Can I put a Front Shock Tower Bar in an 09 LX Sedan?
I see that the EX's have a front shock tower bar that the LX's don't have. So this leads to a number of questions.
Does the bar improve handling? If it does, can I install it in my car? If I can have it installed, what's a good one to get? Would it void my warranty? And if I had a shop or the dealer install it what's typical labor time or cost for it? This would be the first real mod I've done for this car unless you count the tires. :P
2009 Honda Accord LX - Crystal Black Pearl - Wing Spoiler, Cooper CS4 Tires, 35% side & 20% rear tint using LLumar High Performance film. Ballpetter: 2009 Honda Fit Sport - Storm Silver Metallic |
| Sponsored Links | ||
Advertisement | ||
the shoch tower bar doesnt make much f a difference......the lx doesnt come with a bar because it is base model....you could add a bar if you wanted to.....check out my headlight overlay....what do u think???
I wouldn't see why you couldn't install it in your car - the design is universal over the trim lines... I'm not sure if it improved handling (though most "race" cars seem to have them), but I think it provides extra rigidity and doesn't allow as much cowl flex and could possibly prevent mushrooming of the shock towers over times (a very bad problem on non-strut brace equipped E46's).
2011 Pilot EX-L AWD 2010 Corolla LE 2008 Goldwing Navi |
too overdone, too much going on in the front...no my thing
2011 Accord Coupe EX-L V6/Navi PMM |
IMO it just stiffens both towers from some flexing in turns. As for installing the OEM one, you will have to get EX+ upper strut tower mounts as the LX does not have bolt studs to mount it. 3rd party strut brace that use same 3 mounting bolts at top strut would work.
Ed 2008 Accord LX, Alabaster Silver Metallic gone 1985 XR4Ti gone 1974 Opel Manta rally |
LOL I LOVE THIS PLACE!... Dont ask any questions unless you are ready for an unbiased answer ... which is why I never ask em
08 Accord LX Sedan (Polished Metal) Mods So Far: Debadged Switchblade Key Fob 8k HID's Tint (20% front - 5% back) Future Mods: H&R Springs Auto-Up Windows Speakers and Sub |
I asked this question awhile ago and it was determined, as Edaccord08 has said, that the bolts needed to mount the brace are not present on the LX/LX-P trim levels. Replacing the LX stock bolts would require pretty much taking apart the suspension, so I don't think it would be worth it to get the OEM one.
2008 RBP Honda Accord Sedan LX-P, 5AT Mods OEM: Wing Spoiler, Side Molding, Splash Guards, V6 front bumper with coupe fog light covers Non-OEM: Toshiba HIR Lows, Chrome Door Pillars, Blue LED interior lights, White LED trunk and plate lights, Autozone chrome grille, lower bumper, and trunk trim, V-LEDs tail/brake light LED bulbs |
Not yet... 8th gen accords are still "new" to the market.
Hideous, I hope it is only photoshopped to the car. Also, you should open a new thread for that.
2008 I4 Auto EX-L Navi Alabaster Silver Metalic Tinted Windows - Body Side Moldings - Splash guards - Battery Homelink - Trunk, Driver's & Passenger's side Insulator - HIR low beams - Interior & Lisence plate LEDs |
How do i install the strut bar?
honda accord 2008 lx-p |
http://throwdownperformance.com/inde...roducts_id=288 Installation couldn't be easier. Take the 3 nuts off the bolts you seen on top of the strut in your engine bay. Put the bar on with the bolts going through the corresponding holes (there will be extra holes that fit the EX that has more bolts). Reattach & tighten the nuts you removed. If you know how to use a simple wrench, you can do it yourself. Note: there will barely be enough bolt exposed for the nuts to attach securely. Tighten it as best you can, but don't go ape-sh*t on it. As for the difference, most say it doesn't make that much of a difference, some will disagree & say they notice a big difference. Your experience may vary.
2010 Accord Sedan LX-P, Auto (sadly) bought new 6/30/10 Mods TSX rear swaybar wing spoiler P2R throttle body spacer To do: strut tower bar spacers chrome handles |
TheTick247 said it. Ultra Racing makes one. Mark at Throwdown could give you more info Megacow. Installing it should take no more than 15 minutes. It's just a matter of removing the 3 bolts (for models without the OEM strut tower brace) connecting the struts to the strut towers, putting the bar in and bolting everything back together. Also, and this is just my opinion, if you're going to do a front strut bar on a model like the LX(P) that doesn't have it from the factory, I would at least upgrade the rear sway bar as well. Since you are adding a brace up front and stiffening the chassis up front, it's going to cause some understeer on our FWD cars. So I'd balance it out a little by adding a slightly thicker rear sway bar or rear strut bar if there even is one. Ultra Racing probably makes that too for all I know. Again, just my theory, take it with a grain of salt or however else you like it.
2011 PMM Accord LX Sedan (Auto) |
| Sponsored Links | |
Advertisement | |
