Ignition trouble. Main relay? (Gen6) - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 08-28-2008, 10:39 AM
RUprincess05 RUprincess05 is offline
Honda Owner
Unhappy Ignition trouble. Main relay? (Gen6)
I've got a 2000 Accord EX Coupe and I just recently started having trouble starting my car. When I turn the key, it just clicks. This usually happens when the car has been sitting in the sun all day and it's hot inside the car. My boyfriend did some research and found that it might be the main ignition relay. He also found that with most Acura's and Honda's around the same year mine is, this problem with the main ignition relay happens a lot. There's a brown fuse-looking thing under the dash where the foot pedals are and when I tap on it while turning the key, it will start. Any ideas what this problem is?
Old 08-28-2008, 10:42 AM
cforez's Avatar
cforez cforez is offline
3rd Gear
I had the same problem as you, and it was the main relay.
Old 08-28-2008, 10:46 AM
Honda Owner
When I told a mechanic it was the Main Relay, he didn't know what i was talking about. What is the actual name of the part? Ignition main relay?
Old 08-28-2008, 10:55 AM
cforez's Avatar
3rd Gear
PGM-FI main relay.
http://www.driveaccord.net/forums/sh...ght=main+relay
Old 08-28-2008, 11:13 AM
Honda Owner
Thanks. If i were to replace it, is that the only part? or is there more under the hood i'd have to replace?
Old 08-28-2008, 11:32 AM
cforez's Avatar
3rd Gear
The relay is all you need to replace.
Old 08-29-2008, 08:14 AM
SatinSilver's Avatar
Moderator
Wasn't this covered under the ignition recall? Plug your vin into Honda's website under owner's link to find out. Save some $$$ too.
Old 08-29-2008, 12:57 PM
Honda Owner
Nope, SatinSilver. I just checked it. It's the Ignition switch. Here's the actual recall...
"2000 HONDA ACCORD Recall ID from NHTSA: 05V025000
Auto Recall Date: JAN 28, 2005
Vehicle Component: ELECTRICAL SYSTEM:IGNITION:SWITCH
Model Affected ACCORD
Estimated Vehicles Affected: 486659 Recall Details
Model Affected
2000 HONDA ACCORD
2000 Honda Accord Defect Summary:
ON CERTAIN PASSENGER VEHICLES, THE INTERLOCK OPERATION OF THE IGNITION SWITCH MAY NOT FUNCTION PROPERLY, MAKING IT POSSIBLE TO TURN THE IGNITION KEY TO THE "OFF" POSITION AND REMOVE THE KEY WITHOUT SHIFTING THE TRANSMISSION TO PARK.
Defect Consequence:
IF THE DRIVER DOES NOT SHIFT TO PARK BEFORE REMOVING THE KEY AND FAILS TO ENGAGE THE PARKING BRAKE, THE VEHICLE COULD ROLL AND A CRASH COULD OCCUR.
Remedy:
DEALERS WILL PERFORM AN INSPECTION PROCEDURE THAT CONFIRMS INTERLOCK FUNCTION. VEHICLES WILL BE UPDATED WITH A REDESIGNED INTERLOCK LEVER FREE OF CHARGE. THE RECALL BEGAN ON MARCH 7, 2005. OWNERS MAY CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Notes: HONDA (AMERICAN HONDA MOTOR CO.) P68, P69 "
Old 08-29-2008, 02:13 PM
Bowzer's Avatar
Bowzer Bowzer is offline
Many Accords...Many Miles
THat's not the one I think SS was referring to. There is a recall on the ignition where the engine will just cut off without warning. Then it will restart normally shortly afterward.
I'm not convinced from what you describe this would be the problem but it might be worth a look. I'll see if I can dig up the recall...it's on this forum in a couple of threads.
99 Accord EX Sedan 4 cyl, Black, 187K+ miles semi-retired
92 Accord LX Coupe 4 cyl, Charcoal Gray, Sold 187K miles
85 Accord LX HBack 4 cyl, Dark Gray, Sold with 198K miles
84 Accord LX HBack 4 cyl, Dark Gray, Totaled with 18K miles
08 Honda Element EX 4WD, Silver, 104k Miles
01 Isuzu Trooper 4wd V6, Gray, Traded at 125k miles
94 Jeep Grand Cherokee 4wd Ltd, V8, Taupe, Sold 148K miles
75 Jeep CJ5 4x4, Straight 6, White, Sold with ? miles
Old 09-02-2008, 11:56 AM
Honda Owner
Smile
Thanks Bowzer.
Title goes here
close
video goes here
