Dead battery or some other electrical problem? - Drive Accord Honda Forums
Old 08-31-2008, 06:20 AM
Deific Deific is offline
ALL for AGI!
I went to play some golf this morning. Had no trouble starting the car or driving it the 10 miles to play golf. When I went to leave it wouldn't start, wouldn't make any noise other than my Sirius turned on. Luckily I was with my friend who jumped me, we drove to Dunkin Donuts and because he was with me I figured he could jump me again if necessary. After 5 minutes in DD the car wouldn't make a noise and I couldn't get in using the unlock button on the key. He jumped me again and it started up but I had to stay on the gas to keep it going. The CEL and the ABS light would randomly come on then go off. When I got off the exit ramp the CEL came on and stayed on. When I went to pull into my driveway the car died and I was able to drop the clutch and keep it going to get into my driveway.
When I attempt to honk the horn all it does is sort of whine or groan.
When I put my headlights on they do not come on.
Is this a dead battery which I can easily replace or is it a more serious electrical issue.
I am borrowing my FIL's OBD reader today so I will try to get some code out of the car.
I have had the car for almost 3.5 years and it has 55,000 miles on it.
Thank you in advance for your help.
2005 Honda Accord LX
Manchester Honda, CT.
Lowest MPG 29 (first week)
Highest MPG 35.**
Last Accord 88 LX 270,000 miles
Old 08-31-2008, 06:33 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
I bet a dollar to a doughnut you need a new battery.
Old 08-31-2008, 06:55 AM
npolite's Avatar
npolite npolite is offline
5th Gear
If you want a quick way to reset it, pull the negative battery for 30 seconds and re-connect.
2007 TSX - Auto - 66k miles - Non Nav - CGP - Mine
2009 Altima 2.5 SL - 91k miles - Auto - Sister's
1999 Accord LX Sedan - Auto - 103k miles Dad's
2012 Camry LE - Auto - 4k miles Mom's
1995 Integra LS Sedan - Auto - 119k Sold 3/6/2008 Was Mine
2008 Accord EX Sedan - Auto - 37k miles Sister's Sold 6/20/2009
1995 Accord DX Sedan - Auto - 138k miles Dad's sold
Old 08-31-2008, 08:33 AM
ALL for AGI!
Reset what? The battery or the CEL?
Highest MPG 35.**
Old 08-31-2008, 09:08 AM
npolite's Avatar
5th Gear
Sorry something must have happened to the topic I was responding to. Please ignore it.
Old 08-31-2008, 11:38 AM
91EX 91EX is offline
Go Tigers!
Dead battery. You could get it tested. I've had the same problem before. Car started and ran fine, out of the blue, not able to start, but able to be jumped and run. Mine was covered under warranty as the battery was only two years old.
Get this checked out before you toast the alternator.
91 Accord EX AT
Old 08-31-2008, 02:29 PM
mpumas mpumas is offline
3rd Gear
Or it could be the battery cable connection to the battery. A simple/cheap voltage meter will tell you.
Old 09-01-2008, 07:15 AM
ALL for AGI!
By continuing to jump the car it will kill the alternator?
Highest MPG 35.**
Old 09-01-2008, 11:07 AM
ALL for AGI!
I pulled the code it was P0685 ECM/PCM Power Relay Control Circuit Malfunction. Brought the battery down to Advanced Auto Parts and tested it and it needed to be replaced. So I replaced it was a 500 CCA version. I just put it in and the car started up fine. Thanks for everyones help.
Highest MPG 35.**
Old 09-04-2008, 12:29 PM
Go Tigers!
Continuing to run a car on a dead battery will stress your alternator. It is trying to keep a battery at full charge when it is unable to keep it.
91 Accord EX AT
Old 09-13-2008, 04:34 PM
dpobster dpobster is offline
I had the same thing happened to my o3 accord, replaced battery and never had a problem since... knock on the wood.
Old 09-22-2008, 10:01 AM
ricallen's Avatar
ricallen ricallen is offline
Brianna's daddy...
I had the same thing happen over the weekend. I just dropped it off at the dealership this morning. I was assuming that the alternator had gone bad. Now I am hopeful that it too is just the battery!
Ric
2003 Accord EX-L NAV (Redondo Red Pearl) w/OEM spoiler; gold package; 5% tint
Old 09-22-2008, 10:43 AM
RTexasF's Avatar
If you got five years out of an OEM battery that is exceptional.....seems like three years is about it.
Old 09-22-2008, 05:56 PM
ricallen's Avatar
Brianna's daddy...
UPDATE: This thread was absolutely right on! Turns out my problem, whose symptoms were identical to the OP, was exactly the same: bad battery. All is running great now with this simple fix!
Ric
Old 11-14-2013, 05:52 AM
mangpo8 mangpo8 is offline
Hi I have a dead battery few days ago. now changed to a new one. But the multi display on my accord which shows how many KM left for the fuel in my tank is just showing 2 km but the fuel gauge is more than half ( car battery died at petrol staion after a refuel.) I just refuel about $10 more and now the display reads 22KM. WTF? please help. Cheers
