Figured I'd share my experience with installing these headlights
You'll need these parts:
'14 V6 Headlights Left:33150-T2A-A21 (Got it used on eBay for $120)
'14 V6 Headlights Right:33100-T2A-A21 (Got it new for $236 shipped from Boch Honda)
Pig tail wires: 04320-SAA-A00 ($7.10 from Hondapartsunlimited + shipping)
3P Connector: 04321-S0X-305 ($4.17 from Hondapartsunlimited + shipping)
Total cost for the above was right under $400
Good references:
http://www.driveaccord.net/forums/showthread.php?t=175834
http://www.driveaccord.net/forums/showthread.php?t=87497
1) Bumper removal - NO need to remove push pins from bottom of the car except for two along the wheel well. Pretty simple. Remove screw on each side and push pin on wheel well and one right below the wheel well. Remove 6 push pins from the front.
2) Headlights - hardest part is to reach the screw that is about 6" deep into the bracket. Remove the 4 screws and the one push pin per headlight.
3) Wiring - This is how I'm wiring it but you can do it however. I'm wiring it up to the T10 socket for dim so it turns up like stock. I'll be wiring the "bright" wire later and will update this DIY along the way.
Good references:
