window chrome trim question - Drive Accord Honda Forums
Old 01-06-2009, 12:49 AM
ac1c4l3 ac1c4l3 is offline
i recently purchased a 2005 honda accord ex 2dr/4-cylinder (black) and im wondering how i could add chrome trim around the passenger windows
any help is appreciated
Old 01-06-2009, 08:36 AM
CarlR33's Avatar
CarlR33 CarlR33 is offline
6th Gear
I assume if you have a 2 door and your talking about the door windows (passenger windows)? Where on the door are you talking about? Have you tried an accessory shop that specializes in trim and tint or a Honda dealer? Have you seen this on another Honda car?
03 Accord LX I4 5spd, 216k miles.
Old 01-06-2009, 11:46 PM
well im talking about the chrome thats goes around the window in your avatar pic but yes i only have 2 doors and the reason im asking is because theres a black film around it that is peeling/cracking away (i live in vegas so heat is brutal on a car) and under it seems to be bright steel/chrome looking metal so im wondering if its safe to just peel away
Old 01-07-2009, 11:21 AM
CarlR33's Avatar
6th Gear
Might stop by the dealer and ask them because I am not that famailiar with non chrome models or even if there is such a thing. Sounds like someone might have painted it? If it is painted, you could probably peal/sand/steelwool and repaint it with a little work. Look under the door parts section for your car under this website to see if you can find it. I was not sure which EX you have. http://www.hondaautomotiveparts.com/home.htm
You also might want to put a signature on your posts like mine so we don't have to ask what car you have each time. It can be setup under your settings.
Old 01-07-2009, 11:58 AM
luvr_of_vball's Avatar
luvr_of_vball luvr_of_vball is offline
5th Gear
I believe all 7th gen coupes don't have chrome around the windows. All sedans do have chrome trim with the exception of the DX/VP trim. Since the coupe doors must be larger than the sedan doors, you would likely have to go after market to add the chrome trim.
2007 Accord Sedan EX 5MT Graphite Pearl
Old 01-07-2009, 07:34 PM
any suggestions on that would be great on aftermarket place
Old 01-09-2009, 06:56 AM
5th Gear
I'm not sure how to advise you from here. There's probably some options out there, but that area of interest is one I'm not very familiar with. Maybe you should throw this question out is the "modify" section. The folks there might be more knowledgeable. Good luck.
