Reverse Problem - Drive Accord Honda Forums
Old 09-27-2008, 06:46 AM
Bouncnb Bouncnb is offline
4th Gear
Reverse Problem
I have a question. Yesterday when going from drive to reverse, backing into garage, the transmission wouldn't do it. It was in reverse but when I let off the brake and gave it some gas, it just free revved and rolled forward. I went to neutral, then back to reverse and the same thing happened. So I went to park, then back to reverse and there was a clunk and a bit of a shudder and it went into reverse. I did this twice yesterday.
Has this happened to anyone had anything like this happen with the current gen or past ones? Mine is a V6 w/auto.
I can just see it now. I take it to the dealership and they say they can't duplicate the problem, so there is no problem. Any help or advice would be greatly appreciated.
Old 09-27-2008, 07:45 AM
Coolcrush's Avatar
Coolcrush Coolcrush is offline
4th Gear
Dealer with the quickness
2008 Accord Sedan V6 w/Navi PMM
Old 09-27-2008, 08:33 AM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
Sounds like a failing tranny.
2007 EX-L 4DR
Old 09-27-2008, 08:47 AM
AgentWashington's Avatar
AgentWashington AgentWashington is offline
5th Gear
Does it still drive fine in anything other than reverse? Is there anything illuminated on your dashboard or is your "D" indicator flashing?
2008 RBP Honda Accord Sedan LX-P, 5AT
Mods
OEM: Wing Spoiler, Side Molding, Splash Guards, V6 front bumper with coupe fog light covers
Non-OEM: Toshiba HIR Lows, Chrome Door Pillars, Blue LED interior lights, White LED trunk and plate lights, Autozone chrome grille, lower bumper, and trunk trim, V-LEDs tail/brake light LED bulbs
Old 09-27-2008, 11:09 AM
elp_jc's Avatar
elp_jc elp_jc is offline
Out of Control
First things first. Check your fluid level. That's a typical symptom of low fluid. If level is okay, then you definitely have a problem, and it'd be time for a dealer visit. Good luck.
JC
Old 09-27-2008, 11:16 AM
G-Force's Avatar
G-Force G-Force is offline
3rd Gear
My car has only 2000km (1200 miles) and it does something close to what you described but not failing to engage.
Whenever I go from reverse to drive or even vice versa, I hear a distinct clank in the transmission. Not enough to feel in the car but certaining hear it. I have't had my first service yet but will mention it for sure.
'08 Belize Blue Pearl, V6 EX-L Auto. 20%/35% Tint, PXAMG iPOD Integration, 4300K XenonDepot HIDs, 3M Hood Protector, 10" JL Audio sub w/MTX Re-Q Processor.
Old 09-27-2008, 12:47 PM
Seandavid010's Avatar
Seandavid010 Seandavid010 is offline
4th Gear
Now, don't get all nervous, though. It could be something as simple as a faulty solenoid in the transmission. But still, get thyself to the dealer, post haste.
Current Ride:
2009 Accord EX PMM Sedan íPor fin, Mijo!
35% Llumar Tint all around
Splashguards and FloorLiners
TSX Switchblade Key (Yes, with a Sedan!)
XM Radio installed
Parrot CK3100 Bluetooth kit
Hard-wired iPhone install
'False Floor' in center console
Honda History:
1991 Civic w/ 120,000mi
Sadly trashed in an accident
1987 Accord Sedan w/ 140,000mi
Ol' Blue - burned a lot of oil
Old 09-27-2008, 01:58 PM
4th Gear
The car drives fine. It was just those 2 instances. I have approx. 10,900 miles. I will check the fluid level and also do the old sniff check to make sure it, the fluid, isn't burnt. If those are good, then I will make an appointment with the dealer.
Old 09-28-2008, 10:13 AM
next_milenium's Avatar
next_milenium next_milenium is offline
08 Accord V6 Coupe w/ NAV
Here's my $0.02. It's my understanding that an automatic transmission's gears should be changed only after a complete stop. I see too many people just go from drive to reverse or from reverse to drive before their car is completely stopped. I believe when you do that it puts a lot of stress on your tranny. Also, I try to give the tranny a second or so before I give it gas in order for the tranny to complete the gear change. If you instantaneously give it gas after you change from reverse to drive, you will hear the clunk more often.
08 Accord V6 Coupe Auto NAV PMM/Black
Haves:
20% Tint / 55W 5K HID / Debadged / Rebadged with HFP Emblems / No DRLs / 7th Gen Coupe Headrests / Oddyssey Lower Grill / 20" Privat Vulkans 20x8.5 45 ET / 245 35 20 Nitto Extreme ZR 555's / HFP Suspension / TSX RSB / Magnaflow CBE / Crosstour Shifter / Xpel Fog Light Film
Wants:
Rearview Camera / Hacked Navi
Previous Rides:
2000 CLK 320
1995 3000GT
1988 Supra Turbo
1982 Supra
1985 Accord
Old 09-28-2008, 10:22 AM
Accordlover's Avatar
banned
All the Honda's my family (and myself) have owned that had an AT were this way. 86, 96, 98, 99, 03, 08.
You'll put the car in a gear from park, and if you have the A/C off, radio off, windows down or the door open you'll hear a click/clunk as the gear engages.
The post about the time it takes for gear engagement is also true. It is not instantaneous. My Accords both take 2-3 seconds before I feel the gear click into action.
And for anyone who is always in a rush, stop before you make a gear change from a forward to reverse gear or vice versa. You're wearing out the transmission/motor mounts, the transmission itself and who knows what else. It just isn't good.
To the OP - You need to check for the dash indicator blinking, actually being lit or any other abnormality when this happens.
Old 09-28-2008, 10:29 AM
06AccordEX 06AccordEX is offline
Send a message via Yahoo to 06AccordEX
Must see dealer for detail.
Would you please help us by adding your car purchasing price into our car price database?
Share Your Car Price & Quote
Old 09-28-2008, 10:38 AM
elp_jc's Avatar
Out of Control
THAT is perfectly normal on a Honda. And so is the slight delay mentioned; on an auto Honda, you just can't put the tranny on 'D' and immediately stomp on the gas pedal, or you'd destroy your tranny in short order, as the motor would race before tranny engages. Good day.
JC
Old 09-28-2008, 04:47 PM
mhadden's Avatar
mhadden mhadden is offline
On hiatus...
Sounds like a cable adjustment might be needed. The dealership should take care of it for you.
2011 Pilot EX-L AWD
2010 Corolla LE
2008 Goldwing Navi
Old 09-28-2008, 05:23 PM
4th Gear
I checked the fluid level and did the old "sniff" check. The level was good and the fluid didn't smell burned. So, it looks like I am going to call the dealer and schedule a visit. Also, someone mentioned a blinking light on the dash. Nothing was blinking, it only indicated R. I was stopped going from Drive to Reverse. Now going from Reverse to Drive, sometimes I will shift before I am stopped. I know thats not good, but it happens. Like I said earlier, besides the two instances this happened, he car is running and shifting w/no problems.
Old 10-03-2008, 08:54 AM
4th Gear
**Update**
I just got back from the dealership. Here is what transpired. There were no codes showing up when they checked the computer. So they flashed/reset the computer. They also checked the linkage, there was no problem there. They also checked a contact sensor (magnetic sensor?). They said they made a small adjustment there.
Hopefully this doesn't happen again. If it does, then back it goes.
Title goes here
close
video goes here
