Check Fuel Cap Warning Message - Drive Accord Honda Forums
Old 09-23-2008, 11:34 AM
next_milenium's Avatar
next_milenium next_milenium is offline
08 Accord V6 Coupe w/ NAV
Question Check Fuel Cap Warning Message
My car just started to flash "check fuel cap" message on the little window where outside temperature is displayed. I thought maybe it was loose. But when I checked it, it was tight. I opened it and closed it again with several clicks to just make sure hoping the message would go away. No such luck. It's still flashing the warning.
Has anyone had this issue before?
08 Accord V6 Coupe Auto NAV PMM/Black
Haves:
20% Tint / 55W 5K HID / Debadged / Rebadged with HFP Emblems / No DRLs / 7th Gen Coupe Headrests / Oddyssey Lower Grill / 20" Privat Vulkans 20x8.5 45 ET / 245 35 20 Nitto Extreme ZR 555's / HFP Suspension / TSX RSB / Magnaflow CBE / Crosstour Shifter / Xpel Fog Light Film
Wants:
Rearview Camera / Hacked Navi
Previous Rides:
2000 CLK 320
1995 3000GT
1988 Supra Turbo
1982 Supra
1985 Accord
Old 09-23-2008, 11:45 AM
Mase764's Avatar
Mase764 Mase764 is offline
~Sexy Time~
Send a message via AIM to Mase764
it will go away.. give it like 2 days.. happened to many members here
*Steve*
08' Belize Blue Pearl 2 Door Coupe V6!
http://www.cardomain.com/ride/3098044
15 % Tints
TSX Switch Blade
Blue LED installed in interior
OEM Interior Illumination
Tein SS Coilovers Installed
Rear Sway Bar Installed
T rex Billet Grille Installed
Tailight tints (waiting to be installed)
V-LEDS Type2 Color Changing LED turn signal bulbs 6k (Selling Since I bought 8k HID's)
Old 09-23-2008, 11:47 AM
Thanks, I'll wait and see.
Hope this isn't a recurring problem.
Haves:
Wants:
Previous Rides:
2000 CLK 320
1995 3000GT
1988 Supra Turbo
1982 Supra
1985 Accord
Old 09-23-2008, 04:13 PM
mhadden's Avatar
mhadden mhadden is offline
On hiatus...
A lot of times it'll go out after a little bit of driving or a couple of starts.
If its still flashing, then you might have a faulty gas cap or a bad purge valve (seen these problems on my old Mazda3).
2011 Pilot EX-L AWD
2010 Corolla LE
2008 Goldwing Navi
Old 09-23-2008, 04:18 PM
taffwh2008sedan taffwh2008sedan is offline
4th Gear
Happened to me one night, tightened the cap and in the morning, the message was gone.
2008 Taffeta White Sedan EXL-NAV I4
OEM USDM: Interior Illumination, Back-Up Sensor, Body Side Molding, Door Edge Guards, Splash Guards, Bumper Applique, All-Season Floor Mats, Trunk and Lower-Dash Insulators (from V6), Car Cover
OEM Imported: Illuminated Side Step Garnish, Headlight Protectors
Non-OEM: 3M Clear-Bra, V-LEDS LED's
Old 09-23-2008, 06:37 PM
wilcat_2000 wilcat_2000 is offline
i've also read that the message can pop up if the tank is overfilled - that is, if you continue to top it off too much after the gas pump "clicks off" indicating full...did you recently fill-up?
Old 09-23-2008, 09:24 PM
I filled up few days ago and I didn't overfill. It was fine until today. So far, after the msg popped up, I had 3 restarts and the message is still flashing. Will wait couple of days to see if it goes away but if not I'll take it in for service.
I thought I bought Honda to avoid these kinds of little issues.
Haves:
Wants:
Previous Rides:
2000 CLK 320
1995 3000GT
1988 Supra Turbo
1982 Supra
1985 Accord
Old 09-24-2008, 02:36 AM
USAFRET USAFRET is offline
5th Gear
Happened to me three times now. Dealer looked at it and could find nothing wrong. They said they "lubed" it. Not sure what the hell that implies. But after several new starts the code will clear itself.
Tom
2008 Accord EX-L A5 w/Nav
Old 09-24-2008, 11:38 AM
mhadden's Avatar
On hiatus...
You could always disconnect and then re-connect the battery, too. It should clear the code. Make sure you have your radio code handy.
2011 Pilot EX-L AWD
2010 Corolla LE
2008 Goldwing Navi
Old 09-24-2008, 05:28 PM
LI Honda Guy's Avatar
LI Honda Guy LI Honda Guy is offline
I had the same problem on my EX Coupe. I would get the message, check the cap, and it was always tight. I would take it off anyway, put it back on again, and tighten it again. The message would sometimes go away, but inevitably it would come back. Finally, I went to the dealer, where they "checked and lubed it". Same as before. After a few weeks of this, I ended up buying the plastic clip, and the gas cap myself from the Parts Dept. for $22, and changed it myself in all of two minutes. Never had the problem again. I could've had it replaced under warranty, but I felt the $22 more then covered the multiple trips and hours waiting at the dealership so that it could be "checked and re-lubed" before finally having it replaced anyway. Good luck.
2009 Honda Accord Coupe EX Taffeta White
splash guards, wheel locks, body side molding, foglights, trunk tray
Old 09-24-2008, 07:57 PM
The msg finally disappeared today. If it happens again, I will go to the dealer and ask them to replace the cap. Most likely though, they won't do it unless it becomes a recurring issue.
Haves:
Wants:
Previous Rides:
2000 CLK 320
1995 3000GT
1988 Supra Turbo
1982 Supra
1985 Accord
Old 11-08-2008, 11:26 PM
WTH!!!!!!!!!!
This stupid message came back today out of the blue. Last time it happened, it disappeared the next morning. Today, it disappeared after third restart.
Why is this keep happening? I always make sure to turn the cap until it clicks after each refuel. Do you guys ever experience this?
Haves:
Wants:
Previous Rides:
2000 CLK 320
1995 3000GT
1988 Supra Turbo
1982 Supra
1985 Accord
Old 11-09-2008, 04:55 AM
Mase764's Avatar
~Sexy Time~
nope has not come back yet..
*Steve*
15 % Tints
TSX Switch Blade
Old 11-10-2008, 08:09 PM
ShawHDuser's Avatar
ShawHDuser ShawHDuser is offline
3rd Gear
Just happened to me the other day for the first time. My O.C.D. makes sure I turn it 4-5 clicks every time (don't ask) so I took it off, re tightened it and the warning turned off. Hope this isn't another in the long line of american-made quality control issues. No offence to the american visitors here, but maybe my sights were set too high with my RSX which came off the boat from Japan. 6yrs, not a single issue. Not a single creak, rattle, nothing. With my 6mo old Accord EX-L V6 I've been into the shop about 11x for various (albeit minor, but annoying) quality control issues.
'08 Accord EX-L V6 Coupe - Polished Metal Metallic
Old 11-10-2008, 08:13 PM
jblaust's Avatar
jblaust jblaust is offline
08 Accord EXL 6 Spd Coupe
This has happened on my wifes Honda Pilot before a couple of times. The manual says to make sure the cap is tight so you hear it click at least 3 times. It also says it can take a couple of days for the light to turn off. As mentioned before it could also be a faulty fuel cap. We make sure the cap is nice and tight and havent had an issue again since.
2008 Accord Coupe V6 EXL 6 Speed Manual Black/Black Leather
CE 046 wheels 19x8.5 in the front 19x9.5 in the rear 44 and 40 offset.
Eibach Pro-Kit (Modded) 2 inch drop
HFP Body Kit
6000K HID's in the Headlights and Fogs
Tinted Rear lights
5% tints
ALPINE IVA-W505 + ALPINE PMD-B200 7" touchscreen Navi/Dvd
JL Audio 300/4 and 500/1
2 JL Audio 10W3v3's
09 TSX switchblade key
Debagded
STOLEN
http://www.youtube.com/watch?v=dFtMMk9PqsU
http://www.youtube.com/watch?v=Z5gS1QPjkV8
