How to turn off the maintenance light? - Drive Accord Honda Forums
Old 05-25-2008, 10:05 PM
mistabeo mistabeo is offline
4th Gear
How would you do that? Mine is turned on... I took it into the dealership and they told me that once the car hits around 30,000 the maintenance light turns on.
2005 Honda Accord Coupe EX-V6
32k miles
Old 05-26-2008, 03:56 AM
421 421 is offline
banned
Send a message via AIM to 421
put key in, push & hold trip meter reset, turn key to on without starting car, wait until main't req'd light stops blinkin, turn off car, remove key.
Old 05-26-2008, 05:12 AM
Aviography's Avatar
30,000 miles? You'd better start finding a new dealership!
On page 62 of your Owner's Manual (you do have one, yes?), it states that from 8,000 to 10,000 miles, the indicator will light for 2 seconds every time you turn the key to ON, and then flash for 10 seconds.
After 10,000 miles without the light being resetted, the light will remain on as a constant reminder.
You have to wonder where your dealership got the 30,000 miles interval from..........
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 05-26-2008, 08:20 AM
4th Gear
ah thanks for the info guys... gonna try it later.
32k miles
Old 05-26-2008, 09:16 AM
Accordlover's Avatar
banned
Probably an uninformed service advisor who is thinking about one of their 30k mile service packages that all dealers seem to conjure up.
It's time to check the air filter, level of fluids, change the brake fluid if its never been changed, and drain/refill the AT fluid w new Honda fluid.
