V6 Timing Belt Inspection? - Drive Accord Honda Forums
Old 01-17-2009, 03:19 AM
elgato elgato is offline
Today my 04 V6 LX with 56K went in for an oil change and inspection.
They reported that the timing belt was in poor condition and recommended that it should be changed at the "scheduled interval" of 60K.
Do they really look at the timing belt? The owners manual recommends replacement at 105K for both normal and severe conditions, not 60K.
Any idea whats going on here?
Thanks
Old 01-17-2009, 05:44 AM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
I believe the '04 is 110k, but I could be mistaken.
Anyway, the only way to see the belt is to pull the forward upper cover, 5 bolts are there to remove.
I doubt there's anything wrong with the belt, but if you're uncomfortable you can take that cover off yourself or bring it to another shop for them to check for you.
Old 01-17-2009, 05:52 AM
BLCKFLSH's Avatar
BLCKFLSH BLCKFLSH is offline
Make that BluFlsh
Do you live and drive in an "extreme" climate (over 110 or -20 degrees F)? I would definitely get a second opinion on that. 60k miles is only recommended, if you regularly drive in these extreme climate situations.
Old 01-17-2009, 05:55 AM
BLCKFLSH's Avatar
Make that BluFlsh
It's 105k, and there is an access hole in the upper covers, so you don't have to remove them to check the belt.
Old 01-17-2009, 05:59 AM
Fredsvt's Avatar
Moderator
you can't see the belt well enough through those holes, that's for timing mark reference.
Old 01-17-2009, 06:23 AM
ezshift5's Avatar
ezshift5 ezshift5 is offline
6th Gear
......with the strong, efficient J30A4 - - an 'interference' engine - - the timing belt concern gets attention big time...........
certainly more than the 5M Solara which preceded my 6M...................
A second (competent) opinion may help one sleep at nite...................
best, ez....,
2005 Accord EX V-6 Coupe 6M
Taff. White;cargo net;7-24-05
'13 VW JETTA SPTWGN TDI 6M
Build date:03/12/2013 NO NAV
ZERO SUNROOF:CANDY WHITE
1982 VW Rab. Diesel Pickup 5M
Mojave Beige/ac/bedliner/alloys
(sold to restoration outfit)
Old 01-17-2009, 07:50 AM
Accordriver's Avatar
Accordriver Accordriver is offline
6th Gear
X2
Can you take the cover off and take pics? If not just take it to another shop
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Old 01-17-2009, 09:14 AM
SatinSilver's Avatar
Moderator
When I had my oem tires replaced at 58k the Firestone shop wanted to replace the timing belt, accessory belts, water pump etc when it wasn't due till 105k and 3 yrs to go on the time limit. About $1300 in extra's...yeah right. They couldn't even get the wheel weights to stay on.
Old 01-17-2009, 09:20 AM
6th Gear
heh, I spent an hour replacing a harness and wiring on a lexus that melted because of a firestone "mechanic"
Old 01-17-2009, 09:58 PM
BLCKFLSH's Avatar
Make that BluFlsh
Has anyone heard of belts breaking on these engines? I haven't. It shouldn't be too hard to remove the front upper cover to check it out though. I plan to change the timing belt myself, when the time comes. I love a challenge!
Old 01-17-2009, 10:13 PM
6th Gear
Since it's an interference engine, nobody is stupid enough to let it break. If you do it yourself make sure you do it right.
Old 01-19-2009, 07:41 PM
BLCKFLSH's Avatar
Make that BluFlsh
Believe me, there are plenty of owners out there who are well over 100k miles, and haven't changed the belt yet. I've never changed a timing belt before, but I did change the timing chain on my truck. I'm no mechanic, but I do know my way around an engine.
Old 01-19-2009, 08:09 PM
Accordlover's Avatar
banned
Change it at 105k miles unless you live in AZ or see 110+ degrees on a daily basis. Same goes if you see below zero daily. I changed my timing belt at 132k miles, no problems.
They just want money. Next time you're in there, why don't you ask that they take you to your car to show you the timing belt. And if they bring you a belt, that's complete BS.
It's very strange for a dealer to inspect a timing belt during an oil change. Very strange.
Title goes here
close
video goes here
