How to adjust front camber...is it adjustable? - Drive Accord Honda Forums
Old 03-20-2008, 03:08 PM
CA05LXDriver's Avatar
CA05LXDriver CA05LXDriver is offline
5th Gear
Location: Changing the world, one urinal mint at a time!
Just curious if it's possible to adjust a bit of negative camber into the stock ride height. On my wrx it was easy to achieve by loosening the lower arm-to-strut bolts and rotating the upper eccentric bolt.
Any such adjustment on the Accord?
Durka Durka
Old 03-20-2008, 06:27 PM
PanzerLeader's Avatar
PanzerLeader PanzerLeader is offline
Colonel
No! You will find that Honda as well as other car builders thought that being able to adjust Caster and Camber was not needed. You can adjust the toe front and rear but thats about it. You could try Hondas suggested quick fix and shift the subframe over. OR as I will be doing next week, paying through the A-- for front Caster/Camber units and Rear camber units. Because my friend Honda could care less.
2007 Morracan Red Accord Sedan, EX-L NAV 6 Cylinder, 6 spd manual Trans., Gray Interior. Tinted Windows, Splash Guards, Fog Lights, Rear Wing. Matched color body side, wheel lip and door edge moldings. Full factory bra, WeatherTech floor mats. Honda Window visors, Sunroof wind deflector, wheel locks,Trunk Cargo Liner. Rock Guard Headlight Covers. Bridgestone 960AS Pole Position W Rated Tires, HFP Suspension with Acura TLS Sway Bars. Front and Rear Camber kits, CUSCO Type II Lower Brace.
Old 03-21-2008, 12:46 PM
HCF HCF is offline
3rd Gear
Send a message via AIM to HCF
I have a print out from my recent alignment that said my camber WAS out .22.. so I am going to have to disagree with the previous poster. I belive the upper control arm provies a verry slight adjustment, not enough for larger wheels or lowering.. but enough to adjust from daily driving pot holes.
08 Sedan K24 MT
Old 03-23-2008, 06:14 AM
StraightUp80's Avatar
StraightUp80 StraightUp80 is offline
All you can do is "set the toe and let it go"
Old 03-23-2008, 08:26 AM
joerockt's Avatar
joerockt joerockt is offline
Super Slickness...
The front should be fully adjustable from what I understand. When I dropped our 06 and brought it to the alignment shop, they had no problem adjusting camber. I did have to add a camber kit for the rears though...
In fact CA05, why not just lower it? Instant negative camber all around...
Old 03-23-2008, 10:47 AM
alpha alpha is offline
5th Gear
Send a message via AIM to alpha
As stated, only toe can be adjusted. The front is not fully adjustable.
- Mark
2006 Honda Accord EX-V6 6MT Navi Sedan
Carbon Bronze Pearl/Black
Old 03-24-2008, 11:59 AM
joerockt's Avatar
Super Slickness...
*sigh* It is adjustable, not fully, but it can be adjusted...
Old 03-24-2008, 02:31 PM
RinconVTR RinconVTR is offline
4th Gear
This is correct.
You'll get .25 may be up to .50 degrees out of the natural play in the bolt hole.
Title goes here
close
video goes here
