Sunglass Holder Replacement (Pics) - Drive Accord Honda Forums
Old 01-20-2009, 12:36 AM
04 EX Coupe's Avatar
04 EX Coupe 04 EX Coupe is offline
Hey guys, so I picked up my 2004 Accord EX-L V6 this past weekend, and I love it, except for one thing... My sunglass holder won't stay closed. Seems like it will stay in the shut position for approx 15 minutes, unless a large bump is hit, then it will pop open. Has anyone else had this problem? Any ideas on a solution?
2004 Accord Coupe EX-L V6
Old 01-20-2009, 03:57 AM
Gen7coupe's Avatar
Gen7coupe Gen7coupe is offline
KENYA DIG IT?!
Send a message via AIM to Gen7coupe Send a message via Skype™ to Gen7coupe
i had this problem a while back too....forgot how i fixed it though. i think there's this pin on the left side that was moved out of place. the pin follows this path and when it's not in the grove, it doesn't lock it in place....sorry i can't be any clearer but i'll come back later and hope fully explain it better after i look at my car
2003 Honda Accord EX-L
195,xxx miles (as of Nov 2012)
USAF
Old Cars
2001 MituSHITbe Galant
2000 Honda Civic Si
1995 Honda Prelude
1989 Nissan Sentra
Old 01-20-2009, 08:49 AM
accord4daddy accord4daddy is offline
Don't Know Me?
MIne does the same thing and after inspection all I have is the pin and not the rest of the unit so it keeps sliding out.
2004 Accord Coupe EX-L V6 AT--67K
2007 CR-V EX-L 4WD--18K
Old 01-20-2009, 11:01 AM
Bucho Bucho is offline
2nd Gear
I had the same problem about 10k miles when I purchased my 05 ex-l coupe v6. I took it to the dealer and they replaced it. The tech said it was a known issue. I never bothered to check if there was a TSB on it.
Old 01-22-2009, 07:25 PM
nycnftm nycnftm is offline
The replacement part cost less than $2 at Honda service. I bought it but never installed it. Lately I've been taking the sun-visor attachment out and sliding it out to cover the sunglasses holder shut.
Old 01-23-2009, 06:46 AM
rafael73 rafael73 is offline
Too old to tolerate
buy a new one!
Old 01-23-2009, 05:37 PM
shop_9625 shop_9625 is offline
2006 V6 6MT Sedan
I haven't come across this problem and I use mine a lot. Polarized sunglasses have changed my life.
Old 01-23-2009, 07:49 PM
Gen7coupe's Avatar
KENYA DIG IT?!
that had nothing to do with this subject so please post responsibility
USAF
Old Cars
2000 Honda Civic Si
1995 Honda Prelude
1989 Nissan Sentra
Old 01-29-2009, 12:56 AM
Lightbulb Replacing Sunglass Holder (with pics)
OK, so today I replaced my sunglass holder in my 04 Accord EX-L, and I wanted to post up a thread so if any other 7th Generation owners have the same problem they have a crude road map...
1) Remove the two screws located in the roof of the sunglass holder compartment.
2) Gently pry the covers off the front map lights. (I did not have one of those small screw drivers, so I used a 1.5mm alan wrench)
Here is a picture of the map light cover so you can see how the clips hold the cover in place.
3) Remove the screw located next to the lightbulb on both sides.
4) Gently remove the whole assembly from the headliner. Make sure to unclip the two wires powering the maplights and ambient lighting!
5) Pop the maplight/ambient light assembly out of the sunglass holder by gently pushing on the back portion of the lights.
6) Insert old map light assembly into new sunglass holder, making sure to push it till it clicks into place.
7) Insert the whole assembly back into headliner and replace the four screws that were removed in order to take the assembly out. When done it should look like this:
I was able to do this change in about 30 minutes. I used a quick release rachet w/8mm Socket (w/extension) for the two screws located inside the sunglass compartment and a phillips head screw driver for the screws located in the maplights. Below is a picture of the tools needed to perform this repair. **The flashlight was used b/c of how dark it is in my garage.**
Old 01-29-2009, 02:18 AM
We have two different problems. The $2 part is the black locking mechanism on the drivers side of the holder. My problem is the actual holder that folds out of the ceiling is broken. The part from Honda cost me $32.85, took me thirty minutes to replace. I posted a thread up with pictures...
http://www.driveaccord.net/forums/sh...unglass+holder
Old 01-29-2009, 04:06 AM
Don't Know Me?
Good job!
Old 01-29-2009, 04:35 AM
Aviography's Avatar
Aviography Aviography is online now
Merged with original thread.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 01-29-2009, 04:03 PM
darula8's Avatar
darula8 darula8 is offline
Red Devils
Now all u gotta do is get rid of the ugly stock yellow light bulbs
Old 01-29-2009, 04:48 PM
Gen7coupe's Avatar
KENYA DIG IT?!
that's why you should get some led bulbs see this post for some info
http://www.driveaccord.net/forums/sh...ad.php?t=27022
USAF
Old Cars
2000 Honda Civic Si
1995 Honda Prelude
1989 Nissan Sentra
Tags
sunglass holder
Title goes here
close
video goes here
