Automatic Transmission Fluid Color - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 03-07-2008, 06:14 PM
dknight211's Avatar
dknight211 dknight211 is offline
4th Gear
My 2007 Honda Accord Coupe V6 LX AT is approaching 9K miles, and I decided to check the transmission fluid color. The vast majority of my 9K miles has been in pretty bad stop-and-go traffic, so I am keeping a close eye on my transmission.
I took photos of the fluid wiped off from the dipstick. If is a little hard to tell the color from the photo, I would say that the color is light brown with a tint of light orange.
Is my fluid still okay?
(the dirt specs in one of the photos were from something else, not the transmission)
Thanks!!
2007 Honda Accord Coupe LX V6 AT
Old 03-07-2008, 08:26 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
It's about normal for a stop/go type use. It will darken somewhat.
If it turns a deep brown or blackish, change it. Your car could be a candidate for 15k fluid changes if it only ever sees city driving. Regardless of what the manual says. (90k changes)
Old 03-08-2008, 05:21 AM
hermann's Avatar
hermann hermann is offline
Gone but not forgotten
FredSVT has the right idea. Spend $20 every 15K and keep that fluid clean. I have been doing 15K drain and fills. The fluid stays real clean and my car shifts sooooo smooth. Just like when it was new.
2008 Toyota Tacoma Access Cab Pickup 4 cyl-5speed manual tranny
1991 BMW R100GS Purchased Feb. 1992
Old 03-08-2008, 04:27 PM
The Critic's Avatar
The Critic The Critic is offline
Resident Critic
I know an automatic transmission fluid engineer for GM, and I asked him whether or not the color of ATF is evidence of fluid condition.
His answer was that it generally isn't. The newest transmission fluids he said, are able to hold contaminants in suspension better than their predecessors. Thus, if the clutch material is a carbon fiber material, it would be normal for the fluid to darken very quickly as the fluid is doing its job.
In addition, before anyone states that a fluid's color change is due to oxidation, the newer Group II base oils have eliminated oxidation problems completely. Therefore, the fluid's failure mode is now due to friction system failure, not oxidation.
Old 03-08-2008, 07:30 PM
Succinct's Avatar
Succinct Succinct is offline
AV6 Owner Emeritus
Send a message via AIM to Succinct
+1 I was amazed how brown my ATF was for the mileage when I changed it at 15K on my AV6 and my wife's 2006 Ody. When I changed it again at 30K on my wife's Ody, it looked a lot more fresh, which tells me it's even more important to get that first 15K worth of crap out of that fluid.
Eric
2012 Mustang GT 5.0 Coupe. Garage Queen.
1991 Legend L sedan
2006 Odyssey EX-L/RES (Slate Green/Olive)
Veteran owner of numerous other Acura/Hondas previously
2001 CR-V LX 2WD - (R.I.P. Mom!) My son's car
SOLD: 2006 Accord EX-L V6 sedan (Sapphire Blue/Black, 5AT) - 27.2mm TL front sway bar, 20mm TL-S rear sway bar, tinted windows, 6MT shock tower brace, Michelin Primacy MXV4 (stock size 215/50-17)
Old 03-08-2008, 07:59 PM
dknight211's Avatar
4th Gear
Thanks guys for all the tips and advice!
I am currently planning to start doing an ATF drain and fill every time I do an oil change (which is about every 5K according to the MM).
I figure this would be in place of a 15K drain and fill 3 times. My reasoning is that an ATF drain-and-fill every 5K miles allows for more fresh fluid to be in there versus 3 ATF drain-and-fills every 15K (I am assuming dirtier fluid near the end of the 15K). (both situations are the same total mileage and total fluid used)
I have been looking over Armystrong's guide and it looks pretty easy:
http://www.driveaccord.net/forums/sh...ad.php?t=14714
Old 03-08-2008, 09:16 PM
The Critic's Avatar
Resident Critic
Again, just my opinion, but there's absolutely no reason to change it at this mileage. You really are not gaining anything and the fluid is behaving as designed.
Old 03-08-2008, 09:26 PM
namegoeshere's Avatar
And a waste of money. But hey, it's your money so do whatever makes you happy.
I've got about 250 miles to go before doing an oil and ATF change.
Old 03-09-2008, 10:52 AM
Succinct's Avatar
AV6 Owner Emeritus
Based on what I saw in my Ody and my AV6, the first ATF change at 15K is essential, but the second one could maybe wait until 45K, and then maybe every 30k thereafter. The fluid still looked pretty good at 30K when I changed it out on my wife's Ody (after also having done it at 15K).
Eric
1991 Legend L sedan
Old 03-09-2008, 09:32 PM
The Critic's Avatar
Resident Critic
Again, appearance should not be used to judge a fluid's condition. The fluid is suspending the contaminants as it should therefore it will discolor.
Just like motor oil, it is supposed to discolor.
Old 03-10-2008, 05:54 PM
Succinct's Avatar
AV6 Owner Emeritus
So if it isn't even discolored, then there aren't any contaminants supended yet. Even better!
Eric
1991 Legend L sedan
Old 03-10-2008, 05:58 PM
hermann's Avatar
Someone else finally gets it!
SemperFuzz SemperFuzz is offline
My 2006 Accord EX-L 4 Cylinder Automatic Transmission is being replaced under warranty as we speak with only 23,500 miles on it. Fluid was leaking out faster than i could check it and Tranny was acting lame like i was in drive all the time instead of overdrive.
Old 03-10-2008, 06:44 PM
The Critic's Avatar
Resident Critic
I think you missed the point. Contaminants are going to build up and be suspended the moment you pour in the fluid.
How often is enough is the question. Obviously the OEM has decided for us based on their testing. Do whatever you want, it's your car, but I just think that you are changing it way too often.
Old 03-11-2008, 01:54 PM
tr7driver's Avatar
tr7driver tr7driver is offline
ok!
The real issue here for me is that a good transmission shouldn't need fluid changed very often. The auto trannies in the Gen 7 honda V6 are not designed properly. Hondas are know for reliable and economical service. The auto trannys don't live up to this.
Title goes here
close
video goes here
