Timing belt or chain? - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 03-17-2008, 06:38 AM
closer9 closer9 is offline
My First Post
I've heard some Honda's are going to timing chains. Are the new Accord V6's chain or belt driven?
thanks...
Old 03-17-2008, 06:49 AM
Accordlover's Avatar
banned
thanks...
Honda's with chains are all K24 4Cylinders that are in 2003-2008 Honda Accords, and the V6's all still have belts.
The V6's need belt replacements every 7 years or 105k miles.
The 2.4L 4Cylinder in the Accord has a chain designed to last the life of the engine, and it is self adjusting.
Old 03-17-2008, 07:34 AM
03LXV6's Avatar
03LXV6 03LXV6 is online now
Moderator
I would add that all honda K Series have chains. I heard something along the lines of K Series is a new design so it got the chain. The V6 is still the old J design.
2007 EX-L 4DR
Old 03-17-2008, 07:38 AM
banned
I guess I shouldn't have said K24. As what you said is what I meant.
Old 04-16-2008, 09:42 AM
Mr. C Mr. C is offline
My First Post
Confused
I'm confused a little bit.All 03-08 accords with the 2.4 engine have a time chain and not a belt right? I ask because my 04 sedan has 67K on it now and I was prepairing to budget getiting the belt changed as well as looking into the cost of parts to replace it myself. (have had a great deal of mechanical experience but very little in the Honda's) Several web searches has yeilded posting for a replacement belt (Gates) for the 4cyl 04 accord as well as idler pulleys. I just want to be proactive as I've seen the distruction a broken belt can do to the valve train in an intererience engine of which I'm assuming the 2.4 is.
I look forward to any and all replies.
Mr. C
Old 04-16-2008, 10:00 AM
JamieJam1AIM's Avatar
JamieJam1AIM JamieJam1AIM is offline
8th Gen Audio Expert
Send a message via AIM to JamieJam1AIM
I have a feeling you are mistaking the timing belt and the serpentine belt... the "S" belt is supposed to be changed at 90 to 105K miles along with the water pump.. the S belt is what loops the Alternator, Powersteering pump, the main pulley and If im not mistaken, the A/C Pulley If that belt goes and you dont catch it immediately. You could over heat the engine Blow the head gasket end up with water in the head and blow the motor... It happened on my 94 coupe in 2001... Anyone chime in please if I am Passing incorrect info... Id rather try to help, be wrong, and stand corrected, than pass on info and screw someone else up as well...
"The Black Widow Accord" SOLD!!!!!!
"Team Hybrids" Hybrid Audio Technologies & JL Audio Sponsored Sound Quality Competitor.
2011-12-13 IASCA Amateur "North American Champion"
2011 IASCA Amateur Sound Quality, (RUNNER UP)"North American Championships"
IASCA 2012-13 Spring Break Nationals SQC Amateur Champion
IASCA 2011-12-13 Spring Break Nationals Install Amateur Champion
2012 IASCA Competitor of the Year
2012 IASCA Triple Crown Champion
Mods:
Full S/Q Competition AudioSystem
Old 04-16-2008, 11:18 AM
03LXV6's Avatar
Moderator
I don't think the A/C will cause overheating. I actually cut mine off my 95 Civic when the compressor clutch failed. It my friend still has the car without the belt. Just no A/C
2007 EX-L 4DR
Old 04-16-2008, 12:17 PM
banned
There is certainly no timing belt on any 4cyl Accord from 2003-2008.
I'd just replace the drive belts, but not until 105k miles which is the first scheduled tune up.
Old 04-16-2008, 12:51 PM
stevencrosbie's Avatar
stevencrosbie stevencrosbie is offline
Rule Enforcer
Send a message via AIM to stevencrosbie
K motors are all chain driven. You still have the belt that runs the accessories and you need to change that, but that is a much easier and cheaper job.
-Steve (Moderator)
2015 Ram 2500 Crew Cab 6.7 Cummins Longhorn
2012 VW Golf TDI 4dr Tech Package 6MT
Forum Rules and Regulations
Originally Posted by Markus View Post
Here's a hint - if you don't want to be judged by what you write on an internet forum then don't write on an internet forum.
Old 09-20-2014, 11:42 PM
garry garry is offline
My First Post
Honda accord 2005
Hi there got 2005 honda accord with i vtec engine 1998 cc
Is it chain or belt?
Looking forward to hear from you
Thanks
Old 09-21-2014, 04:04 AM
fastball fastball is offline
Honda Nation
His '95 Civic had two accessory belts. Older D series motors which I think were last produced in 2005 had one belt for the A/C, and one driving the alternator and water pump.
Newer K series replaced the D, and those have serpentine belts. One belt drives all accessories.
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver
Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten
Old 02-22-2015, 06:49 PM
FunkyTown FunkyTown is offline
3rd Gear
What about the 2014 Honda Accord Hybrid. Does that have a chain or belt?
Title goes here
close
video goes here
