Map lights not working. Neither one. Easy fix? hopefully - Drive Accord Honda Forums
Old 09-10-2007, 09:12 PM
plunk10 plunk10 is offline
2nd Deer
In another thread I mentioned that I purchased a 2004 EX-L sedan. Upon the drive home, I noticed that the map lights aren't working. Tomorrow I'm going to call the dealership and notify them (not a honda shop). Hopefully its under the short warranty that came with the car.
If not, where do I look? I'd like to think it would be a simple bulb replacement, but something tells me it could be another issue. I'm hoping its just a fuse. I played with the switch near the map lights, but they wouldn't work no matter what I tried.
thanks in advance.
Old 09-11-2007, 04:20 AM
Davisio's Avatar
Davisio Davisio is offline
2nd Gear
Map lights?
I can't think of where those are at the moment.
There's the little LED up top center. There's the "big" two lights above center for general allumination.... Do you mean those?
2006 Accord EX V6 Sedan
Old 09-11-2007, 05:56 AM
Egon's Avatar
Egon Egon is offline
4th Gear
If neither one is working, a blown fuse would be the first thing I'd look for. I don't have any schmatics, but I believe that the fuse in question is located in the left lower kick panel (driver's footwell).
2007 Honda Accord V6 EX-L Navi - Alabaster Silver
2004 Honda Odyssey EX-L RES - Redrock Pearl
Accord Mods: Polk db5250 front, Polk db690 rear, USA Spec PA11-HON2y iPod adapter, OEM Foglights, OEM strut tower brace, Acura TL 17mm rear stabilizer bar
Old 09-11-2007, 06:26 AM
2nd Deer
Originally Posted by Davisio View Post
Map lights?
Yep. The two big lights just in front of the sunglasses holder. The ones where you push the whole light to turn them on. One for each side.
Old 09-11-2007, 11:00 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
check your other courtesy lights....vanity mirror, doors.... if they aren't working either then it's fuse #6.
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 09-11-2007, 04:58 PM
2nd Deer
vanity mirrors, rear dome light, and doors are all working. damn I hope its the fuse. Haven't had a chance to pull out the box and check.
Thanks for the pdf.
Old 09-11-2007, 05:01 PM
princess's Avatar
ready to go....
Since all those things are run off the same fuse....I doubt it. I can't imagine both bulbs burning out at the same time.... but that would be easy enough to check & cheap to replace.
Old 09-12-2007, 03:26 AM
Davisio's Avatar
2nd Gear
Do the rest of the controls up there function properly?
Old 09-12-2007, 09:15 AM
2nd Deer
Everything else up there works fine. Though now I'm wondering if the switch controlling the map lights could have a problem.
As far as checking the bulbs, can I use a screwdriver to "pop" out the map light lenses? I don't want to break anything.
Old 09-12-2007, 10:57 AM
Terps_Fan's Avatar
Terps_Fan Terps_Fan is offline
5th Gear
Yes, a small screwdriver will pop out the lenses. Just make sure to be gentle and patient with them. You can even put a piece of electrical tape on the end of the screwdriver to further protect the lenses.
Current:
'03 Accord EX-L 5spd Sedan, Satin Silver Metallic
'00 Civic EX 5spd Coupe, Milano Red
Past:
'00 Integra GSR 5spd Hatchback, Voltage Blue Metallic
'91 CRX Si 5spd Hatchback, Phoenix Red
'88 Civic DX 4spd Hatchback, Rio Red
Future:
Old 09-13-2007, 06:44 AM
2nd Deer
Update. I haven't popped out the lenses yet, BUT... this morning, one of the maplights just CAME ON for the first time. I had to push the button a couple times to get it to turn off. . Still, the other one won't work regardless.
I just find it odd that they both didn't work, then suddenly one of them works. I'm now thinking maybe the previous owner had the homelink accessory, and may have disconnected it himself without hooking the map lights back up properly??
Old 09-13-2007, 08:34 AM
mwmcginn's Avatar
mwmcginn mwmcginn is offline
<error: divide by zero>
Yeah, could just be loose. What year is your car? Still under warranty? Probably not if you are asking.
May just be best to pull it apart and see whats shakin.
Mike M
2006 Accord VP
Wheels, AutoDim Mirror (temp and Maplights), Car PC.
Old 06-09-2012, 02:11 PM
rgabitan rgabitan is offline
My First Post
I have the same problem on my 2006 Honda Accord map light. The passenger side won't turn on when you open the door. I found out that the connection with the bulb was a bit loose, so I just put a piece of a tiny wooden stick to hold it in place. Once I finished with that, i tried it out, and now the light works perfectly.
Old 06-18-2014, 12:58 PM
sj_usa sj_usa is offline
sj_usa
I have a similar problem. On my 2008 Accord 2.4L EX-L (I have owned for 2 years without any issues) my driver side dome/map light went out but the bulb is fine when I tested it in the passenger side, I believe its the switch itself so I ordered a new switch ($29.99 eBay) which I will install the weekend. But here is the kicker, I found this after my battery died on the vehicle, its a Die Hard battery of 2 years so I recharged it and worked for a week then it died again. Had anyone had issues with a short in the dome/map light which ran your battery down. I have done some diagnostics and it looks like fuse 15 (10amps) is where the parasitic draw is but have yet to do additional diagnostics.
Old 06-18-2014, 02:52 PM
ethlar ethlar is offline
4th Gear
I have seen the actual switches in the map lights fail and cause behavior like this, theyre pretty easy to swap but generally you have to grab them off other accords and similar aged hondas in junk yards or get replacement lights from honda with the switches included
Title goes here
close
video goes here
