Wheel Torque specs (8th gen) - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Wheels & Tires
Old 08-01-2008, 09:31 AM
Naut2Bad's Avatar
Naut2Bad Naut2Bad is offline
Octalever
I have a 2008 Accord EX-L with 17 inch alluminum wheels, Can anybody tell me what Honda recomends to torque the lug nuts to when rotating the wheels?
2008 Accord Coupe EX-L I4
Polished Metal Metalic,
Ivory Interior (TAN),
32% Window Tint,
Splash Guards,
K&N AirFilter.
Old 08-01-2008, 10:13 AM
Aviography's Avatar
Not sure what Honda recommends off top of my head, but typically mag wheels are torqued to around 80 ft-lb, you should be safe with numbers around that range, and be consistent to even out the loading across all 5 lugs.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 08-01-2008, 11:02 AM
frenzal's Avatar
frenzal frenzal is offline
4th Gear
On 7th gen, it is 80lb-ft.
I've torqued the nuts on almost all my cars to that value and never had a problem!
Car: Honda Accord coupe 2005 V6 6-speed saphire blue
Old 08-01-2008, 08:34 PM
reframmellator's Avatar
reframmellator reframmellator is offline
Moderator
It's in the owner's manual and it is indeed 80 ft-lbs for Gen 7 (and I think 5 and 6 as well).
One nifty feature of Sven, our 93 Volvo, is that the spindle nut cover is imprinted with "63 ft-lbs"
Those wacky Swedes. . . .
"Communication isn't what you say. It's what they hear." - Red Auerbach
2007 SE I4 5AT, Cool Blue, 67k
2004 EX I4 5MT, Desert Mist, 160k
Also in the family:
2009 TSX, navy, auto
2011 TSX, black, M6 Tech
2012 Crosstour V6, black
2013 Civic EX, gray
2014 Honda HRX217 (2)
Departed:
2001 Accord EX I4 5MT, Satin Silver, oil slick at 86K
1999 EX-LV, Heather Mist, sold at 146,567
1994 Accord LX I4 5 MT ABS, Malachite Green, traded at 285k
Old 08-10-2008, 03:34 PM
Speedway's Avatar
Speedway Speedway is offline
Can someone please tell me what section this info is under in the manual? I cant seem to find it. Thanks
2008 Honda Accord Sedan EX-L With Navigation
Polished Metal Metalic / Grey Leather
2.4L Automatic
35% Tint - Solar Gard - Supreme
Remote Start - OEM
Wing Spoiler - OEM
Side Body Molding - OEM
Splash Gaurds - OEM
Wheel Locks - OEM
Old 08-10-2008, 04:01 PM
AgentWashington's Avatar
AgentWashington AgentWashington is offline
5th Gear
The torque spec for the 8th gen is 80-ft/lb, I'm pretty sure it's under the "replacing/changing tire" section, whichever that one is, I know I found it in there somewhere.
2008 RBP Honda Accord Sedan LX-P, 5AT
Mods
OEM: Wing Spoiler, Side Molding, Splash Guards, V6 front bumper with coupe fog light covers
Non-OEM: Toshiba HIR Lows, Chrome Door Pillars, Blue LED interior lights, White LED trunk and plate lights, Autozone chrome grille, lower bumper, and trunk trim, V-LEDs tail/brake light LED bulbs
Old 08-10-2008, 04:50 PM
Speedway's Avatar
ok thanks a lot!!
2.4L Automatic
Remote Start - OEM
Wing Spoiler - OEM
Splash Gaurds - OEM
Wheel Locks - OEM
