Help deciding between V6 & I4 - Drive Accord Honda Forums
Old 07-27-2008, 05:45 PM
hank08 hank08 is offline
My first drive of the 08 Accord was the I4 and while I really like to stay with a gas saving cheap I4 Accord, I found that it was both noisy and flat footed on the freeway. Have not had a chance to drive the V6 yet but I imagine it to be a lot more responsive and smoother. Can some V6 owners chime in on whether they think it's a lot smoother than the LX/EX I4?
Our current vehicles are an older Camry V6 (190ish HP) and Maxima V6 (190HP). Both v6's have more torque than the EX I4 Accord and feel much more responsive on the highway. They are also quieter at idle, cruising on the freeway and at WOT.
In an attempt to help me decide, I'll try to list out some pros and cons for the I4 over the V6.
I4 Pros:
- Saves a little more gas than the V6
- Cheaper
- Timing chain should need maintenance till > 150K miles
I4 Cons:
- Rougher idle, harsh sounds at redline
- Less power, not sure if I can get used to this
V6 Pros:
- Quieter, smoother idle
- More power
- Almost the same mpg as I4
V6 Cons:
- Timing belt needs to be replaced between 60k and 100k miles
- More expensive than I4, slightly worse gas mileage
- VCM reliability concerns (Cadillac v8-6-4 anyone?)
Looking forward to your comments.
Old 07-27-2008, 05:57 PM
markymrk720 markymrk720 is offline
2nd Gear
I bought the I4 last year before ever test driving the V6...now having driven the V6...I am kicking myself daily...
Go with the V6.
Old 07-27-2008, 06:03 PM
retrosolutions retrosolutions is offline
6th Gear
yeah, if you go I4 you will only be disappointed later on. I personally would not worry about a timing belt change 60k+
Old 07-27-2008, 06:09 PM
Bill's Avatar
Bill Bill is offline
2007 EX-L V6 Sedan
Location: Southern New Jersey, 20 miles from Philadelphia
I have not driven an 08, but my 07 V6 has lots of smooth power available. It always feels like there is power in reserve.
Couple of comments on your pros and cons:
- V6 timing belt replacement should be around 100K miles, not 60-100K.
- Don't believe maintenance is scheduled for the I4 timing chain. (Does anyone have solid info on this?)
- Agree with your comment about the VCM. This seems to add a lot of complexity with minimal payoff in terms of gas mileage. Based on Consumer Reports "real world" tests, the 08 V6 gets 1 mpg less than the 07 in mixed driving (despite the VCM) and the 0-60 time is 0.1 second slower despite the more powerful engine. I'm sure the larger size and heavier weight are responsible for both.
Of course, another factor you will need to consider is your budget. If this is not a showstopper in considering the V6, by all means make sure you test drive one.
Old 07-27-2008, 06:22 PM
flying raptor flying raptor is offline
banned
Help deciding between V6 & I4oh please
Old 07-27-2008, 06:36 PM
onewheelup's Avatar
onewheelup onewheelup is offline
Let the fun begin....
I decided on the V6 just for the added passing power on the highway. I wasnt sold on the VCM so an that ruled out the automatic. All that was left was the coupe with a 6speed. I've had a couple high reving I4's and there is just no substitute for the smooth power of the V6. I say go with the V6....but then again im bias.
2011 Acura TL SH-AWD
20" TSW InterlagosRF (20x8.5 ET43) wheels, Hankook Ventus V12 Evo (245/35/40) tires, Takeda SR Intake, P2R TB Spacer....and more to come.
2008 Honda Accord Couple PMM EX-L V6 6 speed (07/08 to 03/10)
20" Stern ST11 (20x8.5 ET45) wheels w/TPMS, Nitto NT555 (245/35/20) tires, Greddy Ti-C Single Exit Exhaust, SR Typhoon Intake w/Amsoil Dryflow Filter, Maven Mark 1/Monsterknob/S2000 CR Shift Knob's, P2R TB Spacer, 5000K (35W) Retro-Solution's HID's w/ Relay
Old 07-27-2008, 06:37 PM
Thanks for the comments so far.
The EX V6 is right at the maximum I'm willing to spend on an Accord. By the looks of the replies, I'll give the V6 a serious consideration.
My wife will be the primary driver so she won't really need the additional power that the V6 provides. However, coming from a V6, she seems a bit disappointed at the lack of merging power from the I4 and how rough it sounds compared to our Camry/Maxima V6.
I'm also trying to keep the price at a reasonable ~$25k OTD max. Any higher and I might as well bite the bullet and get a $30k+ RWD sedan.
Old 07-27-2008, 06:41 PM
JamieJam1AIM's Avatar
JamieJam1AIM JamieJam1AIM is offline
8th Gen Audio Expert
Send a message via AIM to JamieJam1AIM
Before all of you nay sayers of the I4 decide to bash it keep in mind that the car by default startup utilizes only 70 % of its power due to the auto on VSA system.. the vsa ( vehicle stability assist) keeps the car from sliding out has brake adjustment etc... with it on you lose 30 percent of the power, cant break the wheels free and naturally get better milage... with that in mind, test drive again and turn off the VSA then decide...
Team Soundstream
2012 IASCA Amateur Install Quality, "North American Champion"
2012 IASCA Amateur Sound Quality, (RUNNER UP)"North American Championships"
IASCA 2012 Spring Break Nationals
SQC Sound Amateur Champion
Install Amateur Champion
2012 IASCA Competitor of the Year
2012 IASCA Triple Crown Champion
Mods:
Greddy Exhaust TiC
Full custom S/Q Competition Audio & video System
NAV TV integration
Audison Bit One
Old 07-27-2008, 06:51 PM
AznX TL's Avatar
AznX TL AznX TL is offline
need 6 speed!
Send a message via AIM to AznX TL
wait, i thought vsa only activates when you have the ! light up on the gauge cluster. otherwise its idle and comes on when needed.
-08 Accord lx-s 5speed manual/ tafetta white
mods
|DDM tuning 6k hids|12" Alpine Type-R|TSX switchblade|Lip spoiler|Type-R Suede red stitch boot|Gunmetal Type-R knob|
|Intake Resonator Delete|Hyper White led license plate led|led interior bulbs|Smoked Reverse lights|
Previous owned
-97 Acura 2.2CL auto/Flamenco Black
Old 07-27-2008, 06:52 PM
Takumi's Avatar
Takumi Takumi is offline
I love vtec!
I would say if you are going with Manual then V6 is for you, if Automatic then I4.
Old 07-27-2008, 06:53 PM
NOPE!!!
By default it is on on every start up.. to turn it off you have to push the button for 3 seconds.. it will then turn off and then the light on the dash will illuminate letting you know hey vsa is off... if vsa is on you are losing power cant spin your wheels, and you have braking assistance.. LOL did your eyes just get opened to something? lol
Team Soundstream
Mods:
Greddy Exhaust TiC
NAV TV integration
Audison Bit One
Old 07-27-2008, 06:56 PM
25K OTD for an EXL V6? On what planet? and there is no ex V6 v6 only comes with leather package which starts at approximately 26795.00 msrp and goes up from there depending on tranny navigation and of course v-6 and accessories...
Team Soundstream
Mods:
Greddy Exhaust TiC
NAV TV integration
Audison Bit One
Old 07-27-2008, 07:13 PM
AznX TL's Avatar
need 6 speed!
Originally Posted by JamieJam1AIM View Post
NOPE!!!
no, according to the owners manual its pretty much traction control. when you spin your tires it will activate vsa, but if you don't its idle but will turn on if you spin your wheels. but if you turn it off it isn't even idle anymore so if you spin your wheels, you keep spinning your wheels.
but it also says when it activates while spinning your wheels and vsa activates it will show the ! illuminated similar to when you turn off vsa.
mods
Previous owned
Old 07-27-2008, 07:18 PM
jeffreyhuhn's Avatar
jeffreyhuhn jeffreyhuhn is offline
Lock it up
Sure there is. You can get an EX v6 sedan.
08 Accord Sedan EX-L V6
Polished Metal
Black Leather
93 Accord SE Coupe 212K
_____________________________
Previously owned
1980 Accord 3 door 5 speed
1999 Buick Regal GSE Supercharged
2000 Audi A4 Quattro 5 Speed
2000 Cadillac STS N*
Old 07-27-2008, 07:20 PM
Lock it up
I think this is correct also.
Polished Metal
Black Leather
Previously owned
