Is the front sway bar necessary? - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 09-19-2008, 01:30 AM
kroze kroze is offline
2nd Gear
I just got an 06 Accord LX Coupe 4cylinders (5speed) and just wanted to know whether replacing the front sway bar is necessary?
I only see people here replacing the rear sway bar from the Acura TL but non mentioned the front sway bar. Is the stock adequate? I hear that it's 25mm and it's a solid metal bar right?
Old 09-19-2008, 03:25 AM
The Pope's Avatar
The Pope The Pope is offline
Just another old guy ....
If you go with the 17mm rear swaybar IMHO you don't need to replace the front. If you want to go with the 20mm rear swaybar, I'd suggest replacing the front as well.
just my .02
The Pope
...... riding off into the sunset like in those old western movies.....
My youngest son, RIP 10/3/2004 (He was 19 at the time)
My mom, RIP 4/6/2011
Forum Rules: http://www.driveaccord.net/forums/sh...ad.php?t=19181
Old 09-19-2008, 04:42 AM
frenzal's Avatar
frenzal frenzal is offline
4th Gear
I have the TL-S rear 20mm sway and the TL-S front 27.2mm and it is worth it. A dramatic improve in handling!
Car: Honda Accord coupe 2005 V6 6-speed saphire blue
Old 09-19-2008, 04:46 AM
psyshack's Avatar
psyshack psyshack is offline
Out of Control
Replacing just the front sway bar will make your Accord happy in really tight turns. Like Auto Xing it. It will point and shoot out of really tight corners at lower speeds better. But it could also make it pick up a inside rear wheel faster.
09 HCHII,w/Navi,I4,CVT Crap,Atomic Blue/Beige,70k Miles (Dull/MPG/Quite Civic)
07 Mazda3 S Touring,I4,5MT,Purple/Charcoal,80k Miles (Civic What?)
00 Ranger Ext,XLT,I4,5MT,White/Gray,200k Miles (Thinks it's a F-150)
X, 05 Accord EX Sedan,I4,5AT,Red/Gray,89k Miles (My Fav. Accord Gen)
X, 06 Civic EX Sedan,w/Navi,I4,5MT,Silver/Gray,44k Miles (No Better Than GM Junk)
Can you save a gal. here and there then blow a half gallon playing with the tach? It can be done!
Old 09-19-2008, 05:04 AM
2nd Gear
For the rear sway bar, I needed these:
20mm bar parts needed:
1 of 52300-SEP-A11
2 of 52306-SEP-A11 (Stabilizer holder)
2 of 52308-S3M-A00 (Stabilizer bushing)
Do you guys have all the part numbers for the front 27.5mm sway bars?
Will I need the stabilizer bushing & holder for the front also? What about the bolts or can I reuse my old one?
Old 09-19-2008, 06:04 AM
2014MSM's Avatar
2014MSM 2014MSM is offline
4th Gear
I would definitely recommend doing the front sway bar as well. I think the main reason most people don't do the front is due to the fact that it's a lot more difficult to replace than the rear. I don't have the part number for the front, but you will only need the sway bar and bushings. You can reuse your bushing brackets and bolts.
Old 09-19-2008, 01:08 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
doing just the front bar will increase the inherent understeer Honda already engineers into the Accord chassis. The car will seem to corner flatter, but it will overwork the front tires and in hard maneuvers it will push.
As stated in other replies, if you go with the standard TL rear bar you'll slightly reduce the understeer. If you go with the 20mm rear bar, you'll have a very good chance of snap oversteer, especially in fast side to side movements.
If you put in the biggest TL rear bar, you really should put in the 27.2 front, I went with the hollow bar to get some weight off the front end. I also had to put Ingalls camber correctors in the rear. My car has the HFP suspension and the extreme negative camber on the rear tires already had the rear end destablized. I had the alignment, set at half tank of fuel, to -.9 degrees camber, and 3 mm total toe-in. I wanted to ensure no snap oversteer with the ever so slight increase in total toe-in.
Old 09-19-2008, 03:18 PM
sjlee's Avatar
sjlee sjlee is offline
6th Gear
First off, replacing the stock sway bars isn't "necessary". People do it to improve the handling of the car.
That being said, The Pope has good advice.
2007 Honda Accord EX-L V6 AT 4DR (Alabaster Silver Metallic) - splash guards, wheel locks, OEM foglights, GROM adapter
2005 Honda Pilot EX-L (Desert Rock Metallic) - splash guards, wheel locks, crossbars, side steps, towing package
1995 Yamaha FZR600 - sold
2001 Chevrolet Cavalier LS sedan (silver) - sold
1996 Acura Integra GS-R sedan (Black Currant Pearl) - sold
1995 Suzuki Katana 600 (teal) - totalled; sold
1984 Chevrolet Celebrity (brown) - first car; sold
Old 09-21-2008, 02:05 PM
The Pope's Avatar
Look here for more info:
http://www.driveaccord.net/forums/sh...hlight=swaybar
and
http://www.acuraautomotiveparts.org/...s=&view=normal
and here's some instructions:
http://www.driveaccord.net/forums/showthread.php?t=6568
and
http://www.neuspeed.com/products/pro...port&p_id=1789 (click on the 'How to install" button in the upper right cornsr of the page)
Also the 2006 TL-S is hollow and the 2007 TL-S is solid.
2k6 front p/n 51300-SEP-A01
2k7 front p/n 51300-SEP-A21
The Pope
Old 09-21-2008, 05:31 PM
Trip's Avatar
Trip Trip is offline
Yep yep . . . Pope knows his stuff. His Accord has some great mods.
Be careful . . . if your car is unbalanced, even at parking lots speeds, this could happen . . .
(just joking, but I thought it was a good place to share this vid )
http://www.youtube.com/watch?v=7RMLt28n0-M
Current: 2009 Mazda 6 iGT 6MT, 1989 Prelude Si 5MT
Come & Gone: 84 Accord HB, 91 CRX Si, 89 Accord LXi, 90 Accord LX Cpe, 94 Accord EX, 95 Accord EX Cpe, 98 Accord EX, 99 A4, 03 Accord EX-L, 91 Civic RT4WD Wagon, 06 Accord EX-L NAVI
From The Dark Period: 01.5 Passat, 08 Accord 6-6
DA MOD TEAM
Old 09-21-2008, 06:02 PM
Cleankill's Avatar
Cleankill Cleankill is offline
4th Gear
Replacing the front sway bar is not necessary.
Please correct me if i am wrong: I think the front sway bar is 25.4 mm hollow. I4 get a 14mm, but i think it is hollow.
v6 get a 13mm solid rear sway because i cut it.
i put 20mm solid rear sway for almost a month, i have not experienced any oversteer yet (VSA has not kick in either). Maybe due to a really nose-heavy model (V6 auto). Light understeer still accompanies with you though.
Yep, i avoid the front sway bar because of the complication and need a realignment after.
If other people say it is easy to get oversteer on I4 with 20mm rear, i would avoid it because I4 does not have VSA.
Old 10-09-2008, 10:34 AM
cyph3r86 cyph3r86 is offline
3rd Gear
this is for the 8th gen coupe right?
2008 NHB V6 6spd Coupe
Modifications: debadged, S2000 CR shift knob, Digital HIDs lo-beam 6000K, 2500k luminics fog lights, radiator mesh grille
Old 10-09-2008, 10:53 AM
sjlee's Avatar
6th Gear
Probably not... considering this is in the 7th gen forum.
Old 09-19-2010, 07:36 AM
geesedude's Avatar
geesedude geesedude is offline
Only What I Can Accord
Does anyone know if there's a TL/CL swap for the front strut bars? I've read that a CL bar (74180-S0K-A00) can work on a 6th gen, but haven't been able to find anything on a 7th gen...
Old 09-19-2010, 07:44 AM
Aviography's Avatar
Just get an Accord V-6 6-speed front strut bar, it's guaranteed to fit.
TL shift knob, Hidden Hitch,
DA Moderator Team
Title goes here
close
video goes here
