ABS + snow - Drive Accord Honda Forums
Old 11-25-2008, 04:55 AM
rischa rischa is offline
ABS + snow
Hello Colleagues,
It is my first winter in Montreal with an Accord Coupe 2008. It finally snowed with the snow staying on the ground.
This morning when I was stoping, my brakes seemed to of stiffed up and was impossible to press down
I have to mention that my TPMS lights started flashing this morning, even though everything was fine yesterday.
My question is, is this normal for ABS brakes? I have never had them before, so I am not sure if this is the normal behavior. I would really hope not, as it seems dangerous.
Thank,
Rischa.
08 Accord Coupe EX-L, 5AT, Navi, Polished Metal Metallic w/ Black leather
Old 11-25-2008, 05:05 AM
AznX TL's Avatar
AznX TL AznX TL is offline
need 6 speed!
Send a message via AIM to AznX TL
abs will pulsate.....stiff is a pretty bad sign. did you let your car warm up first?
-08 Accord lx-s 5speed manual/ tafetta white
mods
|DDM tuning 6k hids|12" Alpine Type-R|TSX switchblade|Lip spoiler|Type-R Suede red stitch boot|Gunmetal Type-R knob|
|Intake Resonator Delete|Hyper White led license plate led|led interior bulbs|Smoked Reverse lights|
Previous owned
-97 Acura 2.2CL auto/Flamenco Black
Old 11-25-2008, 05:25 AM
Yes I have an auto-starter and left it running for awhile before going outside.
But the brake petal is not suppose to stiffen?
Also, when pressing down on the brakes, a weird grinding noise is made. I aws told this is the ABS though
I am discouraged
Old 11-25-2008, 05:29 AM
AgentWashington's Avatar
AgentWashington AgentWashington is offline
5th Gear
Yes the grinding/pulsating sound is the abs. The brake pedal really isn't supposed to stiffen up though too early. Check your tire pressure and brake fluid.
2008 RBP Honda Accord Sedan LX-P, 5AT
Mods
OEM: Wing Spoiler, Side Molding, Splash Guards, V6 front bumper with coupe fog light covers
Non-OEM: Toshiba HIR Lows, Chrome Door Pillars, Blue LED interior lights, White LED trunk and plate lights, Autozone chrome grille, lower bumper, and trunk trim, V-LEDs tail/brake light LED bulbs
Old 11-25-2008, 06:58 AM
MatmanVT's Avatar
MatmanVT MatmanVT is offline
4th Gear
The pulsing and gridning of ABS is definitely scary the first few times, but is normal. (Something you will feel a few times this winter regardless of what kind of snow tires you put on there) I have noticed that the discs usually develop a slight amount of surface rust when its damp and they are left for a day or so, this usually grinds off in the first 2 or 3 brake pushes. (seems to be a honda thing, my 05 did it as well)
In the cold we have been getting the last couple weeks, the stiffening is normal until the car warms up, I have noticed it as well, however it does usually go away after the car gets warm (about 5-10 min of driving at the most). Keep in mind with your brakes, you are pushing fluid with that pedal every time, and all fluids get a little stiffer as things get cold!) We are supposed to get some slightly warmer weather this week, I would take the car out for a drive for a bit and see if getting it nice and warm makes a difference, if not, I would definitely get it checked. ~Slightly warmer means FINALLY above freezing again, this 18 degrees (negative 5 or something like that for our pals north of the border) in the day stinks in November!!!
2008 Accord EX-L W/Navi Sedan in Alabaster Silver
Retired:
2005 Accord EX-L Coupe
1998 Accord EX
1991 Accord LX
1986 Civic DX
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." Leonardo da Vinci
Old 11-25-2008, 07:26 AM
09 ACCORD COUPE's Avatar
09 ACCORD COUPE 09 ACCORD COUPE is offline
09ACCORDCOUPE
Matman is right on, ABS pulsation is normal and it does take some getting used to. Also, surface rust on the rotors tends to appear after a couple of days of not driving these cars, it does cause a grinding feel and sound until it scrapes itself off. My 06 Acura RSX did it and so does my 05 TL. It's definitely a Honda thing. Not sure about the stiffness though.
09 Accord Coupe BBP/BLK Leather EX-L V6 6MT Navi
05 Acura TL NBP/BLK Leather 5AT Navi
FIRST CAR- 1971 BMW 2000, IN 1982
Old 11-25-2008, 08:32 AM
Left-Laner's Avatar
Left-Laner Left-Laner is offline
4th Gear
I think what the OP meant was that when attempting to stop, he pressed down on the brake pedal and instead of the pedal going all the way down, the pulsating effect was felt (the effects of ABS).
I have noticed this on mine and the brake pedal does not go all the way down until the ABS has done its job.
2008 Accord EX-L NAVI I-4 Sedan
* 15% tint
* LED Tailights
* All interior bulbs replaced with LED.
* PP 5W-20, Wix Oil Filter
2004 Accord EX V6 Coupe
* Cold Air Intake
* LED Taillights
* PP 5W-20, Mobil 1 Oil Filter
Used to own...
2003 Accord LX-G
1997 Saturn SC2
1993 Saturn SL1
Old 11-25-2008, 08:56 AM
that is exactly what I meant. I guess I have to get use to it.
I do not have my winter tires on yet. Michelin primacy alpine:
Michelin Primacy Alpin PA3 Tires
http://www.1010tires.com/tire.asp?ti...macy+Alpin+PA3
Title goes here
close
video goes here
