How To Replace Rear Brake Pads On ‘06/’07 Honda Accords
This write-up is intended to assist the average DIY’er attempt to save ~$100 in labor costs for a dealership to replace worn brake pads on the latter 7th Gen model Accords. I would assume there’s not much difference b/t the ’03 – ’05 & ’06 – ’07 model Accords, but this write-up was written based on servicing the ’07 model Accord depicted.
Needless to say, one will need the following parts before attempting to service brakes:
Replacement Pads (local parts store = $40, or dealer = much more $$$)
Floor Jack (not the emergency jack in the trunk)
Jack Stands (safer support than the hydraulic jack)
¾” Socket & Impact or Lug Wrench (impact guns make life easy)
12mm open/box-in wrench
17mm open/box-in wrench
Wide-blade flathead screwdriver (pry bar or crow bar may suffice)
As you can see, these are BASIC hand tools to get you through this DIY task. I’m sure Honda technicians have the “special” tools for the trade, but no high-dollar items needed. If you’re going to replace the OEM pads with aftermarket pads, do yourself a favor by not buying the cheapest past on the market. Duralast Golds have the same average lifespan as the OEM pads (personal experience of writer only… individual results may vary). This write-up is not a debate on which is superior. Yet, aftermarket items that last just as well for less money out-of-pocket deserve a shot at proving themselves. Agreed? Now, let’s move on. Shall we?
With the vehicle sitting on jack stands, use an impact wrench to break loose the lug nuts. If an impact wrench is not a part of your tool collection, remember to loosen the lug nuts before lifting the vehicle onto jack stands. Otherwise, it’ll be tough to break the lug nuts loose while the wheel free-spins. Once the wheel is off, you should see this:
Inspect the pads for wear, and ensure that the rotor is not scorned or has grooves etched into the surface.
(Driver Side)
(Passenger Side)
Now that you’ve confirmed that the brake pads are worn (assuming the rotor is in good shape), look for two bolts on the inward side of the caliper. You’ll need the 12mm box-in side of the wrench to loosen these two bolts. The 17mm open end wrench is used on the nut with the rubber boot on it that the bolt screws into. The picture below shows the caliper removed with the bolts screwed into the nuts with the rubber boot on them.
At this point, the pads just slide out, and you can insert the new pads in place.
Below are a few shots of the worn pads that were removed.
Here’s a shot of old vs. new.
Now that the new pads are in place, the caliper piston must be retracted into the caliper to allow fitment over the new, thick pads. On older model domestic vehicles, this was done by using “C” clamps to force the piston into the housing. Other methods of achieving this was by using a pry bar (or cheater bar) to leverage the piston into the caliper. Well, here’s where foreign manufacturers have thought to engineer something superior. In the picture below, notice the piston surface is made into four (4) quadrants. The grooves are large enough to use a wide-blade screw driver, pry bar end, or crow bar end. The tool of preference is a Caliper Piston Wind Back Compressor Tool (long name to call it, huh?). You can find such a tool on eBay for an inexpensive price of $60 (shipped). Expect to pay more at a retailer (if you can find one selling them). For old-time sake, the brake fluid reservoir cap was removed to allow anticipated back-flow of fluid during compression of caliper piston (see picture below).
The above picture shows the caliper fully retracted. This is accomplished by turning the piston in a clockwise direction. You’ll also notice that a component was removed unnecessarily (see picture below).
This is not necessary to remove, and is easy to reattach in case you removed it (see next picture).
Now that you’ve successfully retracted the caliper, reinstall the caliper onto the caliper bracket, and secure it. You’ll want to ensure that it is just as tight as before it was removed. Check with your local service dealer regarding torque specs. Once you’ve completely secured the caliper with new pads, you’ll be proud to know you’ve saved your valuable time & money. This job should only take up to an hour (max), start-to-finish, if you're mechanically inclined. Take the $100 in labor, and treat yourself (and/or family) to a nice sit-down dinner. Hope this is useful to DIY'ers!!!
Here are a few more shots taken after completion:
