scratch remover - Drive Accord Honda Forums
Old 03-17-2005, 01:30 PM
jakes29's Avatar
jakes29 jakes29 is offline
3rd Gear
scratch remover
Let me get someones opinion on the best scratch remover for dark colored vehicles(my accord is dark green). I have quite a few light to medium light scratches on hood and other areas. I will be using a dewalt rotary buffer. Any advice?
I have been snooping around autopia.org. They recommend SSR by Poorboys.
2000 Accord EX
206k miles
I4 Auto All Stock
Original Transmission
Old 03-17-2005, 02:13 PM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
Inspector 1 - Your phone is ringing, this is right up your alley & I'd like to know too.
Old 03-17-2005, 02:16 PM
RTexasF's Avatar
This one is highly recommended but they specify hand application/removal.
Old 03-18-2005, 05:50 AM
Pairallel's Avatar
Pairallel Pairallel is offline
5th Gear
I've used the Meguiar's Scratch-X, and I was not impressed. I honestly did not see one scratch disappear with it...
'13 Accord EXL V6 (new)
'09 Pilot EX-L (38k miles)
'07 CR-V LX (71k miles)
'11 CR-V SE (14k miles)
Old 03-18-2005, 06:07 AM
RTexasF's Avatar
Bummer!
Old 03-18-2005, 07:41 AM
jakes29's Avatar
3rd Gear
I don't think a lot of the products you can buy at walmart will be very good. I know someone on here has some answers for us...
2000 Accord EX
206k miles
I4 Auto All Stock
Old 03-18-2005, 01:09 PM
Inspector1's Avatar
Inspector1 Inspector1 is offline
O do u know the buffinman
Yes Scratch X is for hand use only.
With a rotary you will need #83 DACP Megs or Finesse-it line 3M if buying locally(At autoparts stores= NAPA/Carquest).
What type of pad are you using on the rotary?
I really like the Poorboys World SSR2.5 I have and am also happy with Menzerna products also.
The key is to start with the least abrasive product and work slowly.
Clean the surface with 50/50 Alcohol/Water and check to see if defects are removed. You want to remove the least amount of clear as possible!!
You may have to use different products and/or pads to get the finish you want.
I1
"Any man who thinks he can be happy and prosperous by letting the government take care of him better take a closer look at the American Indian."
- Henry Ford
4 Honda family...
08 EXL V6 W/Nav PMM 4Dr @ 93K miles
My daily driver
08 Pilot EX-L Dark Cherry Pearl @ 42K miles
The Mrs. daily driver
The Kids
02 EXV6 Naples Gold 4Dr @224K (Trans refresh @156K)
06 EXL I4 CBP 4Dr @ 82K Acquired 3/2013
DA RULES !`
Old 03-18-2005, 02:27 PM
jakes29's Avatar
3rd Gear
I1, I knew you would come through with an answer.
I have done some research and I think this will be my plan of attack:
wash
clay
SSR1 or 2.5
Ex
Nattys
I will probably start with a polishing pad with ssr1 then maybe a cutting pad and then if that doesnt work a polishing pad with 2.5.
How does that sound? I have never heard of the alcohol cleaning you mentioned? Would I still need to do this if I clay first?
Thanks as always
2000 Accord EX
206k miles
I4 Auto All Stock
Old 03-18-2005, 03:03 PM
tallgood tallgood is offline
Honda Lover
There are no scratch removers
Old 03-18-2005, 04:03 PM
Inspector1's Avatar
You are correct when it comes to base coat, but clear coat swirls and fine scratches can be leveled out(basically removed)with the correct procedure.
I1
- Henry Ford
4 Honda family...
My daily driver
The Kids
DA RULES !`
Old 03-18-2005, 04:04 PM
jakes29's Avatar
3rd Gear
meaning???
2000 Accord EX
206k miles
I4 Auto All Stock
Old 03-18-2005, 06:30 PM
BenjiBoy650's Avatar
Originally Posted by jakes29
meaning???
Deeper scratches are basically paint that was removed. Thus to remove a real deep scratch, you'd need to go and put the paint back on, which you'll have a hard time doing with any buffer or "scratch remover" product off the shelf.
Are they really scratches? There is a lot of stuff on the car that can be removed by Goof Off.
Old 03-19-2005, 05:23 AM
Honda Lover
Scratches can not be removed with something in a bottle other than paint. Scratch removers may moisturize the paint for a while just long enough to hide them but they come back and that is on a silver or white, or in my case Heather Mist or Sand Stone. Dark colored cars are tough to take care of. White or something the same color as dirt are fine for me.
Old 03-19-2005, 05:59 AM
Inspector1's Avatar
Like I said scratches in base coat(base coat/clear coat) have to be filled back in with paint. Swirls and fine scratches can be removed with compounds designed to remove(The Moisturizer thing you are speaking of are polish's with " Fillers" that in essence fill the voids with oils that make the scratches and swirls seem to disappear) Abrasive compounds take off layers of the clear and level the clear making the surface smooth again (just like sanding a piece of wood)!! But you have to remember you are only dealing with the max thickness of 2-3mil of clear!!
Color of the vehicle has nothing to do with the scratches other than making them harder to see on lighter colors. Scale White to Black
I can spot marks on any color vehicle under proper lighting!!
I1
- Henry Ford
4 Honda family...
My daily driver
The Kids
DA RULES !`
Old 03-19-2005, 03:20 PM
Honda Lover
[QUOTE=Inspector1]Like I said scratches in base coat(base coat/clear coat) have to be filled back in with paint. Swirls and fine scratches can be removed with compounds designed to remove(The Moisturizer thing you are speaking of are polish's with " Fillers" that in essence fill the voids with oils that make the scratches and swirls seem to disappear) Abrasive compounds take off layers of the clear and level the clear making the surface smooth again (just like sanding a piece of wood)!! But you have to remember you are only dealing with the max thickness of 2-3mil of clear!!
I1 [/QUOTE
Thats my whole point, lighter colored cars hide the blemishes better. You
are talking more tech terms but I think we are on the same page. And yes if you go over a car with a spot light you will find everthing.
99 Accord LX
05 Accord EX
01 Civic LX
2013 CR-V EX-L
