OBD-II Code P1457 - Drive Accord Honda Forums
Old 10-31-2007, 10:18 AM
Deereboy Deereboy is offline
OBD-II Code P1457
I own a '99 Honda Accord EX (4-cyl.) with AT. It has 100k miles and has been relatively trouble free with one or two exceptions. Recently the check engine light came on while I was driving. I took it to Autozone and used a tester for the OBD-II codes. The code that came up was P1457. Since the car has been in Minnesota and Wisconsin all of its life, forums have indicated that it could be a corroded solenoid/valve assembly.
From a thread in this forum, I read Honda Service Bulletin 01-011(provided by Princess) and replaced the EVAP Control Canister Vent Shut Valve. I pulled out the no. 13 fuse to reset the system, and hoped I had fixed the problem... but the check engine light came on again after 5 or 6 driving cycles. Does anyone know what else it could be? I am hoping it isn't the PCM referred to in the Service Bulletin. Should I just bite the bullet and take it to the Honda dealer?
Thanks!
Old 10-31-2007, 02:12 PM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
maybe these will help.....
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 10-31-2007, 02:54 PM
Thank you Princess!
