Old 05-14-2008, 07:52 PM
Accordriver's Avatar
Accordriver Accordriver is offline
6th Gear
V6 Transmission Filter (7th gen)
Edit:
Ok, finally found my answer(I'll put as much detail as I can in to help people who have difficulty finding the answer in a search as I did):
Unlike the I4, the V6 has it's filter under the airbox, like so
Ironically I searched for hours, but missed the information that's in the FAQ ->
http://www.driveaccord.net/forums/sh...ad.php?t=13804
Part number for the filter:
25450-RAY-003
I've heard that there's an accessible transmission filter on the V6 auto, but I haven't read anything that says where. All I turned up in the search is that it's a "bear" to replace
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Old 05-15-2008, 01:16 AM
Calamity Coyote's Avatar
Calamity Coyote Calamity Coyote is offline
Texas Ground Pounder
It's not something that Honda list as a "Serviceable" maintanance part. I don't think that the job is even listed in a "over the counter" repair manual. However, yes it can be changed and yes it is a bit of a pain in the butt. If you are mechanically inclined, it is recommended. I have started a pattern on my accord to change the fluid every 10K and I plan on changing the filter as well each time now. It's a little easier if you have a CAI installed since it removes a lot of the plastic pieces that cover the filter that you are going to need to remove to access it. Other than that, it's just a little time consuming.
2003 Accord EX Sedan V6 Auto NAVI (Noble Green Pearl)
Mods:Fog Lights-front & rear TL sway bar-V6 MT shock tower bar-AEM V2-Magnaflow cat-back-Window & Moon visors-Kaminari Lip Kit-clear bra-Bug Shield-CUSCO Type II TSX Lower brace-Enkei EV5 wheels
Audio/Video:audio under construction-KP window up, one touch moonroof, mirror tilt-Dice iPod-Rear Camera-TVandNav2go Video
Wish List:Air Ride-Charger
Old 05-15-2008, 04:06 AM
6th Gear
But where is it? Under the air box?
Old 05-15-2008, 07:08 AM
turBeau turBeau is offline
Sup
It sits under the intake pipe on the bellhousing of the transmission.
07 Sedan SE I4 Auto
TSX IM w/ P2R heatshield
Homemade CAI
2.25" exh. w/ 06 Si muffler
17mm TL sway bar
Magnefine trans. filter
Fumoto Valve
Kenwood KFC-6970ie
Old 05-15-2008, 07:42 AM
brickman's Avatar
brickman brickman is offline
College...ouch!
I thought you had to remove the ATF pan...bottom plate...what ever you might call it...to access the ATF filter on the 7th gen V6?
Do you mean to say this is some sort of in-line filter? I thought the 7th gen 4cyl ATF filter was an in-line filter but not the 6cyl.
2007 Accord SE V6 Sedan Graphite Gray @ 60k
Previous - 2002 Accord SE I4 AT Sedan Silver
Facts are stubborn things, but statistics are more pliable. - Mark Twain
Old 05-15-2008, 09:38 AM
psyshack's Avatar
psyshack psyshack is offline
Out of Control
http://www.collegehillshondaparts.com/
The filter is item #7. Look down on the top of the tranny. It should be very clear. Basic automotive 101.
09 HCHII,w/Navi,I4,CVT Crap,Atomic Blue/Beige,12k Miles (Dull/MPG/Quite Civic)
07 Mazda3 S Touring,I4,5MT,Purple/Charcoal,40k Miles (Civic What?)
00 Ranger Ext,XLT,I4,5MT,White/Gray,140k Miles (Thinks it's a F-150)
X, 05 Accord EX Sedan,I4,5AT,Red/Gray,89k Miles (My Fav. Accord Gen)
X, 06 Civic EX Sedan,w/Navi,I4,5MT,Silver/Gray,44k Miles (No Better Than GM Junk)
Can you save a gal. here and there then blow a half gallon playing with the tach? It can be done!
Old 05-15-2008, 10:29 AM
brickman's Avatar
College...ouch!
The link only takes me to a search page on the College Hills Honda web site.
When I search on my car, I find nothing for an ATF filter.
Once again....you are referring to a 6cyl?
Old 05-15-2008, 11:29 AM
6th Gear
Basic automotive 101 eh?
How about the filter here in a I4:
is replaced by this in a V6:
Since you have a V6 I'm sure you noticed this...oh wait.. you don't
Old 05-15-2008, 11:40 AM
6th Gear
25450-RAY-003
Old 05-16-2008, 03:07 PM
Marc04LX's Avatar
Marc04LX Marc04LX is offline
4th Gear
I wonder if the filter could be gutted or bypassed and an inline filter added in a more accesible location?
I also propose this because it has been said that the V6 filter lacks a bypass.
Current mods: 17" HFP wheels, OEM wing, OEM foglights, and Magnefine tranny filter
Planning: tint and custom sound system
Old 05-21-2008, 11:43 AM
Marc04LX's Avatar
4th Gear
Any opinions?
Old 05-25-2008, 01:50 PM
BenjiBoy650's Avatar
DA janitor and busboy
Send a message via AIM to BenjiBoy650
Accordriver - the I4 filter you posted is a Magnefine. Not sure where you got the picture but that is not Honda stuff. I added one of those to my Ody, and sometimes it is put in with tranny replacements on the 4AT (though Honda has a non-descript filter for it).
Marc04LX, I wouldn't worry about a bypass as the tranny filter gets all clogged up and fluid still seems to circulate fine. Here's one off a 5AT Odyssey
You can add an inline filter, most people use the Magnefine I mentioned above. It has a filter element and also has a magnetic ring to trap finer particles, which is nice. Typically it's put in the return line from the radiator cooler going back to the tranny, at least on an older car. On newer cars and cars where you are installing a tranny cooler at the same time there's other guidelines. See the link below for a cutaway of the Magnefine, I found it very interesting
http://www.v6performance.net/forums/...ad.php?t=60257
Ben
'07 Accord SE K24A8/5MT, 76K
Alabaster Silver/Grey cloth
"Marshmallow" - '00 Odyssey LX J35A1/4spd AT, 120K
Taffeta White/Fern cloth
Gone & Missed...
"Sandy" - '99 Accord EX I4 5-speed sedan, 145K
Heather Mist Metallic/Ivory cloth
"Kiwi" - '04 Mazda6s V6/5MT, 70K
Sepang Green Metallic/Black Leather
Old 05-25-2008, 05:39 PM
tmus2122 tmus2122 is offline
My First Post
Just replaced mine today (I4) used one I got thru ebay from CT Powertrain Products, fit right into the oem clamp, worked great, after I got the clamps off the hoses. Got it at:
http://cgi.ebay.com/ebaymotors/ws/eB...m=260046687716
$22.50 total. Quick shiping, didn't need the hoses of course. Was happy about being able to use the oem clamp.
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
