Cleaning the interior ceiling - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The 9th Generation
Old 12-21-2013, 06:27 PM
JJ_H JJ_H is offline
3rd Gear
So while I was pumping gas today I guess I got some grease or some black stuff on my finger and when I reached for my sunshade it got on my ceiling. Does anyone know what fabric cleaner I can use to get this stuff off? It was very difficult to get off my finger so I'm scared that when I try to clean it it will just smudge and look even worse on my ceiling. Thanks
Old 12-21-2013, 06:39 PM
thenewjs thenewjs is offline
3rd Gear
I got the same problem but its from chicks applying makeup in the car. My plan is to attack it with some oxy.
Old 12-21-2013, 07:14 PM
TN9thSi's Avatar
TN9thSi TN9thSi is offline
5th Gear
Woolite and water, diluted 10:1. Lightly dampen a microfiber towel with the solution and gently wipe the area. Use a clean microfiber dampened with just water and do a final wipe. When I say dampened, I mean just slightly damp. You don't want to saturate the material.
2013 Accord Coupe EX-L | CVT | WOP | Black/Ivory
Old 12-21-2013, 09:50 PM
3rd Gear
10 to 1 water to Woolite ratio? Did this work out well for you?
Old 12-21-2013, 10:00 PM
karfreek's Avatar
karfreek karfreek is offline
Even My Mower Is a Honda!
Interior ceiling = Headliner
Jay
2013 Accord EX Sedan - 2.4L/Stick - Alabaster Silver
2013 Odyssey EX-L - 3.5L/5-Speed Auto - Taffeta White over Truffle
2008 Royal Star Venture - 1300cc - Very Dark Red/Black Metallic
Old 12-21-2013, 10:35 PM
TN9thSi's Avatar
5th Gear
I've used that general dilution many times with good results. You don't want to use so much Woolite that it takes much water to "rinse" it out of the fabric. Again, the key is to only lightly dampen the fabric and not allow the adhesive or backing underneath to become wet. And not apply much pressure while wiping. Just use a light back and forth motion.
Old 12-22-2013, 08:58 AM
WDMaccord WDMaccord is offline
6th Gear
Locally: Folex on a MF towel and dab the spot. Continue using clean portions of the MF and dabbing until it is clean.
Online: CG Fabric Clean diluted 1:20. Same procedure as above.
If you have detailing brush like this, it would work well for gentle agitation. I wouldn't recommend agitating with a MF towel...dab only.
http://www.autogeek.net/autoventbrush.html
Current:
2013 EX-L V6 w/ Navi Sedan Black/Ivory
2003 EX-L V6 Sedan Black/Tan
2008 CRV EX AWD Black/Black
Previous:
1999 EX-L 4 Cyl. Sedan
1997 EX-L V6
Title goes here
close
video goes here
