Replacement key? - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 04-19-2008, 06:52 PM
BeaufordBuddy's Avatar
BeaufordBuddy BeaufordBuddy is offline
Fully loaded
Send a message via AIM to BeaufordBuddy
Replacement key?
Silly situation just happened. I accidentally threw my car key inside the washing machine with a load of laundry. I realized it a few minutes later after the cycle began and there was clanging around. So I took it out immediately, well after the front load washer door unlocked, and dried it off. I tried to unscrew the small tiny screw that holds the key fob cover on, the one you have to take off to replace the battery. Unfortunately it was on super tight and I ended up stripping the screw, even after using a jeweler's screwdriver. So now I can't get the cover off to dry it out or when I'll eventually have to replace the battery. The screw is half way off so the cover isn't on tight. My question is this; if I take this to the dealer will they be able to do something? It might sound crazy but is this covered under the original warranty or will I have to pay for something like this? I was looking to get a replacement key anyway so how much will that run me? I've heard horror stories about how much of a pain it is to replace key fobs and how costly they are. I have a 2005 Accord EX V6 sedan. Any insight from anyone would be great. Thanks.
2005 Honda Accord Sedan EX V6 (Satin Silver Metallic)
Specs found here
Old 04-19-2008, 07:09 PM
VTECaddict's Avatar
VTECaddict VTECaddict is offline
Out of Control
is it still able to start the car? does the remote still work?
if yes to both, you just need a new outer shell (or maybe even just the screw?). you can order that only...check on honda parts websites to get the part number(s). or just glue it or something and worry about it later when you have to change the battery.
if it can still start the car, but remote doesnt work, you need a new shell and remote portion of the key. you can easily reprogram the remote yourself...instructions are on this site somewhere.
if it cant start the car, you need a new key. the key itself is about $35 or so. cost to program the new key to your car's computer will vary from dealer to dealer. ive seen anywhere from free to $100.
2006 BMW 330i 6MT (Alpine White/Terra)
Old 04-19-2008, 07:18 PM
Aviography's Avatar
If you have access to a soldering iron, you can put the tip on the head of the screw for 10 to 20 seconds, this may help loosen the screw enough that you can remove it, let the inside dry out before trying to see if it works.
If you are lucky, you may only have to replace the battery since the water would have undoubltly shorted it out and depleted all the energy........
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 04-20-2008, 02:11 AM
tizo's Avatar
tizo tizo is offline
4th Gear
Originally Posted by BeaufordBuddy View Post
The screw is half way off so the cover isn't on tight...
any possibility of removing it the rest of the way with a small pair of needlenose pliers or something equivalent???
Old 04-20-2008, 10:28 PM
Fully loaded
Okay, I managed to pry open the back cover of the fob (the part with the Honda "H" logo). I had to cut away at some of the plastic in order to take it off. I don't understand why this screw is on so damn tight. Does this thing have to be torque down or something damn? I look in the Honda eStore for a replacement part and I can't just order that one back over. It costs $3.43 and the screw itself costs $1.75 (wow!). I'll call the local Honda dealership tomorrow and have them order those two things. Oh and there doesn't seem to be any apparent water damage to the internal keyless entry mechanism. I thought that under the fob cover there would be exposed circuitry but there is a separate piece that holds the battery and is sealed to prevent water from entering. Pretty nifty. Just another testament of great Honda ingenuity. Thanks everyone. I'm glad I managed to work this out. I didn't want to end up paying $100+ for a replacement key.
Specs found here
Old 04-20-2008, 10:38 PM
jeffreyhuhn's Avatar
jeffreyhuhn jeffreyhuhn is offline
Lock it up
throw it in the dryer next.
08 Accord Sedan EX-L V6
Polished Metal
Black Leather
93 Accord SE Coupe 212K
_____________________________
Previously owned
1980 Accord 3 door 5 speed
1999 Buick Regal GSE Supercharged
2000 Audi A4 Quattro 5 Speed
2000 Cadillac STS N*
Old 04-21-2008, 06:49 AM
Accordlover's Avatar
banned
in the pocket of some jeans! :Yes:
Get all the moisture out, put it on med - low heat.
Old 04-21-2008, 06:58 PM
Aviography's Avatar
Uh, I hope you were joking? (didn't see the )
Just put it near a sunny window for an hour or so, dryer heat maybe too much, plus all the potential for static electricity isn't good for electronics.
DA Moderator Team
Old 04-22-2008, 10:40 AM
dave118811 dave118811 is offline
I went swimming with my keys, cell phone, and wallet for a good 15 minutes. Key somehow still worked! Unfortunately can't say the same for my cell phone.
Old 04-22-2008, 07:52 PM
Sadz Sadz is offline
Stick it in a bag of rice for a day or two. Rice will absorb the moisture.
Old 04-22-2008, 07:53 PM
WOW, just realized how lame my "FIRST POST" is...........hope it helps someone! LOL!
Old 04-22-2009, 11:17 AM
melissa melissa is offline
My First Post
Key
Okay so my remote works and my key works, but the casign around that tiny screw broke and the casing won't stay together. I have it held together with rubber bands at the moment. I looked on the honda estore to see if I could get just the front and back cover of the keyless remote but couldn't find them.
Help am I missing something can I not by just these pieces?
Thanks!
Old 06-22-2011, 04:47 AM
wazy wazy is offline
My First Post
LoSt my Car Key
Hye, Iím a new member hereÖ Iíve big prob right now.. Iíve lost both of my car keys.. Iíve tow my car to Honda service centre to keep safe of the car.. and the replacement cost is around rm3450.. I donít know, can I get other solution to replace it that maybe a bit cheaper compare to the original set by honda.. you know guys.. raya is just around the corner.. some more.. my road tax gonna expired by this end of jun.. it will cost me around 3k++.. owhhh please guys.. help me.. accord latest model.. 2010.. plsÖ
pls help me.. can contact me if you dont mind at wazy.ab@gmail.com/ 0173966800.
Old 06-22-2011, 07:13 AM
georgiamadman's Avatar
georgiamadman georgiamadman is offline
HOLD MY BEER AND LOOK OUT
what did he say?
Old 06-22-2011, 07:43 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
Originally Posted by georgiamadman View Post
what did he say?
Oh, georgiamadman, I can speak jive. He said
he's in great pain and wants to know if
you can help him.
- It is just a car -
2015 CR-V, EXL, AWD
2005 Accord Sedan EX-L AT
(Just traded - 2009 Accord Coupe 6/6 Black)
Title goes here
close
video goes here
