Tires 205/55R16 yes or no ?? - Drive Accord Honda Forums
Old 06-28-2008, 02:48 PM
jkozlows's Avatar
jkozlows jkozlows is offline
2nd Gear
Hello
In my country 205/60R16 (typical for accord) tires are not so popular.
So, they are more expensive (about 50%) than typical (in Poland) 205/55R16
I would like to ask, what are You thinking... are they not so small ??
Maybe somebody have 205/55R16 and can show me the photos, how are they looks.
I can buy Toyo Proxes T1-R 205/55R16 91 W
This tire is unfortunately less diameter about 1 inch (campared with nominal) - it's a lot - i think
second: are 215/55 they o'k for typical honda rim ??
Regards
Jack
Greetings from POLAND & sorry for my English
Accord EX 06 2.4 carbon bronze... beautiful sedan
Old 06-28-2008, 07:05 PM
cforez's Avatar
cforez cforez is offline
3rd Gear
I have 215/55/16s on my 2000 Accord with 16x6.5 Honda rims. Stock size was also 205/60/16. 215 width tires were standard on the USDM 06-07 V6 Accords with 6.5" rims, so you can definitely put 215 tires on your rims.
Here is a comparison of different tire sizes:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/60-16 4.8in 12.8in 25.7in 80.7in 785 0.0%
205/55-16 4.4in 12.4in 24.9in 78.2in 811 -3.1%
215/55-16 4.7in 12.7in 25.3in 79.5in 797 -1.5%
215/60-16 5.1in 13.1in 26.2in 82.2in 771 1.8%
Old 06-28-2008, 07:52 PM
gmech's Avatar
gmech gmech is offline
2nd Gear
I'm thinking the same thing that 215/55R16 would minimize the difference and thus keeping a close to stock tire ratio instead of running 55 profile on 205s. So the speedo is not messed up as much.
Old 06-29-2008, 01:35 AM
jkozlows's Avatar
2nd Gear
Originally Posted by cforez View Post
... 215 width tires were standard on the USDM 06-07 V6 Accords with 6.5" rims, so you can definitely put 215 tires on your rims.
Here were wrote, that the rims are 17 in 3.0 V6
But You are right 215 is 215.
I hope, that 215 are not to wide, and don't stand out behind the car.
Old 06-29-2008, 07:00 AM
Aviography's Avatar
Only the 6-speed manual transmission cars have the 17" rims, I believe.
The earlier models (03-05) also have 7" wide rims, vs. the 6.5" wide rims of the 06-07 V6 models.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 06-29-2008, 08:02 AM
Blackhawk's Avatar
Blackhawk Blackhawk is offline
2nd Gear
Send a message via AIM to Blackhawk Send a message via Yahoo to Blackhawk
I am running 225/45s on my 17x7s vs stock 215/50s. 7 inch rims will hold up to a 235 tightly so you should be okay with 215.
-JT
Old 06-30-2008, 07:01 AM
lebomb's Avatar
lebomb lebomb is offline
6th Gear
I have 215/55-16's
2014 Accord Sport CVT
Champagne Frost Pearl
Kicker 300watt Amp
Kicker Comp S 12" sub/ported box
SON OF THUNDER
Old 06-30-2008, 07:22 PM
honda761's Avatar
honda761 honda761 is offline
888
What is the highest sidewall I can run on my car? I have the stock 17inch V6 wheels. The ride is harsh. My car is not something I would want to take on a trip from my home in Seattle to Miami for example.
06 EX-L 6 speed V6 sedan, 101K Traded in
2011 Mazda3s Hatchback automatic
Old 07-01-2008, 05:03 AM
Blackhawk's Avatar
2nd Gear
That's probably the longest possible road trip in the lower 48 states, so don't beat yourself up too much! I think 215/55 or 225/50 would be the max you would want to put. Otherwise you'd throw off the speedo and odo more than you want to.
-JT
Old 07-03-2008, 05:48 AM
cjg1999 cjg1999 is offline
Originally Posted by lebomb View Post
I have 215/55-16's
I don't mean to hijack, but I am going to move up to the 215/55 tires for my 05 4 door. Anyone experience a drop in fuel economy going to the bigger tires (and getting away from the Michelin MXV4 energy brand) Thanks
Old 02-10-2013, 10:19 AM
gonerman gonerman is offline
Am I good to put on Firestone Affinity 215/55/16 on my 2003 Honda Accord? I am upgrading to a stock alloy wheel 5 spoke...switching out the old 15" steel hub caps! Gonna look stella!
Old 02-10-2013, 02:28 PM
namegoeshere's Avatar
Yes, as long as you don't mind the slightly inaccurate speedo and mileage readings.
Old 02-10-2013, 03:01 PM
honda4ever honda4ever is offline
4th Gear
there is only one real batman. Adam West rules.
Old 10-31-2014, 04:04 PM
aaronflynn aaronflynn is offline
My First Post
2014 Honda Accord
My 2014 Accord has 205/65/16 tires, but I have some 205/55/16 snows; besides inaccurate speed readings is there any other danger to mounting these tires?
Old 10-31-2014, 04:57 PM
Aviography's Avatar
None what so ever.
But did you realize this is the 7th Gen forum? You have a 9th Gen Accord.
DA Moderator Team
