car "jolts" when turning on a/c
it's done this since i got it and i figured i would ask if this is normal or if something is messed up.
if i am going slow and go to turn on my a/c, you can feel the car 'jolt' when the compressor kicks on for the a/c and obviously the a/c isn't cold right away, takes a few minutes to finally get ice cold. if i'm at a higher rate of speed (45+mph), it does it still, but it's a lot smaller than when going at a slower speed since i'm going faster the only real time it scared me is when i was pulling in to park at home and doing less than 10mph, turned it on so when i remote start it the next day it would be cold. the car jolted and you could hear it make like a clanking sound outside the car. is this normal? or do i need to have it checked out before my freaking a/c stops working in this hot south fl weather?
04 Accord Coupe V6 6spd NHBP
^modified, but never done^ |
| Sponsored Links | ||
Advertisement | ||
By jolt do you just mean a prominent vibration?
Honda's have very noisy A/C compressors. They tick/click/clunk on and off and the idle is really effected by A/C operation. The compressor should in no way effect the car's movement, so if that's whats happeneing, then you should have it looked at. However, it sounds like you might ust not familiar with Honda A/C systems; they're not the best. |
i'm due for an oil change soon so i'll have them check out the a/c then just to be safe
The car raises the RPM when the AC comes on. If the idle is too high, the possibly it could feel like a "jolt" when it happens. Usually on the newer ones, it the idle is too high you'd get a code though.
We don't tolerate personal attacks!! 3 strikes & you're out!! I kicked cancer's butt! You might be next!!!! :) (_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance. the latest in a long line of Hondas: His: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims |
i'll have to check later and see if the RPM raises when i turn the a/c on
this is true with all Hondas I've owned, even the 90's vintage Acuras - the Honda A/C kicks in really "abruptly", and can cause a "surge" feel as the rpm's kick up - and the fact you notice it at slower speeds (and lower rpm's likely) is very typical. Some are more abrupt than others. At idle, sometimes you can hear the compressor make a "clunk" as the clutch engages. It's especially true for the first time the compressor kicks in for a while (like when you put the defroster on from a vent position).
andy
...a member of the DriveAccord moderator staff.... We don't tolerate personal attacks!! 3 strikes & you're out!! A 3 "Honda" (and 1 "Ford") Family in NH 04 Mazda Tribute LX 4WD (Black, Son #2's) 110k miles 12 Acura TL SH-AWD Tech Package (White, Wife's toy) 5k miles 12 Honda Civic LX coupe (Silver, Son #1's) 4k miles 13 Acura MDX SH-AWD Base (White, mine) 1k miles |
Very very true. All Hondas do that. All 3 of our Hondas ('98 Accord EX-V6, '05 Odyssey, and mine) do that.
Billy '06 Honda Accord EX-L - Carbon Bronze/Black My Accord Mods: Fog lights, autodimming mirror, USASpec iPod adaptor, LED backup lights, cathode lights in trunk, fog light mod, Inspire taillights, 35% tints, HID retro w/TSX projectors, lip spoiler, TL switchblade key, TL 17mm rear sway, TSX signal mirrors, TL rims |
I concur...All of tha honda's in our family did that. '86 Civic, '91 Civic, '94 Accord, '03 Oddy, '06 CR-V, and tha '08 Accord. All have a lil jolt...nothing out of the ordinary from a Honda
I get the some "jolt" when stopped at a light. I find that it happens because the RPMs increase and I'm not pressing the brake all the way in so the extra RPMs will give it enough power to roll a bit.
2007 EX-L 4DR |
The "jolt" , "thump" or "bang" the compressor makes on initial start after the a/c has been off for a long while is the compressor actually not turning easily at first. Actually it can be physically locked up, depending on where the compressor is in its cycle.
The compressor is low mounted, obviously, when it sits off for anything longer than a few hours, the refrigerant oil pools in the compressor. Since oil is not compressible the engine has to work extra hard to clear the oil out and send it back into the lines. On my 6 speed, I always make sure to turn on the a/c when the rpm is below 2k if possible. I've turned it on a couple of times at around 2500 to 3k and the belt will squeal madly until the compressor is able to turn. Accords aren't the only ones that are subject to this, nearly all cars/trucks with low mount compressors with lines that drop from much higher, have oil slugging problems.
Sapphire blue '04 V6 6 speed w/ full HFP, comptech ss, momo shadow, TL-S 27.2h/20 bars, intake spacer, retro chrome MH1 HIR2 highs, hella DE fogs, EBC Ultimax, subwoofer/amp, infinity rears, HD Radio, aux adapter, navi conversion. Vermilion 1999 SVT F150 Lightning, Sylvania/Visteon Xenarc HID headlamps, '01 L turn/marker lamps, PIAA fogs, '01 up Bilstein shocks, all Pioneer speakers, Clarion subwoofer. All Redline fluids. Silverstone 2003 Honda S2000, bone stock |
Both of my 7th gens have had the same issue. Sometimes if I engage it while I'm driving it actually sounds like I've hit something on the road. It would be nice if Honda could figure out a way for the clutch to engage in a more refined way. In other four cylinder cars I've rented recently you can hardly tell when the a/c is engaged.
2006 LX-SE I4 Auto Mobil One Only Previous Babies: 2003 Accord EX I4 Manual 1996 Toyota Celica Next Car ... Accord EX 2.2 i-CDTi ?? |
Our Accord does not give a jolt, pop, bang. And it sure does not make clanking noise's. Its a little click and you can feel the draw.
The poster makes it sound like its a old Chrysler Air Temp V-Twin compressor turning on. A old pan head Harley without spark plugs of a A/C compressor if there ever was one. Have them look at it. Should be a near seamless event. IMHO.
09 HCHII,w/Navi,I4,CVT Crap,Atomic Blue/Beige,70k Miles (Dull/MPG/Quite Civic) 07 Mazda3 S Touring,I4,5MT,Purple/Charcoal,80k Miles (Civic What?) 00 Ranger Ext,XLT,I4,5MT,White/Gray,200k Miles (Thinks it's a F-150) X, 05 Accord EX Sedan,I4,5AT,Red/Gray,89k Miles (My Fav. Accord Gen) X, 06 Civic EX Sedan,w/Navi,I4,5MT,Silver/Gray,44k Miles (No Better Than GM Junk) Can you save a gal. here and there then blow a half gallon playing with the tach? It can be done! |
psyshack - i'm not exaggerating. i've had plenty of different POS cars before this one to know what a jolt is compared to a small click
andy
If mine start clattering and making undue noise. I will look into it. Click > slight hum. Thats it.
| Sponsored Links | |
Advertisement | |
