Resetting Service Code "1" and "tool" indicator - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > 2006 Honda Accord Instructions
Old 10-17-2007, 09:09 AM
MarkBloome MarkBloome is offline
HELP
Had my car serviced, including oil change, at Pep Boys. When They finished they did NOT know how to reset the negative mile indicator, the "1" service code or the "tool" indicator.
I cant get to the dealer for a while, but they said they could handle it at the service booth.
The normal turn ignition on and hold in the reset/odometer button doesn't handle this complete reset.
Any ideas or suggestions?
Old 10-17-2007, 09:27 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
Not knowing which car you have....here's the instructions for both. pretty much the same anyway....
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 10-17-2007, 10:13 PM
Thanks - here is my info
Sorry - 2006 Honda Accord LX 4Cyl 4Door-
Tried your suggestions but odometer showing MINUS miles blinking (this my 8th Honda) first with oil life indicator.
Showing blinking Minus miles a number 1 in the service code area and a tool showing No other warning lights or codes....
I cant get to the dealer for a while, but they said they could handle it at the service booth in seconds.
Just a thought, is there hidden button inside in back of drop down glove box
r
Old 10-18-2007, 08:51 AM
princess's Avatar
ready to go....
No hidden buttons. You just need to follow the instructions. They should also be in your owner's manual. Make sure your key is on when needed & of when needed. Make sure you hold for the amount of time indicated.
Old 09-18-2010, 10:29 AM
Jhm4872 Jhm4872 is offline
[QUOTE=MarkBloome;176755]HELP
Just hold down the Trip Buttom for about 10 to 20 seconds, untill display blinks, then release, and Hold down again untill it displays 100%
Old 09-18-2010, 11:04 PM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
Really now?
2007 EX-L 4DR
Old 09-19-2010, 06:33 AM
Aviography's Avatar
Yes, nearly 3 year old thread revived!
TL shift knob, Hidden Hitch,
DA Moderator Team
Title goes here
close
video goes here
