radio volume limit - Drive Accord Honda Forums
Old 12-10-2007, 10:05 AM
08Coupe 08Coupe is offline
2nd Gear
radio volume limit
I have the EX coupe with the subwoofer sound system. Has anyone else noticed that when you turn up the volume at least for FM stations after the volume setting of 30, you can't hear any increase when you go from 30 to 40. Maybe it's just my ears.
Old 12-10-2007, 11:14 AM
08 Coupe's Avatar
08 Coupe 08 Coupe is offline
It's all just Hunky!
FM???whats that?
I have noticed it on CD's though. Not sure why it does it.
08 EX-L V6 Coupe
Life is Good!
Old 12-10-2007, 11:17 AM
GigaS27 GigaS27 is offline
5th Gear
Its because of the SVC setting.
What happens is if you have SVC turned on, it makes the volume increase as you go faster, so when your at idle you will not see a difference.
Stay at idle, turn your volume to 25, and turn the different settings for SVC and you will hear the volume change for each setting.
2008 Honda Accord EX-L w/ Navi
Metallic Polished Metal
4 Door
Gray Leather Interior
5-spd MT
Mods: 12" kicker L7 solobaric(1500Watt Amp); 20% Tints; HID 8000K; OEM FOGs, NaviScreen converter to TV(DIY)!
www.JohnCaetanoPhoto.com
Old 12-10-2007, 02:01 PM
2nd Gear
Thanks! that makes sense...
Old 12-10-2007, 05:43 PM
Ignition_key's Avatar
Ignition_key Ignition_key is offline
08EXL V6MT Navi
Yups.. This was introduced in the New Civis and then the New Accord.
2011 EXL V6MT NAVI (Blk/Blk) Current Ride
2009 EXL V6 Belize Blue (former)
2008 EXL V6MT NAVI (Blk/Blk) (former)
