Disconnecting the FRONT ANC Mic - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Audio & Electronics
Old 07-25-2008, 06:43 PM
sscheitel sscheitel is offline
2nd Gear
How is this accomplished?
I took down the sunglasses/vanity light overhead light and see the plug that runs the moon roof and the door lights as well as the ANC unit....
which wires do i snip to deactivate this mic?
Thanks
Proud owner of:
2008 Sedan EX-L I-4 with Navi 5SP Manual
Nighthawk Black Pearl /Black Leather
Old 07-26-2008, 09:20 AM
2nd Gear
ok...more research has yeilded that the ANC mic shares the mic port with the NAVI system...and is NOT paired inside moonroof/cabin light controls...that is just the HFL mic...jezze....
so...
I have the 08 EXL Accord with NAVI and I am trying to disconnect the front ANC mic...but in doing this it also disconnects the NAVI and HFL system....
which wire(s) going to the ANC MIC/NAVI MIC Assembly is for the ANC? There are 7 wires and the pdf documents (link below) do not address the ANC with NAVI wiring harness.
http://www.driveaccord.net/forums/sh...ad.php?t=15874
There are (7) wires going into this harness
This is why so many people in my situation have had to disconnect it from the back of the radio and not at the mic source. I do not want to disassemble my dash so i just am wondering what color wire I need to cut....
maybe someone can tell me what color wire(s) are coming out of the factory H/U that control the FRONT ANC MIC???
Jayknight/Princess....this one is aimed right in your direction!!!
Thanks
Proud owner of:
Old 07-26-2008, 09:29 AM
jayknight jayknight is offline
4th Gear
HFL uses the same mic as the navi. http://www.driveaccord.net/forums/sh...ad.php?t=18902
08 Accord PMM Sedan EX-L V6 AT
09 TSX 17mm RSB upgrade
iPod Redwine audio mod
Kicker zx300.1 with kicker crv12
Cliford 50.5X alarm
Old 07-26-2008, 09:39 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
here's the terminal.... I don't know if disconnecting just the white wire will do it for you though.....
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 07-26-2008, 09:50 AM
2nd Gear
Jayknight...disconnecting the white and black off of the one MIC did not disengage the ANC....apperently BOTH mics are involved....pulling the wires on the one did nothing....
I will now attempt to pull the white out of the harness and see where this takes me...
thank you both!!!
Proud owner of:
Old 07-26-2008, 10:05 AM
4th Gear
did u disconnect the rear mic?
Cliford 50.5X alarm
Old 07-26-2008, 10:11 AM
2nd Gear
yes...when I pull the front mic assembly I do not get the "thwoomp" out of the bass box in the trunk...it is definetely the front mic assem
Proud owner of:
Old 07-26-2008, 10:15 AM
4th Gear
that's odd, i dont have the thwoomp sound from my sub.
Cliford 50.5X alarm
Old 07-26-2008, 11:21 AM
2nd Gear
BINGO!!!!!! WE HAVE ACHIEVED TOTAL ANC CANCELLATION !!!!!!
Clipping wire# 4 (White) disabled the ANC front connection....that is what needs to be done!!!!
Thank you Princess for the schematic...it made all the difference!!!
Thanks!!!!
Proud owner of:
Old 07-26-2008, 02:26 PM
4th Gear
does your hfl work after clipping the wire?
Cliford 50.5X alarm
Old 07-26-2008, 03:22 PM
2nd Gear
Jayknight,
yes....HFL & Navi along with Bluetooth phone connection phone calls work with no issues.....
funny story...
I connected all three wiring harnesses and of course I had the sub woofer feedback....but I made a bluetooth phone call to my wife and (dont laugh) blew into each of the two mics (front left & right) to see if there was a difference...that is where I gathered that removing the black/white wires on the one mic would not work. Both mics were used for both appliacations, NAVI & ANC.....
I removed the black/white wires from the harness...as you suggested and I still was getting the "thwoomp" through the sub...hence the mic had nothing to do with the equation.
reading on this website that people had no luck just simply disconnecting the mic...I knew that I had to get to the ANC wire going into the wiring harness.
That is where Princess's diagram came into play.....one clip of the WHITE (4th one in from either side) wire and we were golden!
no "thwoomp" and the bluetooth phone calls as well as the NAVI and HFL voice commands worked perfectly.
A real blessing...
The real sad part is that I paid to have this all installed and they could not figure this out....even after they told me they had done 08 Accord installs with the ANC cancellation.
you live and learn....
Proud owner of:
Old 09-01-2008, 05:04 AM
CapoeiraChris CapoeiraChris is offline
Is there another front ANC mic location in the '08 Sedan LX-P? I don't have one located in the head lamp/sunglasses holder as indicated. Furthermore, I only have a power plug (green and black cables) that goes to this assembly?
'08 Black Accord Sedan LX-P
20% tint all around
Alpine MRV-F357 amp
2 x 10" JL subs
Alpine SPS-600s rear deck
Old 09-01-2008, 08:13 AM
princess's Avatar
ready to go....
seems to be.....
Old 09-01-2008, 05:46 PM
Alternate Front ANC mic location?
Originally Posted by princess View Post
seems to be.....
I looked into both consoles and there aren't mics in either of them on the Accord Sedan lx-p but the speakers connected to my amp still aren't sounding right, particularly when I drive. Any suggestions for finding the front mic?
20% tint all around
Alpine MRV-F357 amp
2 x 10" JL subs
Old 09-01-2008, 07:56 PM
princess's Avatar
ready to go....
In looking through the features of an LX-P, it doesn't have ANC at all! It's not standard for LX or LX-P. I'd just looked for a front mic, not IF it were a feature on yours.
