Wiring Diagram - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 10-08-2007, 01:25 AM
blueasianmonkey's Avatar
blueasianmonkey blueasianmonkey is offline
4th Gear
Wiring Diagram
Found this on accordtuner and thought everyone could be find this useful too, btw use this at your own risk, I am not responsible for the accuracy of this diagram.
FUNCTION .... WIRE COLOR .... POLARITY .... LOCATION
12volts .... white .... + .... ignition harness
Starter .... black/white .... + .... ignition harness
Ignition .... black/yellow .... + .... ignition harness
Accessory .... black/red .... + .... ignition harness
Second Accessor .... white/red .... + .... ignition harness
Keysense .... red/white or red/black .... - .... ignition harness
Power Lock .... pink/black .... - .... grn plug, L side of fusebox
Power Unlock .... pink/blue .... - .... grn plug, L side of fusebox
**These wires will meter while using the passenger door lock switch.
Lock Motor .... yellow/black .... 5wi .... grn plug, front of fusebox
Unlock Motor .... yellow/green .... 5wi .... grn plug, front of fusebox
Disarm Defeat .... yellow .... 5wi .... large wht plug above fusebox
Parking Lights+ .... red/black .... + .... large wht plug above fusebox
Parking Lights- .... black/red or blue/red .... - .... in steering column cover
Hazards .... green/red .... + .... large wht plug above fusebox
Turn Signal(L) .... red/blue .... + .... large wht plug above fusebox
Turn Signal(R) .... brown .... + .... large wht plug above fusebox
Door Trigger .... green/red .... - .... grn 5 pin plug behind fusebox
Trunk/Hatch Pin .... blue/black .... - .... driver kick, harness to rear
Hood Pin .... yellow/red .... - .... hood pin switch in latch
Trunk/Hatch Release .... yellow/green .... + ..... driver kick, harness to rear
Factory Alarm Arm .... white/red .... - .... driver door module in door
Factory Alarm Disarm .... white .... - .... driver door module in door
Disarm No Unlock factory alarm disarm
Tachometer .... blue/red or blue .... AC .... ECM/PCM
**The ECM/PCM is on the front of the transmission tunnel.
**The connectors are on the passenger side.
**On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25.
**On the 6 cylinder models it is in the gray connector A, pin 23.
Horn Trigger .... green/yellow .... - .... steering column
Speed Sense .... blue/white .... ECM/PCM
**On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26.
**On the 6 cylinder models it is in the gray connector A, pin 11
Wipers .... blue (L), yellow (H) .... - .... windshield wiper motor
LF Window up/dn .... red/black - red/yellow .... LF window switch in door
RF Window up/dn .... red/blue - red .... RF window switch in door
LR Window up/dn .... red/white - blue/black .... LR window switch in door
RR Window up/dn .... red/white - blue/black .... RR window switch in door
Sun Roof open/close .... green/yellow - green/black .... moonroof motor, rear of roof
**Only on the sedans.
**Coupes: the moonroof motor is integrated into the moonroof control unit not allowing
**access to the motor wires.
Radio 12v .... white/green .... + .... radio harness
Radio Ground .... black .... - .... radio harness
Radio Ignition .... yellow/red + .... radio harness
Radio Illumination .... red/black .... + .... radio harness
Power Antenna .... yellow/green .... + .... radio harness
LF Speaker +/- .... green/black - lt. green .... radio harness
RF Speaker +/- .... grn/yel - gray or gray/red .... radio harness
LR Speaker +/- .... blue/white - blue/black .... radio harness
A1 - YEL/GRN = Radio switch (AMP.)
A2 - YEL/RED = ACC (main stereo power supply)
A3 - GRN/RED = Radio remote switch
A4 - RED/WHT = Security input
A5 - PINK = Right rear speaker (+)
A6 - BLU/WHT = Left rear speaker (+)
A7 - GRN/YEL = Front passenger door speaker (+)(and also right tweeter +)
A8 - GRN/BLK = Driver's door speaker (+)(and also left tweeter +)
A9 - RED/BLK = Lights-on signal
A10- WHT/GRN = Constant power
A11- BROWN = Radio remote switch ground
A12- NOT USED
A13- NOT USED
A14- NOT USED
A15- BLU/YEL = Right rear speaker (-)
A16- BLU/BLK = Left rear speaker (-)
A17- GREY = Front passenger door speaker (-)(and also right tweeter -)
A18- LITE GRN = Driver door speaker (-)(and also left tweeter -)
A19- RED = Dash lights brightness controller
A20- BLK = Ground
________________________________________
Current: 2006 Honda Accord LX I4
Love Alabaster Silver
Mods: Factory Alarm w/ Hood Switch & Mic
Blitzsafe iPod Harness
35% FormulaOne Tint + MoleSkin
Acura TL Key Conversion
Debadged Accord Sign
Color Matched Side Skirts
Fog Lights/Spoiler
F.Mods: HID retro
PastLove:1990 Honda Accord LX I4
ODO:130,000 Miles
Old 10-08-2007, 01:02 PM
Calamity Coyote's Avatar
Calamity Coyote Calamity Coyote is offline
Texas Ground Pounder
Very useful information here. Thanks. I think someone should sticky this one.
2003 Accord EX Sedan V6 Auto NAVI (Noble Green Pearl)
Mods:Fog Lights-front & rear TL sway bar-V6 MT shock tower bar-AEM V2-Magnaflow cat-back-Window & Moon visors-Kaminari Lip Kit-clear bra-Bug Shield-CUSCO Type II TSX Lower brace-Enkei EV5 wheels-Trans Cooler
Audio/Video:audio under construction-KP window up, one touch moonroof, mirror tilt-Dice iPod-Rear Camera-TVandNav2go Video
Wish List:Air Ride-Charger
Old 10-08-2007, 09:49 PM
4th Gear
i thoguht it was pretty damn useful that's why i copied and pasted it to store for later on...good for modifying and putting lights in...and tsx mirrors..everythin..
Fog Lights/Spoiler
F.Mods: HID retro
ODO:130,000 Miles
Old 11-26-2008, 02:30 PM
evident evident is offline
5th Gear
reviving this thread. figuring out the color codes of the speaker wire was the most confusing thing. and i dont even know why speaker wires have a useless clip attached to it to, instead of the regular plugs!!! and the screws require a 5/16" wrench to unscrew.
2007 Accord Coupe EX-L auto I4
Nighthawk Black Pearl w/ HFP body kit
Mini H1 HID's
oem foglights
106K miles
35% Tints, 60% 3m Crystalline tint windshield
Kenwood KDC-X993 head unit w/ Alpine PDX 4.150 Amp and Focal Access 165 A1 component fronts, 690CA1 rears
Other Cars that i maintain
2007 Lexus RX350 70000 miles
Title goes here
close
video goes here
