Ok, brakes squealing now? :furious: - Page 14 - Drive Accord Honda Forums
  #196
Old 06-03-2009, 10:01 AM
Edaccord08 Edaccord08 is offline
Out of Control
The ABS/VSA unit is listed as rewritable, just like ECU so maybe they could do firmware update to alter bias if that is a available option if its to much to the rear.
Whats odd to me is such a big range of mileage that pads last, some 11K to 30k pretty big range
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
  #197
Old 06-03-2009, 10:09 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
I was told that Honda is working on altering the computer chip to change the 80% rear brake useage to a more even application.
- It is just a car -
2005 Accord Sedan EX-L AT
2009 Accord Coupe 6/6 Black
  #198
Old 06-03-2009, 10:13 AM
lpaudio2 lpaudio2 is offline
5th Gear
what I did with my 7th gen brake issues (different issue) was asked the dealer to pickup labor, and install my pads.... Some dealers say no to 3rd party. Mine was fine with it.
2006 AV6 6sp
  #199
Old 06-03-2009, 10:17 AM
Kayzle's Avatar
Kayzle Kayzle is offline
(_8^(])
Do 09 coupes have this brake problem?
09 Accord Coupe LX-S I4 Auto
Crystal Black Pearl
OEM:
Trunk Tray, Mud Flaps,
Wheel locks, Factory 35% tint
Mods:
De-badged
35W 5000k Raptor Slim HID kit (DDM Tuning)
95mm White Angel Eye CCFL rings (Retro Solutions)
Painted interior headlight housing
Type2 Color Changing LED turn signal bulbs (V-LEDS)
Odyssey lower grill mod (Made by denttarek)
Black out top grill
09 TSX Switchblade Key
$368 total spent to date
  #200
Old 06-03-2009, 10:24 AM
denttarek's Avatar
denttarek denttarek is offline
08 Acc Coupe/Auto/Nav/BBP
i would think so ,there is no evidence that there is any differences between an 08 and 09 models at all
  #201
Old 06-03-2009, 10:26 AM
Kayzle's Avatar
(_8^(])
Originally Posted by chris.mcconathy View Post
A new Service bulliten has just been put out about the rear brakes on 08 accord's, mine is a coupe so i don't know about 4 doors.
If you have 12k miles or less the Honda is paying for your rear brake pads and installation if they wear out.
12-24k miles they will pay for half of the replacement and installation cost.
So basically have your pads checked if you still have less that 12k miles and get them replaced now if are less than a couple mm's left. I just had mine replaced today at 18,800 miles and it cost me about $91. The pads themself will run you 76 buck if you use OEM from dealer if Honda wasn't helpng us out. My understanding is that they are looking to into the problem to see what kind of actions are going to be taken for a recall, if any?
would they do this for 09's also?
Crystal Black Pearl
OEM:
Mods:
De-badged
Black out top grill
  #202
Old 06-03-2009, 10:38 AM
einy einy is offline
2nd Gear
As another poster in this thread noted on his '09, my '09 has also had squealing brakes since it hit 500 miles, primarily (but not exclusively) from the rear brakes. In my case, the squealing noise is only under light brake pedal pressure, and goes away when you put more "foot into it", so to speak. Also, it doesn't always happen ... even under otherwise identical conditions. I took all of the pads out to inspect, and all looked fine. I sprayed the backs of the pad (after taking off the shims and de-greasing them) with "disk brake quiet", put the shims back on, de-glazed both pads and rotors, and re-assembled. 3000 miles later, the fronts are quiet, but the rears are once again squealing. Time permitting, I'll look at the rears again this weekend, to see if unusual wear has begun to show itself. I have seen alot of brake dust on the rears, a bit more that on the fronts in fact, so I suspect that the ABS/VSA/EBD system is putting more pressure towards the rear of the car - possibly as a stability enhancing technique ???? In addition, I am a frequent "parking brake user" (my '09 has the manual transmission in it), and based on that, as well as from my experience with an identically equipped '01 Accord that preceded the current '09, to see the inside rear pads wear out first, as the parking brake is actuated by mechanically "kicking over" the rear calipers, putting the inside rear pad in contact with the brake rotor. It would be interesting to know how many of us out there who have experienced rapid rear pad wear, particularly the inside pad, are parking brake users ....
  #203
Old 06-03-2009, 10:52 AM
Kayzle's Avatar
(_8^(])
I just hit 1,500 on my 09 no problems, but I'm scared of the future
Crystal Black Pearl
OEM:
Mods:
De-badged
Black out top grill
  #204
Old 06-03-2009, 10:57 AM
Drowzee Drowzee is offline
4th Gear
If there truly is a TSB out for the rear brakes, can anyone locate the #?
08 NBP Accord Coupe EX-L I4
4300k HIDs from XenonDepot
OEM foglights w/ 3000k HIDs from Retro-Solutions
35% tint all around
  #205
Old 06-03-2009, 11:07 AM
MySilver_08 MySilver_08 is offline
banned
If you can't locate the number, what makes you think any of the rest of us can?
  #206
Old 06-03-2009, 11:30 AM
damadazkikr's Avatar
damadazkikr damadazkikr is offline
4th Gear
Send a message via AIM to damadazkikr
i made an appointment on friday with honda to see why my brakes are squealing. it would be nice if i had the tsb # for this as well
2008 Accord Coupe EX-L, Taffeta White
i4, 5 Speed MT
Tints: sides 20%, rear 5%
Debadged "Accord"
No DRL's
6000k 55w Retro-solutions HIDs
Coming Soon (Hopefully):
Exhaust (if there is ever one made for the i4)
SRI/CAI
Angel Eyes
Eibach Lowering Springs
OEM Decklid Spoiler
  #207
Old 06-03-2009, 11:49 AM
shogun's Avatar
shogun shogun is offline
Manong
Has anybody PM'd "Princess"? She should be able to verify if a TSB is out or in the making.
Mine: 08 BBP EX-L Coupe w/Navi Hers: 06 Atomic Blue Civic Coupe w/NAVI
No ticky, no washee
  #208
Old 06-03-2009, 11:55 AM
YRMed YRMed is offline
Leased a VW_My life ****s
In my experience, they are squealing because the shims between the back of the brake pad and the caliper are experiencing a metal on metal contact because the grease in between them evaporated from heat.
In my application, after I greased up the areas where shims touch the brake pad/calipers, the noise went away.
FYI, the front inner pads have 2 shims, and there is definite metal on metal contact there. Upon inspection you will notice that there is very minimal amount of lubricant left. At least for me there was no lubricant left and I am at 8k miles.
'12 VW Jetta 2.5/5spd lease - WORST decision ever
'11 Infiniti G37x - Sold
'09 TW 6-6 - Sold 1/1/2011
  #209
Old 06-03-2009, 12:38 PM
abhi abhi is offline
3rd Gear
At what mm width they will replace it for free? I mean does it has to be less than specific width(mm) in order to get them replace under TSB?
Mine is 10800 miles 08 sedan.
  #210
Old 06-03-2009, 03:27 PM
08_SilverCoupe 08_SilverCoupe is offline
First off thanks, Chris.McConathy for posting about the service bulliten. I have just started hearing my rear brakes go bad, the sad thing is that im only at 23k. Hopefully I can swing by the dealer tomorrow and get them to do something about it.
Tags
08 accord exl v6 w/nav, brakes
