Is it normal, for 2005 I-4? - Drive Accord Honda Forums
Old 05-25-2008, 06:04 AM
sbi sbi is offline
3rd Gear
When the engine is idle and you open the hood, to hear the valves?
2005 Accord EX I-4 Graphite Pearl
Old 05-25-2008, 06:51 AM
Aviography's Avatar
It may be the clicking of the PVC valve you are hearing.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 05-25-2008, 09:34 AM
sbi sbi is offline
3rd Gear
What is PVC valve and where is it? The clicking I am referring to coming right from the top of the engine.
And if it is indeed the PVC valve - is this OK, is it normal?
Old 05-25-2008, 11:12 AM
Edaccord08 Edaccord08 is offline
Out of Control
Its good chance what you are hearing is the fuel injectors clicking.
Honda's fuel injectors are on the loud side, I know the 2008 2.4L are and probably yours too.
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Old 05-25-2008, 11:41 AM
sbi sbi is offline
3rd Gear
That's fine (loud) as long as it's normal, and not some kind of bad valves coming at me
Old 05-25-2008, 12:04 PM
Out of Control
Did this noise just start happening, or you just got the car ?
How many miles are on the car ?
Ed
gone 1985 XR4Ti
Old 05-25-2008, 12:30 PM
04AccordCpe's Avatar
04AccordCpe 04AccordCpe is offline
04AccordCpe
let me guess, it goes
tick tick tick tick, etc....
mines always done it
[SIGPIC][/SIGPIC]
2008 V6 EX-L
Previous Accord- 2004 Coupe LX
Old 05-25-2008, 05:42 PM
sbi sbi is offline
3rd Gear
I don't think it just started, I guess this is the first time I noticed that. I have the car for 3.5 years now, it was a leased car until a month ago so I didn't really pay too much intention because my intention was to get a new lease. Things turned out that I wasn't getting a new lease but rather I bought the car from Honda, so obviously as an owner I now pay more intention to things.
Old 05-25-2008, 06:43 PM
andysinnh's Avatar
andysinnh andysinnh is offline
Administrator
Send a message via AIM to andysinnh
I've got an '05 I4 with about 35k miles - clicking from the injectors has been noticible from the first day, and hasn't changed a bit. Valves might be slightly heard, but most of what you hear is the injectors. My son's '04 Civic with the 1.7L I4 was the same way - injectors the main sound.
andy
...a member of the DriveAccord moderator staff....
We don't tolerate personal attacks!! 3 strikes & you're out!!
A 3 "Honda" (and 1 "Ford") Family in NH
04 Mazda Tribute LX 4WD (Black, Son #2's) 110k miles
12 Acura TL SH-AWD Tech Package (White, Wife's toy) 5k miles
12 Honda Civic LX coupe (Silver, Son #1's) 4k miles
13 Acura MDX SH-AWD Base (White, mine) 1k miles
Old 05-26-2008, 04:04 AM
Out of Control
Ok, well that sounds normal then, As I said before you will definitely hear clicking from in front of engine with the hood up.
Ed
gone 1985 XR4Ti
Old 05-26-2008, 05:02 AM
sbi sbi is offline
3rd Gear
Thanks!!
Old 05-27-2008, 12:54 PM
plunk10 plunk10 is offline
2nd Deer
You mean, PCV valve.
PVC is a type of plastic, or pipe
2004 Accord Sedan EX-L 2.4 5spd manual.
Old 05-27-2008, 03:07 PM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
Yea!! Someone other than me has typed it wrong!!!
I say it wrong too!!! I KNOW the difference.....it just come out wrong.
Ends in V.....it's the valve....
Ends in C.....waters the Calle Lilies, carnations, cucumbers.....
I kicked cancer's butt! You might be next!!!! :)
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
His: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
Old 05-27-2008, 04:10 PM
Aviography's Avatar
I can't believe I did that!
How embarassing!
DA Moderator Team
Old 05-27-2008, 04:49 PM
Out of Control
looks like we missed answering the PCV question.
The PCV (positive crankcase Ventilation value) is a form of check value (spring loaded) which is mounted up front and in middle of block on 2.4L, it has vacuum hose going to the intake manifold.
What it does is prevent crankcase pressure from developing which would case oil leaks, carbon deposits etc. It tends to make slight clicking noise at low speeds(idling).
here more info if you like on it.
http://en.wikipedia.org/wiki/PCV_valve
Ed
gone 1985 XR4Ti
