver
B-1:
Replace engine oil and oil filter
Rotate Tires
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system
Inspect fuel lines and connections
Hope this helps.
2007 Honda Accord SE V6 Sedan Cool Blue Metallic
2008 Honda Odyssey EX-L Baltic Blue Pearl
Old 08-17-2007, 04:57 PM
Succinct's Avatar
Succinct Succinct is offline
AV6 Owner Emeritus
Send a message via AIM to Succinct
RTFM. I just had to say it. Everyone else pretty much covered it well.
Eric
2012 Mustang GT 5.0 Coupe. Garage Queen.
1991 Legend L sedan
2006 Odyssey EX-L/RES (Slate Green/Olive)
Veteran owner of numerous other Acura/Hondas previously
2001 CR-V LX 2WD - (R.I.P. Mom!) My son's car
SOLD: 2006 Accord EX-L V6 sedan (Sapphire Blue/Black, 5AT) - 27.2mm TL front sway bar, 20mm TL-S rear sway bar, tinted windows, 6MT shock tower brace, Michelin Primacy MXV4 (stock size 215/50-17)
Old 08-17-2007, 05:18 PM
Bill's Avatar
Bill Bill is offline
2007 EX-L V6 Sedan
Location: Southern New Jersey, 20 miles from Philadelphia
When I purchased my 07 Accord V6 in June, the dealer provided a Maintenance Minder pricing menu for all the Maintenance Minder services for 06 and 07 V6 models. This dealer's price for B 1 is $90.95.
Old 08-18-2007, 12:13 AM
^ what a rip off.
