2014 Coupe EX-L, H11 or H11b? - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The 9th Generation
Old 12-30-2013, 12:36 PM
Ghostriderz85 Ghostriderz85 is offline
2nd Gear
I'm confused, what does our car use for low beam? H11 or h11b?
Old 12-30-2013, 04:05 PM
Maddman Maddman is offline
3rd Gear
Halogen - H11
HID - H11b
The "b" indicates that the HID capsule return wire is rotated 180 degrees when compared to an H11 capsule. The Honda reflector works better with an H11b.
Old 12-31-2013, 07:20 AM
Husker's Avatar
Husker Husker is offline
6th Gear
Thumbs up
One of the best mods I did to my car, going with H9 instead of H11, the difference is incredible for the price.
I tried the HID kit route, got rid of it, because of blinding on-coming cars/drivers.
I purchased THESE from Home Depot.
I cut the tab with a razor knife (Box Cutter) look at THIS for what I'm talking about.
Trust me you will be very happy with the H9 vs H11.
Old 12-31-2013, 07:55 AM
covertash's Avatar
covertash covertash is offline
4th Gear
H11"B" specifically if you end up buying from TRS (sold under their XB35 moniker). For whatever reason, other aftermarket vendors (including DDM, and even quite a few generic eBay ones) had the return wire in the correct orientation for their plain H11 bulbs; which goes to show the quality control in aftermarket parts.
Husker's alternative recommendation is solid, though, and worth pursuing if you value true night time visibility and safety.
2013 Honda Accord EX-L V6 Sedan ASM - Naomi
RV6 PCDs | HID Retrofit: Custom 4G Acura TL "Mini H1/Bi-Xenon" Projectors - TSX-R Clear Lens - Denso Slim D2S - Osram Xenarc 66240 CBI 5000K | Acura TLX V6 25.4 mm RSB | Husky WeatherBeater | Cargo Hooks | Horn Upgrade | Full Interior LEDs | Debaged
Old 01-01-2014, 03:56 AM
LAF LAF is offline
I46MT
Truly one of the cheapest and best gains for the money on lighting there is for us non/anti HID folks.
Best improvement for night driving there is. Pretty safe also. You will like it for sure and there is a big difference especially if you go to a Silverstar or Piaa bulb. But even a plain Jane bulb gives you great benefits with little fuss or expense.
Old 01-01-2014, 06:16 AM
MartyV6 MartyV6 is offline
2014 V6 Sedan
I love my new xb35/zenex ballast setup. For less than a hundred bucks the difference is night and day seriously.
Old 01-01-2014, 06:35 AM
crea78's Avatar
crea78 crea78 is offline
5th Gear
All you did was cut off the top tab from the H9 bulb as shown in the picture from the other thread. Also, how "white" are your low beams when looking at your car straight on?
Not sure if I should go this route again as I did on my 2008 Accord or go HIDs which I would love to try.
2014 Honda Accord Sport CVT
Modern Steel Metallic
3M 35% Color Stable Tint | Xenon Depot Xtreme Kit w/ Philips Bulbs | exLED interior LEDs | 5k LED parking & DRLs |WeatherTech mats | debadged
Old 01-01-2014, 06:44 AM
Husker's Avatar
6th Gear
Yep, Just cut the tab. They are very bright and the cutoff is below on coming drivers windshields.
HID is brighter, but ,the only way to do it right is very expensive.
covertash's Avatar
4th Gear
Yep, cut off the tab but file it down so that it is smooth and flat, making it easier to install the plug back in.
It is a bit whiter than the stock H11 halogens, but don't expect anywhere near HID color temperatures. The best way to describe it is that the intensity is much higher.
Old 01-01-2014, 06:53 AM
crea78's Avatar
5th Gear
For the price for improved light, I will give these a shot. Thanks
Old 01-01-2014, 10:53 AM
sutaji sutaji is offline
H11b, the HID makes the car looks more luxury
The Following User Says Thank You to sutaji For This Useful Post:
MartyV6 (01-01-2014)
Old 01-01-2014, 02:28 PM
2014 V6 Sedan
You should try the All Star Kit mentioned elsewhere here. If you want HIDs, then you will be disappointed with the H9. It just gives you more of the yellowish halogen light. You don't get that white blanket of light that xenons give. Plus you'll be replacing the H9 bulbs very often. Their life is a fraction of a normal H11. So if you're gonna go that route, buy a 6 pack
My Accord now looks like an Acura or Lexus or BMW or something. <$100 for the All Star Kit, plus $10 for some LED replacements for the license plate lights and all interior lights.
Just try the HIDs if that's what you want. Don't listen to the naysayers on here who tell you the only CORRECT way is a full projector retrofit. They are technically correct but PRACTICALLY-speaking our projectors are fine for swapping in the HID bulb. They are worried about the last 1% of perfection. I am happy with the 99% of HID goodness that I have without spending a lot of time and MONEY to get that last 1%.....
Old 01-01-2014, 03:19 PM
Gearhead82 Gearhead82 is online now
4th Gear
Wait until you have to drive at night in a heavy snowstorm or fog. As you're being blinded by your own headlights that "last 1%" is going to feel a lot more important.
2013 Sport 6MT (MSM)
Old 01-01-2014, 03:58 PM
covertash's Avatar
4th Gear
That's funny. Your so called last "1%" is what allows proper HID projectors to shine light far down the road, and wide down the sides - not down, directly into the foreground, right in front of you, as the optics of the halogen projectors are designed to do. Since you claimed in the "all star" thread that you don't do a lot of night time driving (let alone, be far from home), I would suggest you not make bold statements about "practicality" that could at best prove to be unhelpful, and at worst, be a serious detriment.
I can tell you, from personal experience, that your money saving "all star kit" is a hazard in poor weather conditions - not to mention just general night time driving on completely unlit roads, where your own headlights are your only (blinding) source of light. Try to see if you can find the white dashed lines when it is pouring rain, or in a blizzard, on a highway with other drivers, who also share your sentiments to mismatch HID bulbs and halogen reflectors/projectors. Hopefully you didn't get the bright idea to put in color matching HID's or non-functional LED's in your fog lights when driving in those conditions either.
It's comical you mention replacing the H9 bulbs often - I'm at the 3 month mark and both bulbs are still holding up fine. At $6-7 a pop, per bulb, they aren't really cheap, but it's not exactly going to put you in the red either if you have to change them out once or twice a year. Sure the OEM rated lifespan is quite low, but you are also depending on your aftermarket HID bulbs to hold up to the OEM spec'd lifespans as well. Whether if you trust them that much is entirely up to you, but I would certainly put my money on the likes of Philips or Sylvania/Osram then... wait, who makes TRS's bulbs again?
In the end, a true HID kit is more than just a pretty flood of white light, and a cutoff line. Your kit may look like it came from an Acura/Lexus/BMW, but it certainly does not perform like them.
Old 01-01-2014, 04:47 PM
crea78's Avatar
5th Gear
I was also looking at the All Star Kit but for the price of the H9s, I can also get other LEDs for my car + front seat WeatherTech mats. I did have H9s before and they lasted close to 4 years, but was weighing my options again.
Title goes here
close
video goes here
