A\C Questions sounds like a diesel engine - Drive Accord Honda Forums
Old 10-10-2008, 06:31 AM
corrado_driver corrado_driver is offline
A\C Questions sounds like a diesel engine. Why does my car sound so bad with the A\C on. Also Some times its really cold and other times it dosn't seem to work
V6 ex 4dr 2003.
Thanks
Larry
Old 10-10-2008, 01:05 PM
lpaudio2 lpaudio2 is offline
5th Gear
either a bad compressor, bearing, or compressor clutch. Have them checked, you'll be glad you did, if the bearing or clutch fails it could (unlikely but possibly) throw the belt off.
2006 AV6 6sp
Old 10-10-2008, 03:40 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
If you hear abnormal noises from that compressor, get it replaced asap. If it does detonate, and send all it's guts through the system. It will cost you more than a small fortune if it does that.
The compressor should make little or no noise. Many do whine a bit at lower rpms, but grinding or knocking is NOT right.
