How To Replace Rear Brake Pads ('07 Accord) - Page 3 - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > DIY
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
  #31
Old 12-22-2008, 09:44 PM
Honda247's Avatar
Honda247 Honda247 is offline
I snapped my G string....
Send a message via Yahoo to Honda247 Send a message via Skype™ to Honda247
Honda pads. I looked at PEP boys and they didi not have any. I also checked Autozone, and none either. I just replaced the pads and did not think to lube the rods. I'll probably do that sometime after the Christmas season. I just need to get mt brakes done so I can work. Or do you think i need to do this now? Oh, yes its an 08 Accord. One of the tech at the dealer said that from 2003 to 2008 accords have this problem. He was suprised that my rear pads lasted this long, (I have 25,000 + miles on my car). He said that they usually last about 15,000 miles. I'm gonna bring my old pads to the dealer and show them how they are wearing.
2009 Civic EX TW
K&N Drop in Filter (33-2342)
Eibach SportLines (4.3140)
Apexcone Raptor V2 35W 5000K HIDs (9006)
Nokyas Hyper Yellow Stage1 2500k High/DRL (9005)
Nokyas Hyper Yellow Stage1 2500k Fogs (H11)
Painted Engine Cover
FRANCI5
Cardomain
Facebook Profile
Youtube
  #32
Old 12-28-2008, 06:25 AM
zro26t's Avatar
zro26t zro26t is offline
Southern Jag!
A lot of people thought I just drove my car SUPER HARD to have worn OEM brakes down in 20K miles. Someone started a thread about "Honda Quality" pads wearing faster than normal. At that time, I refused to pay nearly $500 dollars for Honda to charge me for pads, rotors, and labor. I bought all the hardware I needed for ~$100, and did the work myself.
UPDATE...
Now with 50K+ miles on car, front pads (w/ 30K miles driven) have more than half the material on them, and rear pads (w/ just over 20K miles driven) look practically new. Duralast Golds should last the life 1.5 times the life of descent performance tires. Should get 50K - 60K out of pads without issue under average driving conditions. I can accept that for aftermarket pads. Now, if you drive any car in an Autocross event, pad wear is emminent (sp?).
Have NO squeeks, qwirks, noises... NOTHING! If this thread helps, GREAT! That was the intent. Recommendations are welcome. Glad to illustrate a kind of "shadetree", but SAFE, way of taking care of your vehicle.
Happy Holidays!
'07 Armada SE - Family Hauler w/ tint & performance tune
'07 Accord SE V6 #1 - Graphite Pearl w/ legal tint (wife's car) TRADED & GONE (for Armada)!
'07 Accord SE V6 #2 - Alabaster Silver Metallic w/ HIDs, fog lights, less-than-legal tint, DVD & TVs for my 3 kids (wifey's car)
'86 Chevy Silverado C10 - My hotrod of choice! Don't sleep on the SLEEPER!!! ---- SOLD!
'95 Impala SS (DGGM) - My latest acquisition... Soon to be 12-sec, low-ridin', daily driven, highway cruiser!
  #33
Old 12-28-2008, 08:19 AM
rszappa1 rszappa1 is offline
6th Gear
I have an 07 with original pads and the rear are over 50% left
  #34
Old 12-28-2008, 08:23 AM
Aviography's Avatar
05', front and rear pads are at least 50% left.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
  #35
Old 12-28-2008, 09:53 AM
6th Gear
by the way I have 56,000 on it...Its all in how you drive...also no brake rotor pulsing neither....
  #36
Old 04-11-2009, 05:46 PM
6th Gear
Honda 247 what is the name of that tool that you got at Autozone?
  #37
Old 06-03-2009, 03:13 PM
DeeAgeaux's Avatar
DeeAgeaux DeeAgeaux is offline
3rd Gear
Original pads and shoes on mine at 67K miles.
I have about 30% left on front pads.
Don't know about the shoes but they don't squeel.
03 Sedan I-4 LX 5AT 93k Miles
Enkei RP03 SBC 17X8 48MM offset
General Exclaim 225/50 R 17
Neuspeed Upper Strut Tie-Bar
TL Rear Sway Bar
Suntek Tint 20% F 5% Rear
Magnefine ATF
Pennzoil Platinum 5w-20 10k OCI
Motul 5.1
  #38
Old 07-08-2009, 01:34 PM
hondaguy2582 hondaguy2582 is offline
Anyone know which side pads with the clips goes on when doing the rears? Rotor was tore up to the point I had to replace it, and nothing was left on the pads itself on the right driver side?
  #39
Old 07-14-2009, 11:20 AM
Russ Russ is offline
My '06 Accord is approaching 50K mi and it's on its second set of pads. The left rear makes a screeching sound on right turns that sounds like the wear indicator is making contact only during right turns. I thought it might be a bearing but the sound is pretty unmistakable. Has anyone else experienced this? So I'm going to inspect the pads and if necessary, change the pads.
Question: What is the proper torque spec for the caliber bolts?
Thanks,
Russ
  #40
Old 07-25-2009, 05:29 PM
Boba Fett's Avatar
Boba Fett Boba Fett is offline
4th Gear
I was actually wondering this too. What are the torque specs for the caliper mounting bolts?
7.5 Gen 2006 Accord Coupe EX 4cyl Manual
17mm rear sway bar
EBC Green Stuff Brakes
Centric Premium Rotors
Yokohama AVID TRZ
Mobil 1 Synthetic and Filter
Infinity Reference
  #41
Old 07-30-2009, 09:06 AM
DallasAccord's Avatar
DallasAccord DallasAccord is offline
Terminator
Would this work? Disc Brake Pad Piston Compressor Caliper Wind Back Tool:
Or just this one? Disc Brake Piston Cube Brake Tool:
  #42
Old 09-13-2009, 09:30 PM
Nko1000 Nko1000 is offline
so i just replaced my rear brake pads, on my 2001 honda accord coupe ex v6, and i was wondering if my e-brake could have been effected? i ask because it seems as if my e-brake got "weaker"? before when i pull up the e-brake and gas it, the car wouldnt move, but now the car moves when i press down hard with the e-brake up. it could simply be that my mind is playing tricks on me or did i screw up some where?
  #43
Old 10-16-2009, 10:22 AM
jrath1 jrath1 is offline
Overdrive
What are the torque requirements?
  #44
Old 11-06-2009, 08:19 PM
Aarmin's Avatar
Aarmin Aarmin is offline
5th Gear
Can anyone help me:
When installing (screwing in the caliper outer bolt), noting the flats on the caliper pin, make sure one of the flats rests against the projection on the caliper...
What are the "flats" on the pins so spoken of? Anyone have a picture of the caliper pin.
Code:
Code:
The compression clamp will work on the front disc-pistons, but not the rear; to prevent damage on the rear disc-pistons threads you can use a flathead screwdriver or needle-nose pliers to rotate the piston clockwise to back into the cylinder.
Also - on the rear disc brakes - align one of the grove cutouts in the piston with the tab on the rear-disc-inner-brake-pad (can anyone clarify if this is why the rear inner pad does not have a shim? - only the outer pad). Be careful not to distort the piston boot - if so, turn the piston in the opposite direction to restore the ideal shape of the boot. A little lubrication (rubber grease) could help avoid twisting the piston boot.
From a Dec. 2008 Honda bulletin:
AKEBONO-sytem: flang bolt (front): 26ft/lbs
NISSIN-system flang bolt (front): 37ft/lbs
flang bolt (rear):17ft/lbs
I don't know which system is which (AKEBONO / NISSIN); other than one is a larger system and the other isn't; it also depends on your options, and even varies by model year. I also hear there are two different rear brake systems (I guess they mean disc and drum sets? ).
Edit: I believe (maybe) the larger system is the V6 accord (37ft/lbs) and the I4 Accord is a smaller system (26ft/lbs)... 17ft/lbs for the rear disc-brake systems (they still put drums on Accords? lol)
  #45
Old 01-01-2010, 07:18 PM
berg's Avatar
berg berg is offline
6th Gear
Send a message via Yahoo to berg
Is the caliper piston put back in place by turning it?? or pushing it??
2007 Accord coupe EX i4 graphite pearl aka"Bonita"
64,2xx miles and PAID OFF! TITLE IN HAND
Magnafire AT Trans Filter
TL 17mm rear sway bar
V6 7th gen Front strut bar
Diode dynamics stage 2(white)
2005 accord chrome volume button
2010 Altima 3.5 SR Sedan Pearl White
24xxx Miles
Sport Package
Stillen Exhaust
Racingline y-pipe and RSB
Injen SRI
